South East Region Regional Board for South East Members.
Official Tampa, FL Area Thread
Old 04-12-2016, 08:35 PM
  #2301
84LsxZ28's Avatar
Car: 1985 Z28
Engine: Turbo 5.3
Transmission: 4l80e
Axle/Gears: Ford 9"
Re: Official Tampa, FL Area Thread
Originally Posted by Gfunkill
If there isn't a meet, just come over here and drink.
Lmao, sounds good to me
Today I started my LS for the first time. It sounds mean. Tuning with the Megasquirt has a really big learning curve to it. Just getting it to stay running after it first fires up is what I'm working on right now. Will has been helping me through it though so hopefully I'll get it tomorrow.
Old 04-12-2016, 11:24 PM
  #2302
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
Late May is the gathering in Atlanta. That is where you should be, 84!
Old 04-15-2016, 11:39 AM
  #2303
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
I'm hoping to be there. We'll see how that goes though.
Old 04-15-2016, 07:34 PM
  #2304
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Had fun wednesday night. 1/8 mile at showtime dragstrip. was my first time on a real strip. been doing tons of street racing over the years. took me a bit to figure out the staging, etc. i was a bit disappointed in my times but i guess it was to be expected? first 3 runs were 8.7. last run was 8.3 at 83mph with 100 shot. not very impressive but all in all a good time.
was cool i got #3 as i'm an Earnhardt fan, lol.
Old 04-16-2016, 08:04 AM
  #2305
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
whats your gear ratio?
whats the specs on your converter?
did you spray off the line?
what did your plugs look like after the pass?
where was you bottle pressure
Old 04-16-2016, 11:04 AM
  #2306
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
3.73
about a second off the line
havent done a plug reading yet
IDK the bottle pressure? im a noob to nitrous, but i had the bottle filled and only sprayed it once or twice before racing.
heres the converter im using; http://www.summitracing.com/parts/sum-700350
as kind of a fun bonus, the SRT neon that beat me last year with his 22lbs of boost only ran a 9.2 and a 9.0. i was happy to have run a lil faster. got a video on facebook but dont know how to move it here? its in a group called "third gen riders."
pulled some plugs. they look ok to me. maybe a bit rich, idk? thoughts?
Old 04-16-2016, 07:55 PM
  #2307
L98GTA87's Avatar
Car: 1987 Trans am
Engine: 350 Vortec Stealth Ram
Axle/Gears: 02 SS Torsen Zexel 3.42
Originally Posted by RubberDucky
Meet at my place this Saturday. PM me for my number so I can text you the addy.
Just saw this, otherwise would have been there.
Old 04-16-2016, 08:26 PM
  #2308
Car: 1989 Camaro RS
Engine: LH6
No worries. We called it since Will's car had it's heater core fail right before he came out.
I've gotta push the Camaro back again. The 4Runner needs about $500 worth of maintenance if not more.
Old 04-17-2016, 11:29 AM
  #2309
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
Originally Posted by redneckjoe
3.73
What kit are you using.? There should be some basic guidelines for beginners using nitrous.
You want to keep your bottle pressure between 900-1100.
For PIZZ sake don't use a torch to heat the bottle and get the pressure up...
you don't want to use projected tip plugs like your using there.
What was the fuel pressure at the fuel solenoid?
Old 04-17-2016, 01:46 PM
  #2310
Car: 1989 Camaro RS
Engine: LH6
Old 04-18-2016, 08:01 AM
  #2311
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
Is that a third gen meet of 1?
Old 04-18-2016, 08:36 AM
  #2312
Car: 1989 Camaro RS
Engine: LH6
Lol, there's a 3rd gen 4Runner in the background.
Old 04-18-2016, 12:55 PM
  #2313
Car: 1991 Firebird
Engine: 3.1L V6
Old 04-18-2016, 10:51 PM
  #2314
Car: 1989 Camaro RS
Engine: LH6
Started some work on the car. Swapped out the broken power antenna for a non-power unit. Tried to remove the rest of the old harness at the bulkhead connector but no luck. Will have to try again tomorrow.
Old 04-26-2016, 11:01 PM
  #2315
Car: 1989 Camaro RS
Engine: LH6
Sold my C4 Vette wheels, selling my spare set of headers tomorrow. And probably going to pull my Hooker setup and sell that soon as well. Prepping for a LS swap.
Old 04-27-2016, 03:13 AM
  #2316
Car: 1991 Firebird
Engine: 3.1L V6
Got a lead on a motor? Going T56 as well? You should have done this from the get-go.
One day, I'll do the swap as well.
Old 04-27-2016, 09:31 AM
  #2317
Car: 1989 Camaro RS
Engine: LH6
No leads yet, planning on T56. I haven't really started looking since I'm still recovering from spending so much to move, and the 4Runner is in need of maintenance so that has to come first. Can't LS swap the car if I can't get to work.
