Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Weight reduction weight transfer traction first 100lb from bone stock
Old 06-21-2016, 05:44 PM
Cal.91maroproj's Avatar
I recently purchased a all redcamaro rs v6 3.1l for 500 I want to keep it looking stock and still pull hard without big turbos Nitrous maybe? 😷😶😓
Old 06-21-2016, 05:48 PM
Re: Weight reduction weight transfer traction first 100lb from bone stock
I removed this spare tire rack jack door motor latch with slide rail thing old heavy carpet and sound dedonating
Old 06-21-2016, 05:51 PM
Here it is before i fabricate and build a batery rack install and re assemble interior like lightweight carpet hope someone gives me good ideas before i put it back together
Old 06-21-2016, 05:54 PM
Spare tire metal rack removed im guessing 5-8lb let me know wat all of you think em i in a good derection or not
Old 06-21-2016, 05:55 PM
Old 06-21-2016, 05:57 PM
So far no bad rust hopefully she is all clean of rust
Old 06-21-2016, 05:59 PM
Some welds i cut of to remove braket
Old 06-21-2016, 06:03 PM
This is next to remove before batery rack plans im guessing 3-5lb im hoping -100lb after this quick weight reduction project. DOES ANYONE KNO WHAT IS THE STOCK WEIGHT FOR A 91 RS V6 3.1 CAMARO 3RD GEN PLEASE ANYONE AND THANKS
Old 06-22-2016, 12:46 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
so if you cut that off, what will you use as a hatch latch?
Old 06-23-2016, 11:49 AM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Probably hood pins through the hatch? It's not very uncommon to do in a race car.
I'm actually debating removing the entire latch assembly on my s10 street/strip truck and pinning the gate shut. It should lose a few pounds and get rid of that annoying tailgate raddle at idle.
Old 06-23-2016, 01:24 PM
Maybe hoodpins not sure what I'm going to end up fabing up or installing but I do know it has to be lightweight
Can u see picture? thinking thats a good spot for battery and i drilled out some ground holes but ended up with more than 3 pounds for shure on metal and dirt on my portable vacume no filter just bag no dust in bag just grains and grains of dirt and metal
Old 06-23-2016, 01:27 PM
That should be enough ground holes less weight
Old 06-23-2016, 01:54 PM
Here is my hood it is very heavy so far not shure how many punds it has lost but the big piece feels abit over a pound and the metal shavings are in my vacuum with those 3 pounds
The holes i drilled out
Old 06-23-2016, 02:00 PM
Lighter intake i cut of some metal to make foom for filter
Old 06-23-2016, 02:16 PM
Horn weighs about 2 or 3 pounds going to wire new steering wheel with cheap light horn and should loose more weight up front and more weight on back because of battery but more traction because of weight and more evened out weight due to less weight on right than left on the back anyways wat u all think
Old 06-23-2016, 02:28 PM
I also started reducing weight my quick idea of reducing my first 100lb is...
1.remove all rear interior to skeleton.
2.remove(cut/grind) any body metal like ..
Spare tire mount bar thing I'm guessing 5-7lb
Spare tire jack toolsguessing 25lb
Rear latchmotor and mount rail guess 12-16lb
All old cushionsound mat stuff gues5_10
Lighter battery guess 15-20lb
Battery relocation to rear
Intake lightest cold air I can find ? 3-10lb
Exhaust mods/fan lightest I can find ? 15-20lb
$20 Lightweight USB only stereo 2 spkr ? 5-8lb
Ac delete if I find out it does not work ?5-10lb
Let me know what you guys think
Old 06-23-2016, 02:34 PM
This is the steering wheel with horn about 1 more pound added but i get horn
Old 06-23-2016, 05:22 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Axle/Gears: 9 Bolt 3.45
i wouldn't cut out the rear hatch latch or drill any more holes man... its not really worth hacking this car up more to save a couple pounds. buy a lighter hood and lighter parts. you can drill this body to swiss cheese and its still gonna be pretty slow due to the v6.
Not trying to offend you but this is just my opinion
Old 06-23-2016, 08:07 PM
Yes that's what in thinking now too much work better off looking for lighter hood I'm thinking of a custom sunroof ��
Old 06-23-2016, 08:14 PM
tealman92's Avatar
Car: 1992 Z28
What's your end goal? Lighter to be a fast race car? Or cruiser? Why a sunroof? It will add weight.
Old 06-25-2016, 01:03 PM
This is wat ive seen before this style looks quick to fab up and install but with a tint
Old 06-25-2016, 01:05 PM
I would likesomething like this one in future as a cruiser tho
Old 06-25-2016, 01:06 PM
But I am thinking the quick plastic one just need to find a gasket seal before anything
Old 06-25-2016, 01:36 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
God help you if that car is ever hit.
That interior sheet metal is there for a reason. These cars already have enough structural problems.
You better cage that car stat.
razman340
09-18-2009 07:18 PM
daves12secV6
09-28-2006 02:45 AM
Doward
05-16-2005 09:07 PM
ImportsRsloths
05-25-2001 02:13 AM
Quick Reply: Weight reduction weight transfer traction first 100lb from bone stock
