How to remove CENTER CAPS
Old 04-14-2016, 01:15 PM
On Probation
sonjaab's Avatar
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
My center caps ar looking pretty shabby and showing their gray
base color. Want to paint them matte black.
How do you remove them?
Old 04-14-2016, 03:35 PM
Re: How to remove CENTER CAPS
I'd pull the wheel, and use a large wooden dowel or block and a soft rubber mallet to knock the cap loose from the back side.
If you try to tilt the cap to pop it loose, you'll likely break any of the alignment pegs that arent already broken.
Old 04-14-2016, 09:21 PM
section 8's Avatar
Car: 1988 Camaro iroc-z
Engine: 350 stock engine
Transmission: stock automatic
Axle/Gears: stock
Mine just popped off when I pried on them with a flat head screw driver.
Old 04-14-2016, 10:32 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
There is a metal ring with a spring on the inside of the wheel pushing plastic fingers out to hold it on. I pull mine off by giving them a little twist while pulling out. Or take the wheel off and tap them out with a rubber mallet and a long extension.
Old 04-15-2016, 01:10 AM
Camaro86IrocZ's Avatar
Car: '86 Iroc Z & '91 RS
Engine: 305 TPI & 305 Qjet - Future LC9
If you have little nubs on em that go into the wheel like OEM they won't be there after trying this method.. Go and take the wheel off and tap them out with a rubber mallet and a long extension as mentioned.. Or find a new repro set on ebay..
Old 04-16-2016, 06:38 AM
On Probation
sonjaab's Avatar
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Thanks guys.............
A cold spring has finally sprung here in frosty NY so its time to get
the Z out of the garage and spruced up for summer crusin'
Got them off with a little gentle wack with a mallet.
A couple of them were missing the alignment pins and badly cracked.
I just bound the cracked ones together (to close the crack gaps) and whipped
out the fuser stuff my bud uses at the body shop to fill and stop the cracks.
Sanded the fuser smooth and preped and painted them matte black.
I suppose I still have to mask off the black painted area around the lug nuts
and spray them too.
Also the air intakes in the lower nose/bumper cover need a shot of paint too.
Pics soon............
Old 04-16-2016, 03:34 PM
On Probation
sonjaab's Avatar
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
cracked wheel cap
finished cap
Still need to mask off the lug nut area and spray that too
Old 04-28-2016, 04:20 PM
On Probation
sonjaab's Avatar
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Guys..............
SCORED a NOS set of 4 off fleabay for $30 bucks !
someone972
Wheels and Tires
04-14-2016 09:39 AM
Gran Torino
04-14-2016 09:10 AM
gt4373
04-13-2016 11:33 PM
norcalz28
Northern California
04-13-2016 11:47 AM
David Casto
04-10-2016 03:38 PM
Quick Reply: How to remove CENTER CAPS
