How much boost can a stock 350 take
Without motor problems, not counting the tranny.
I am thinking about a 12 psi ATI with the 3core intercooler.
Would forged pistons be enough or would a forged crank and/or rods be necessary?
1 Post
Car: 1992 B4C 1LE
we pound out 10 second quarter milers with stock crank, stock rod, trw forged piston motors regularly on the "juice" or "noss" (if you are a *****) your blower should be much gentler at 12 # even. but a cast piston motor 10# is about it for safety Im sure others have done 12# without problem but it really depends on a few factors that you will need to watch closely; compression, timing, A/F ratio, and fuel quality. good luckhttps://www.thirdgen.org/rides/index...ew&rideid=3980
NinjaNife
08-23-2015 11:49 AM
