100 shot safe on a (basically) Stock 355?
Ok, I know nothing about nitrous, and I want to put a 100 shot on a TBI 350. I plan on using a Jacobs nitrous mastermind or a NOS TPS progressive controller to apply the juice. Does this sound reasonable for a basically stock 2 bolt main 355? I shouldnt be spinning it past 4300 rpms, maybe 4500 at the most. Will this hold together, or am I looking for trouble?
Dude yes you will be fine, make sure you drop a couple degrees on your plugs, and bump your timing. I would say do 150 but Im not to sure the TB would like it. Dont waste your money on that mastermind, you wont need it for a 100 shot. If you are going to get a progressive computer go with the NX maximizer, I had it and it was great!!