Old 04-29-2016, 08:06 AM
  #2318
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
its the NX express mainline, plate kit. adjustable to 250.
i went from 45 to 43 plugs. i do have some champion equivilant to AC 41's.
fuel pressure is 7psi at carb. no gauge at solenoid. i'd like to add a low fuel pressure cut off switch soon.
Old 04-29-2016, 08:11 AM
  #2319
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
been working on a new exhaust system lately. the old one was 2 1/2" with a lot of bends.
new one is manrel bent 3", with not an "H" or "X" pipe, but a "K" for an expected increase of over 500hp, lol.
Old 04-29-2016, 08:14 AM
  #2320
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Old 04-29-2016, 09:23 AM
  #2321
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
your going to want to change to a non projected tip.
http://www.rockauto.com/en/moreinfo....=69261&jsn=233
these are what I use for a 150. they are for an aluminum head. Notice how the electrode is down in the plug.
Old 04-29-2016, 09:29 AM
  #2322
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
http://www.nitrousexpress.com/instructions.html
they want bottle pressure at 1050. and 10lbs of fuel pressure at the noid.
I have a fuel pressure safety switch on mine. (hobbs switch). Reading on forums, a lot of people say to not run them. They will leak and spray fuel over everything. Ill be removing mine.
Old 04-29-2016, 10:35 AM
  #2323
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
i appreciate the tips. not too worried about blowing this motor, (although i really dont want to), its been together since 2005. just cast heads, pistons and crank. eventually i want to build something bigger and stronger. takes time and money. im thankful to just have a toy to play with.
Old 04-30-2016, 12:19 PM
  #2324
Car: 1989 Camaro RS
Engine: LH6
Probably gonna do a head and carb swap on the 327. LS swap is way down the road and I wanna drive my car now. I don't like that it sits doing nothing. I've got too many other things going on at the moment to fix it like I want.
Old 05-01-2016, 10:37 AM
  #2325
Car: 1991 Firebird
Engine: 3.1L V6
Again?
Old 05-01-2016, 05:47 PM
  #2326
Car: 1989 Camaro RS
Engine: LH6
Again?
Yeah, life seems to always have a good way of smacking you in the face.
At least I can do a head, cam, and carb swap in the 327 for less than $1000. Will wants to buy my 700R so if I come across a 5 speed swap I can recoup some money.
Old 05-01-2016, 09:53 PM
  #2327
Car: 1991 Firebird
Engine: 3.1L V6
What is wrong with the current setup?
Old 05-02-2016, 09:07 AM
  #2328
Car: 1989 Camaro RS
Engine: LH6
One of the heads is losing a valve on cyl 1 and cyl 7. I could rebuild these heads but they are a garbage casting, and who knows what the cam is, my carb is junk too.
Motor really just needs a top end rebuild, but I wanted to go EFI again and make the car daily worthy again.
Old 05-02-2016, 01:24 PM
  #2329
Car: 1991 Firebird
Engine: 3.1L V6
Which one is your daily? The 4runner? Why not fix that and save $$ for LS instead of waste more money on that motor. Or sell the motor and buy LS.
Old 05-02-2016, 07:09 PM
  #2330
Car: 1989 Camaro RS
Engine: LH6
I fixed the 4Runner. I'm only gonna fix the 327 just so I can drive the car until I have most of what I need to LS swap. I'm months away from even buying a motor right now. I moved recently so I'm still paying down the debt that's come from that.
Old 05-09-2016, 11:08 AM
  #2331
Car: 1989 Camaro RS
Engine: LH6
On the hunt for a set of 083 heads, can be in any condition as long as the valves are there. Don't want to spend more than $100 on them if you guys don't mind keeping an eye out.
Opinions on this cam? It seems to be right where my goals are without breaking the bank. I've already got a set of Scorpion 1.5 roller rockers to go with it.
http://www.summitracing.com/parts/lu...make/chevrolet
Old 06-01-2016, 01:32 PM
  #2332
edwardk12687's Avatar
Car: 89 iroc
Transmission: t5
Axle/Gears: 323
lunanti makes a good cam however one thing you want to be careful is the size if your running a.c and the like. go to big you will need a vacuum canister for your brakes and such to work.
Old 06-01-2016, 01:53 PM
  #2333
Car: 1991 Firebird
Engine: 3.1L V6
You sons a bit...missed out. Awesome time at the gathering! So awesome I apparently don't remember anything past 11pm Saturday night. Crap. At least I'm not the only one, many only have photos to reference by. Except, I'm not in any of them.
Old 06-01-2016, 04:48 PM
  #2334
Gfunkill's Avatar
Car: Sport Coupe
Engine: 3.4 MPFI
Transmission: WC T5
Dude, I don't remember anything past 11pm on ANY Saturday night.
Glad you had fun.
