Can I run an ATI P600B for tpi on carb?
I have been thinking about selling my tpi stuff and going carb to get some real numbers out of putting on fastburn heads and an lt4 HOT cam kit on my ZZ4. This also drops compression ratio. Since I already have a P600B for tpi and a carb hat, would I be able to use it on a carb application? If so, what all would I need other than the carb hat, anything?
1 Post
Car: 1992 B4C 1LE
I also recommend a boost referenced return style fuel press regulator that is capable of producing the regular fuel pressure you need + the boost pressure + about 5-10 psi.
theshackle
03-05-2017 06:37 PM
86IROC112
08-17-2015 02:00 PM
Sanjay
08-12-2015 03:41 PM
