BBC Turbo Headers
BBC Turbo Headers
I am thinking of swapping out my procharger for a single turbo this winter. Does anyone know of any turbo headers that will fit a third gen camaro with a BBC? Again thinking of one large single but might consider twins.
RoboYogi (10-02-2021)
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Re: BBC Turbo Headers
Eh i dont think there are any that are a certain fit. There were some universal up and forward styles i think, but depends on your valve covers and master cylinder/booster location and motor plate. Stainless works has some. Ebay has some cheaper ones
Car: 89 Iroc-z
Transmission: TH400
I had a sbc when they were up front and i made those too but there are more sbc headers out now.
bbc im not totally sure
Car: 89 Iroc-z
Transmission: TH400
Theres a few ebay type ones out there google search bbc turbo headers. Some up and forward but idk how much space there will be for the fender well area and brake components and steering shaft stuff
it is very tight over there
i am in the same boat. Would like to run a turbo 555.
Has anyone looked at these:
https://www.stainlessheaders.com/pro..._Turbo_Header/
Car: 1985 camaro
Engine: 496
nice car!
IgorT (10-03-2021)
You might have better luck looking for Cast-Iron Exhaust-Manifolds... if you are not looking to fabricate anything.
Also much of the Steel Headers that are sold for Turbocharger use, are built with the thin-wall tubing that a standard Header would use.
That material is too thin... a good amount of heat escapes, when you want as much as possible going to the Turbocharger.
The ideal Header for Turbocharger use...
would be 0.120" wall Stainless-Steel with the inside ceramic-coated, and the outside Thermal-Wrapped.
I do not expect anyone to do this other than professionals...
But the closer to something like this, the better.
Car: 89 Iroc-z
Transmission: TH400
That be one heavy header lol but durable i guess.
But regular tubing does last a fair amount of time. Some crack over time and just need to repair them. I like mild steel myself, lasts for years of normal abuse. Coating helps. but expect that it may be a wear item just like anything else and need replaced every several to 5+ years depending how much use. To be honest anyone doing a turbo bbc likely isnt using it like a daily driver street car lol But i had like 4-5 years of couple thousand miles a year driving and multiple passes in my sbc turbo deal and lasted fine. My bbc turbo car headers have 2 years on them but much limited use duty so far with the other issues i have had
Car: 89 Iroc-z
Transmission: TH400
Yes! Been thru some iterations of things to get it working more efficiently. Went from 1.32 a/r housing to 1.15 and picked up a touch more spool speed, but still not fast enough. Track has been garbage for a radial car and im still tuning suspension but it just doesnt boost fast enough.
so ordered some vband 1.0 stainless housings to try. Got them on but also lost the transmission so just got trans and converter back. Havent gotten them in yet to test. Went from a stock 2.48/1.48 gear ratio th400 to 2.10/1.41 setup so should help the leave abit. I want it to leave on 5 lbs atleast and come in faster than it does now. I can leave on 3-4 and it wont reach 23 lbs til start of 2nd gear... not that the track will hold it but i want the capability there so i can control it with the AMS controller or holley Boost if i go that way
3rdgendragcar (01-25-2023)
Car: 89 Iroc-z
Transmission: TH400
Yes i made them and they are basically like any other long tube header for our cars since im remote mount turbo
