If you have a Players Challenge Car, please post here. (RPO- A4U, 1LE or R7U)
#451
Car: 1988 IROC-Z Convertible
Engine: 408 Stroker Turbo, TPIS Mini Ram
Transmission: Magnum t-56
Axle/Gears: Ford 9" 3.55
Re: If you have a Players Challenge Car, please post here. (RPO- A4U, 1LE or R7U)
So today I sold the remainder of my players cars, memorabilia and engines! All gone to a new home for a fresh start! I've been into these cars since I was 15 and saw the Andy Mahood #13 Kokanee car on my paper route.
Not sure what the future holds but I'll still be around!
Here is a few last pics of the stuff...
#454
Car: 1989 IROC G92 LB9 MK6
Transmission: MK6
Axle/Gears: 3.45
Really cool! The stamp pad on my '91 1LE is V0123 CLJ and then vin derivative. Not many days between my engine and this one. Thanks
#455
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
I've never looked closely at the engine dates ... but I know they were all done in a batch. So it stands to reason they should be all within a week or so or else all identical to make inspections easier.
Mark.
Mark.
#456
Mike invited me to see the cars before they left. I would have loved to have these 2 cars in my collection. Here's a photo of our cars going neck to neck at Mosport
#458
Is the V number some sort of engine unit number or is the coding specific to the 1LE cars?
Two other 1LE numbers to add to the list:
1991 11/90 Built Z28 V1022CLJ
1991 03/91 Built Formula V0123CLJ
#459
#460
I special ordered mine thru AAFES while stationed in Europe. It is a G92 1LE without air. It is currently undergoing a transformation. I have a complete with wiring harness 1999 Z28 all aluminum engine with six speed. I have original engine in storage. Need more HP.
#461
#462
Transmission: MK6
Axle/Gears: 3.45
1991 1LE Trans Am built 3/90 V0123 CLJ.
#463
Here is the stamped pad on my 89 formula 350 vert.
Had to deck it, instructed the machine shop to save the VIN pad.
#464
Question for you road racing guys - is there an advantage to having a shorter wheel base on the car or for the rear axle to be closer to the front? When I was loading up my 90 at the shop yesterday I noticed the rear axle was far closer to the front of the opening than the back.
#465
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Is it the same on both sides? I could see if you have the Right one forward and the left one is standard it might want to turn one way better than the other... I remember seeing NASCAR sprint cars like this, they would dog track to get around the corner better. In this case the right being forward I would think (could be wrong) it would want to make the car turn better to the Right, which does not make sense. As most races are left...left ... left...left.
#466
The new addition...
#468
Its a 1989 Players car, Motomaster #1...Just 33,000 km needs bars and seat and decals. Ill set up and separate thread on it once its off the trailer and can get some photos.
#470
Engine: TPI(s)
It sure looks clean. Being the Motomaster #1 car, it was a front runner in many of the races. Took some 1st places as I recall. Should have lots of video and pics of this car in action!
#471
Dang...another one found! Great to see.
#472
Just picked up this 1990 built #58 car. Still has the original Davenport cage.
Unfortunately going to let the white (below) #33 car go.
#473
This pic is from 2004 I believe
#474
Yes that's it, kinda hard not to recognize the paint scheme. Lol!
#475
Cool line up of players cars! Nice pic!
#476
Engine: TPI(s)
Cool find.
Why that one over the white one? What is better? Curious on the story.
Mark.
Mark.
#477
It would be cool to re-sticker that puppy up and make it look like it did when racing.
John
John
#478
Hey....new kid here. I was banging around the magic interweb looking for info on my Players car and found this thread. So....about 10 years ago I brought a 1991 Trans Am R7U down from the great white north to Wisconsin. 23,000k when I bought it and the only mod I could find was a radio had been added. I've always had a couple questions and perhaps this is the place to get them answered...
-How can you tell if it was raced? Be fun to track down some pics of it on track if they exist.
-Any idea on how these are doing value wise. I bought it as a "hummm, might be worth something someday". Are they?
-I've tracked it at Road America a couple of times, which lead to replaced sway bar bushings and upgraded pads. And did have to pull injectors a while back (did not try to restore any 'lost' yellow paint). Other than that, it looks to me like it's factory stock...I'm not sure this car was ever tracked in anger (see item 1 above).
Overall, just interested in adding to my knowledge of this car. Love having it in the stable (it's one of 4 TA's in the garage)...
#479
Engine: TPI(s)
If the car was raced, it will have signs of a rollcage being installed. Check under the floor boards for 4 holes. As well, in the back by the lower control arm where it meets the body. Usually the carpet will be cut ... but often race teams may swap interiors from year to year, so your carpet may be intact.
You can check the computer and see if the race PROM is there. Often, you can find one in the later cars as when the racing ended, the PROMS were still in those cars. The early years are tough to find.