Old 06-01-2016, 06:50 PM
  #2335
Kingtal0n's Avatar
Car: 240sx
Engine: whatever works
Transmission: 4l80e this year
Axle/Gears: 3.512
hey guys, I know its not Tampa but I live in south FLorida and I tune all your engines, and others. You can do hourly $100/hour and the first hour is free if you bring me the vehicle and supply the electronics, usually take 2-3 hours on the street to do a full tune just the most basic drivability/safety functions in any ECU with a large injector 500-800rwhp street car, then we can goto the dyno if you want it cleaner, I use the same dynometer at STP Performance in Ft Lauderdale, for 15 years. I also create a diagnostic report and tell you what you need to fix or upgrade or even downgrade based on years of experience and knowledge. Most jobs are $200 total to give you an idea, plus dyno time which is usually $60, it only takes me 5-7 runs usually to clean it up and get the most from the combination, then we can dial it back for the street as needed (loading on the street against vehicle weight and gearing is quite different than pushing a roller "weight"). Not to turn this into a damn book but I keep forgetting to let people know on this site that I still tune cars.
Old 06-06-2016, 11:00 PM
  #2336
Car: 1991 Firebird
Engine: 3.1L V6
Rubber, have you been driving your car? I had a guy at my work say he saw an orange 3rd gen camaro lowered with silver wheels in Lakeland.
Old 06-07-2016, 09:29 AM
  #2337
Car: 1989 Camaro RS
Engine: LH6
Unfortunately no. It's been in the garage since January. I'm hoping to get the motor into okay shape for July 4th though. My girlfriend wants to ride around in it lol.
Old 06-07-2016, 09:52 AM
  #2338
Car: 1991 Firebird
Engine: 3.1L V6
Uh oh, better have some dark tint and a/c. We all know what that means when the girlfriend wants to go for a ride in it. They want you to take them somewhere fancy and spend lots of your $$.
Old 06-07-2016, 11:00 AM
  #2339
Car: 1989 Camaro RS
Engine: LH6
Hahaha, it won't have A/C on the 4th, but when I finish up the motor it will. Good thing it's got a posi, I can spin the tires easier lol.
Old 06-07-2016, 12:15 PM
  #2340
Car: 1989 Camaro RS
Engine: LH6
Got a lead on some heads. Bare 186 castings, they are double hump heads, but they have accessory holes.
Old 06-07-2016, 11:27 PM
  #2341
IROCUDREW's Avatar
Car: 1989 Chevorolet Iroc-z convertible
Engine: 383, holley terminator efi
Axle/Gears: stock 10 bolt w/ 3.73
Any car meets around the area? I'm near sun city center. I recently relocated to Florida from New Jersey.
Old 06-08-2016, 08:03 PM
  #2342
Car: 1991 Firebird
Engine: 3.1L V6
Welcome, Drew!
We haven't had a get together in some time now. I usually do stuff with some of my friends with other types of cars. Next event I will be going to is in Lakeland at the Detroit Muscle Speed Shop. That will be July 9th.
Old 06-08-2016, 11:49 PM
  #2343
Car: 89 iroc
Transmission: t5
Axle/Gears: 323
yes welcome its good to see new members around maybe we can revive this thread lol by the way if anyone is interested i finally go to the point of picking out the exhaust for the car. and its finally almost done. going to be running true dual's but 2" pipe. since it will be easy to fab up and its only a mild street build anyway. with dual cherry bombs. my project is finally coming to an end woot
Old 06-09-2016, 02:23 AM
  #2344
Car: 1991 Firebird
Engine: 3.1L V6
Ed, all this talk of exhaust and coming to an end and no pictures? Rubbish! I'm interested to see it!
Old 06-09-2016, 02:33 AM
  #2345
Car: 1991 Firebird
Engine: 3.1L V6
Here is some pictures from the gathering. There were so many cars, it is impossible to take a single picture and get all of them in it at once.
Old 06-09-2016, 08:25 AM
  #2346
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Dual 2" seems on the tiny side?
what headers do you have? i have a dual 2 1/2 with h-pipe and cherry bombs i'd sell dirt cheap. it fits hooker shortys.
glad to hear its coming together and will be driving it soon.
Old 06-09-2016, 09:02 AM
  #2347
Car: 1989 Camaro RS
Engine: LH6
So I had an idea last night. And now I have 19x10 Vette wheels front and rear. I'll get a photo tonight.
Old 06-16-2016, 11:29 AM
  #2348
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
I love that color of your car. If I ever buy another thirdgen, that is the color I will be searching for.
Old 06-16-2016, 12:56 PM
  #2349
Car: 1989 Camaro RS
Engine: LH6
For sure. I love Jim's car. He just needs a V8. Lol.
Old 06-16-2016, 02:20 PM
  #2350
Good catch. I didn't even notice it was a RAII hood on a V6.
Quick Reply: Official Tampa, FL Area Thread
