V6 verts?
V6 verts?
Did the convertibles only come with V8's or were some built with a V6.
1989 is the model year I'm wondering about in case it matters.
It's tough to find the build options for the convertibles anywhere online.
Car: 1988 IROC Z Convertible
Engine: 305 TPI (LB9)
Axle/Gears: G80 GU2
Re: V6 verts?
I remember seeing these base model verts around.. They must have had some with V6.. I bet they are rare..
Car: 86 Firebird
Engine: 2.8l V6
Re: V6 verts?
My 86 firebird is a 2.8L multiport V6. Anyone know why the V6 and V8 radiators are opposite each other. The V6 filler neck is on the drivers side. I'm having a hard time finding an OEM style radiator.
Re: V6 verts?
My 91 is a V6, yes it's slow. But honestly it's not that bad, It gets up and around just fine. Where the lack of power shows is on the highway. Going to pass someone you need to get a running start at it. Up to 75mph it's tolerable. I always tell myself that for it's time it probably wasn't nearly as noticeable compared to the other things on the road at the time.
Mine just turned 53,000 miles the last time we had it out. I had every intention on swapping an Ls1/T56 into it, but it just runs and drives so well. It cruises great and floats along...I don't want to loose that and make it all hot-roddy. Car only comes out when the top can be down.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: V6 verts?
For the Camaros, the V8 only LG4/A4 and LB9/MM5 were for 1987 only, from 88-92 I believe the V6 was an option for every year. They pop up every now and then.
Re: V6 verts?
My friend in college had a 1992 3.1L auto vert green with black stripes and 25th anniversary badges
uNkleStv
10-24-2010 08:38 PM
