Procharger F1R
Procharger F1R
Anyone know when the new F1R will be released to the public? I am under the understanding that it is a small frame charger, 4" inlet, 3" outlet, and can flow 2000cfm!!! That is unbelievable!!! Me must buy one now
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
First batch was out this February
i saw one installed on a Mustang at ASSC a few weeks ago
it is PIMP
someone else...cough...cough....i know around somewhere has one but i cant say who because it is a secret
it is PIMP
![Wink](https://www.thirdgen.org/forums/images/smilies/wink.gif)
So, they are out??? Does this someone have a thirdgen? This should be interesting, that s/c has the potential to make a ton of HP! With the cars that I have seen poping up on this board, it should be an interesting year! We need a thirdgen to take that "Fastest Stock Suspended F-Body" title.
Originally posted by TheButcher
So, they are out???
sorta, just a few
dont know for sure![Wink](https://www.thirdgen.org/forums/images/smilies/wink.gif)
yup
So, they are out???
sorta, just a few
dont know for sure
yup
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
The F1R sounds like a pretty stout little unit :hail:
But we have not seen one on the dyno as of yet, so lets not jump to conclusions
You never know. We may just see one being tested on a third gen this season :lala:
Car: 1991 Z28
Ok, enough tongue in check humor here.
What I want to know is are the stats listed above correct or
Will this F1R be offered in a kit for third gens or will it bolt to the D1 brackets or
Any info you can give would be
Thanks.
![bs](https://www.thirdgen.org/forums/images/smilies/bs.gif)
![Confused](https://www.thirdgen.org/forums/images/smilies/confused.gif)
![Cool](https://www.thirdgen.org/forums/images/smilies/cool.gif)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
I would be very interested in knowledge on that blower. Ive been emailing all kinds of sources for info on race kits for a third gen and cant get anyone to answer. I'm going to buy something soon and I guess that the people I have emailed dont want my money. My car is a turd with this new motor only having 8 to 1 and big *** 227 afr's. Need boost!
Call Larry @ ASSC in Lake Bluff, IL
i'm pretty sure he is the only one that has had the first few F1R units as i stated before i saw one on a stang there
he can answer your questions and order you one
1 Post
Car: 1992 B4C 1LE
I talked to my account manager the other day at procharger and he seemed pretty sure that the F1sc will be sized like the D1sc and use it's brackets without any of the major surgery required with the D1r D1x or larger. Its main power lies within its revised impeller design and mainly it's gearcase (from 4.10 to 5.10+) step up ratio. Like I always say, with bolt on blower kits that can make more boost and power than most people could ever use, why are people drooling over the possibility of a non-existent turbo kit?
It's true the F1 will work with existing D1 brackets. The F1R is slightly larger and needs to have a custom bracket. Besides the fact that it's larger in physical size, it's also a peaky blower and will not work well with a stock TPI motor.
I am still waiting to see dyno results from either one of the F1's.
Here is a little taste of how potant a new F series blower can be. In this case, it's the new F2 which is the next step up from the F1R. The point being that it outperforms the Novi 2000 by far![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
New F2 dyno results
New F2 dyno results
1 Post
Car: 89 Formula
Engine: Nada - v4.0
Transmission: Nada - v3.0
Axle/Gears: Nada - v3.0
If ya yell REALLY REALLY loud....
Originally posted by JeffT
Hey, 89, do you have a phone number or should I just try yelling out the window???
![Embarrassment](https://www.thirdgen.org/forums/images/smilies/redface.gif)
Chris
Spend to much $$$ with ASSC MOTORSPORTS
ati, big, blower, blowers, car, d1x, f1r, fastest, gen, mustang, power, procharged, procharger, procuarger, sale