You can send me your vin via PM and I can check and see if I've seen it before. I've been at this for a long while now.
As to value ... tough to say yet. The market for these cars is still up and coming. What I see is it has to wait a bit until the age group that "remembers" these cars gets older and has spare money to spend to recapture their youth so to speak.
I took my 1989 1LE Camaro out to a show yesterday. While not a Players car, it has Players history. It was interesting to watch and see who stopped by and read the info sheet. Usually mid to late 40's guys.
Certainly having all the right documentation will be key.
Mark.
#480
Engine: TPI(s)
I posted up some old race footage and some footage from GM Motorsports. I'm new to using youtube but gave it a whirl. I had to mute some of the sound in one so it would not say copyright claim. Again ... pretty new to using youtube. My hope was that this stuff is pretty old and the tapes I have are pre-TV as the original screening stuff. So they were not aired on TV in this version.
Here are a couple.
The first one is the 1989 recap. Due to some music in the background I had to mute in parts. IT makes for a boring watch, but there is lots of CAR action. Especially at 6 min onward. And then around 8:15, you can listen to the cars. Great footage.
This one is the GM Marketing tape to try and get more companies to advertize with them. Some good footage here and there. Lots of talk.
As I have time to upload the original footage, I will. Some of TV aired ones I don't think I can put on youtube.
Mark.
Here are a couple.
Mark.
#481
Engine: TPI(s)
A couple more ...
1987 Recap. Good footage from 1987.
A 1989/1990 Recap. More footage. Good watch.
Mark.
Mark.
#482
Thanks for sharing the videos.
If you own a Player's Challenge car, keep them nice so I can buy them from you in the future.
#483
Engine: TPI(s)
One more. A 1988 Marketing video.
I'll stop posting up links here. I think I've covered off enough for people to appreciate. I'll continue to digitize more ... just go to the Channel thing in youtube to keep up to date.
I have race footage as well ... but they are long. Unsure how best to upload those. IT would be best to create a 10 minute short.
If anyone is looking for a particular year or car, let me know and I can check what I have.
Mark.
Mark.
#484
This is awesome, Mark! Keep them coming. Do you have the '91 & '92 series?
Thanks.
Benny
Thanks.
Benny
https://youtu.be/SxrsWYJx7fU
Mark.
Mark.
#485
Engine: TPI(s)
As far as marketing tapes ... I uploaded the 1991 marketing tape which would have been the last one they used. I think I titled it as 1990 1991 but really it was for the 1992 seasons. Date on the tape was 10/31/1991.
Mark.
#486
Post 'em up please! These are cool!
What some people do is cut the full race into 3 segments, titling each video "Race ... Segment 1" and then link to Segment 2 when it's over. That way you can watch the full race, but the uploading is manageable.
#487
Engine: TPI(s)
Ok ... A couple more.
Richard Dean Anderson (Macguyver) Interview.
AND a Blooper real ....
Mark.
Mark.
#488
Car: 91' Z28 1LE R7U
Engine: 350 ZZ6
Transmission: 6 Speed T56 Magnum
Axle/Gears: 3:42 posi G80/GU6
Videos!!!!!! I know what i'm doing now for next few minutes. See if i can find my #17
#489
Engine: 350 ZZ6
in the promo
#490
Engine: TPI(s)
I have 1989, 1990, and 1992 races. Maybe some 91's ... I have not found those yet. Slowly I will upload ... VHS is slow!
#491
#492
Engine: 350 ZZ6
Ya you bet, Fort No Where. lol I bought the car back in 93. Probably never get rid of it. Puttin brand new ZZ6 350 and 6 speed in it! Motor and trans should be here in 2 weeks.
#493
Engine: 350 ZZ6
Cool! Mine raced in the 90' season also so hopefully see it. Geez I forgot how goofy the chicks wore their hair back then! Felt like I was 17 again watching those vids.
#494
Engine: TPI(s)
Mark.
#496
#498
I due tend to forget that the '90 model year was a short one. Thanks for the reminder.
#499
Engine: TPI(s)
Yup some footage from 1990 which has the newer nose. The marketing tapes have a mixed bag of footage. Still cool none the less!
I'm adding more 1989 races. Then I will get to the 1990. Then maybe the 1992 ones. Its such a slooooooow process.
Mark.
Mark.
#500
Engine: TPI(s)
Ok ... I'm done loading Videos on the Players Challenge Series Channel. 51 Videos so far. Great coverage of the 92 season - I think all races. Good coverage of the 89/90 seasons. Some of the 91. And some of the 86-88 seasons.
There is some fantastic racing to watch. The east/west shootouts are some of the best to watch. All of those cars have bumps and bruises.
If I can find races additional footage, I will upload.
If anyone wants a physical copy of the races, I can put on USB.
Enjoy!
https://www.youtube.com/channel/UCay...wMpRlxGBYrrpcQ
Enjoy!
