Drivers side quarter panel
Old 06-28-2016, 11:09 AM
Irishamericanld's Avatar
Car: 1992 firebird
So here's is the next part to tackle.. After reading the boards here about this issue I am wondering what caused it... There doesn't appear to be any damage to the bumper that would have caused it to push into the door. The door catches at a few spots and caused the quarter panel edges to roll.. Should I pull that part off and hammer it out or replace it ?
Old 06-28-2016, 02:32 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Re: Drivers side quarter panel
Check the pinch weld area where the fender mounts under the car. It's possible that it was improperly jacked up there instead of the actual proper jack point causing the fender to bend and/or shift.
Old 06-28-2016, 02:33 PM
Car: 1992 firebird
Cool beans! You know what I noticed? The drivers side front post looks bent and has some rust..
Old 06-28-2016, 04:04 PM
battman's Avatar
Engine: 350, 350, 305, 396
This! seen it many times myself.
Old 07-02-2016, 04:46 PM
Car: 1992 firebird
Looked under the panel and saw that it is indeed bent up ... I'll bend it down and then see how the fit is ..
Old 07-03-2016, 12:21 AM
Billgluckman's Avatar
Replace that fender.
i could be wrong but i'd bet there was a fender/door replacement done and things weren't aligned properly.
yevgenievich
South Central
11-27-2016 01:21 PM
AW119 Pilot
Pacific Northwest Region
04-15-2016 11:03 PM
Vanilla Ice
04-08-2016 01:08 PM
Lar98ss
04-06-2016 06:07 PM
stegal
04-02-2016 10:43 PM
Quick Reply: Drivers side quarter panel
