[Sold] Manual pedals, Hydraulics, Hydraulic TOB
TGO Supporter/Moderator
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
These were on my '88 Formula, used for 1 season before I decided to go automatic. (track car).
Stock manual pedals
Stock master cylinder
Howe hydraulic throw out bearing
Braided line
This will work on a T5, T10, etc. Comes with different studs and spacers. Useful for push-clutch conversions on T56 transmissions, etc.
I was gonna keep this in case I ever converted the car back to a street car, but that isn't happening.
$250 plus shipping.
Stock manual pedals
Braided line
$250 plus shipping.
Car: 1983 Camaro Z28
Transmission: TKO 600
Axle/Gears: Strange S60
Re: Manual pedals, Hydraulics, Hydraulic TOB
Still for sale? Any idea if this would work with a Tremec TkO600? Not sure if the bolt pattern on the trans would be the same?
![](https://cimg9.ibsrv.net/gimg/www.thirdgen.org-vbulletin/2000x1504/howe_clutch_release_065026740b03a1f832e6e78d18612e4bfb760cc2.jpg)
But yeah, I still have it all.
Hmm, I'd also need to make sure it slips over my input shaft sleeve. Do you have a p/n for that? I can look into dimensions. And worst case for the stud I could use threaded rod and a nut, no? That just keeps it in that 30-degree window?
I suspect the stud is hardened, although I can't imagine that much force is trying to rotate it. It keeps it from rotating. I also have a bleeder hose, unlike the one in the picture, so you're not bleeding it IN the bell housing.
It's a good setup but my manual days are over. One of my Corvettes is manual and after 5 minutes in traffic I want to drive it off a bridge.
I think I am going to stick with a stock style setup for reliability and ease of repair if it does fail. Would you be willing to sell the pedal assembly by itself?
The only downside to the hydraulic tob is if it fails you have to yank the transmission. If you are running long tube headers however, it can't be beat (for clearance). It's a personal choice.
Like I said either way, my manual days are over. Even if my left leg worked, I can't shift as fast as I could when I was younger so It's not competitive.
Okay, I'll take the pedals then. PM me with your PayPal info or address is you want me to send a payment that way. I'd love that extra clearance, but as you said, everything is a give and take. I'm getting the car ready for longtubes now and I will have to clearance the slave cyl bracket I am sure. Man, I have everything working against me for a nice exhaust system. Only found two examples of nice headers that fit straight plugs. Stainless Works and Dyno Dons (obviously more mid length). I am still holding strong with the stick shift. I'm sure the day will come when I get sick of it. There is no argument that an auto is quicker, but I love that clutch pedal.
Pix as requested
Thanks. I should have a rod that connects the clutch pedal to the master cyl. right? I'll have to check if I got that with the master assy from another member.
82876 I believe. I had it on a T5, and it came with two studs if I recall. The bearing new is like $136, and then I've got the line, the adapter fittings to the stock master, the stock master with tank, and the remote bleeder line.
Pretty good deal I think for $150 + shipping.
Pedals are sold btw.
Everything sold, thanks
huberta5691
12-27-2015 08:18 PM
'91CamaroRS
Brakes
12-21-2015 07:17 AM
