Strange map replacing burnout smiley.
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
This is really strange. I'm seeing a map in the place of the burnout smiley. Another member (Brisk) is seeing the smiley.
I'm using firefox and he is using IE. Not sure what is up, but here is a screenshot:
So at this URL, you see a map instead of a smiley?
https://www.thirdgen.org/forums/imag...es/burnout.gif
I'm using the same setup as you, Win XP with FireFox 1.5 (as you stated in another thread) and I do not (nor did not) have this issue.
Edit: Can you give a link to a thread/post where this is happening?
Not anymore, he had it as his sig, but I asked if he was showing his house and that it wouldn't be a good idea. He removed it to keep people that were seeing it as a problem.
I cleared the cache and don't see it anymore. Must have been me.
Looking at his signature, he is having his main image hosted elsewhere. I can only guess he was hot linking the burnout smiley, and that possibly where it was hosted, was changed. Perhaps he was just seeing a cached version.
As you probably well know, if that was the case, it wouldn't be a TGO issue and nothing TGO could do.
red90IROCls1
08-25-2015 06:56 AM
novaderrik
08-10-2015 12:44 PM
