T76 on stock 350 TPI 5 spd
#51
Car: '88 Formula, '95 Formula
Engine: LC9 , LT1
Transmission: TKX , 4L60E
Axle/Gears: 3.50 9" , 3.23 10bolt
Re: T76 on stock 350 TPI 5 spd
-- Joe
#52
Engine: LC9 , LT1
From all the pm's and on this thread with Cheesehomer was there any mention of having any parts at all yet for the turbo build.If he had a full kit and just needed a turbo I doubt this thread would be this long to pick something..anything to get the car up and running with some boost on a budget turbo.
-- Joe
#53
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Was this the setup you did the L98 single turbo kit build thread?
#54
Engine: LC9 , LT1
No, that was the chinese BBS knock off. That kit actually worked well, but had plug issues with my AFR heads (raised exhaust port).
That kit is on my buddies L98 (1988 GTA).
This kit was entitled something like "Single turbo with cast manifolds" basically, I copied another member's design but I used LT1 fbody manifolds rather than TPI manifolds. They have larger runners and have better flow.
Crossover goes in front of the accessory drive, WG open to atmosphere and 3" downpipe.
If I ever do another turbo thridgen, I'll just use the cast banks manifolds (twin). Much tighter packaging, more professional looking.
-- Joe
-- Joe
kenbob (10-11-2020)
#55
Car: 89 Iroc-z
Transmission: TH400
Banks are so much money tho
Just wondering if a t4 small cover 70mm would clear the hood in a thirdgen with that kit.
A stock 305 will spool that .96 ar t70 on3 very quick if my remote turbo does spool fairly decent. 350 even quicker
#56
Car: 1987 Iroc Vert
Transmission: 5 spd
I also noticed a member has a set of 55lbs injectors on sale here. Would that be a good set to start with on the stock 305 and can I use them if I go to a stock 350 later ??
https://www.thirdgen.org/forums/engi...injectors.html
OK...now back to the question ....
What about these injectors ?????
#57
Engine: LC9 , LT1
-- Joe
#58
Car: 1987 Iroc Vert
Transmission: 5 spd
WHAT...?????? I thought we went through this already and a T70 on a 305/350 5 spd would be great..... ??? ..a t76 would spool too slow ..?
#59
Engine: LC9 , LT1
Also, I'd err on the side of caution using big injectors on an EBL. An EBL is really just a stock ECM with some flash memory and extra I/O, and the injector drivers are all hardware. You have zero control over the injector firing strategy, meaning if it's too rich at idle and part throttle you won't be able to "tune it out" by changing the firing events.
-- Joe
#60
Car: 89 Iroc-z
Transmission: TH400
The 76 would spool a tad slower but the turbine is same as the 70. So its close to same only difference is overcoming the inertia of the larger wheel
Run either but the 70 is more than enough to break the motor
55's are more than enough injector. They will work once well tuned. What brand?
Edit: accel lol i rather see you get lucas 42's or siemens 60
#61
Car: check
Engine: check
Transmission: check
For the best and easiest tuning get injectors which the compensation data exists. Ford Motorsport and DeatschWerks both publish this data for the injectors they sell. A 47#/hr injector will support about 660 HP, so the Ford Racing M-9593-LU47 is a good choice for that level of HP. Note that this is a long injector but has the USCAR (US car) type connector.
Stock TPI uses the Jetronic/Minitimer connector. The up side is that compensation data is available for them.
This was just an example, there are other injectors available.
RBob.
#62
Engine: LC9 , LT1
I'd say no to the Accel injectors, too much bad history along with no real compensation data. As for sizing them, get ones that cover the required HP level, but not too much more flow. A 55#/hr injector (8 of them) will support close to 800 HP (flywheel).
RBob.
RBob.
-- Joe
#63
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Easy enough to calibrate injectors. Put ECM in test mode with a forced injector PW. Mess with open and/or close times to see when the squirt.
Best bang for the buck is P&H injectors if the ECM supports them. Can find 55#/hr sets for $100.
#64
Engine: 3xx ci tubo
On the 305, with a small turbine you can get into a case where boost comes in too early and it will surge in the 0-5psi area. But that is on a stock turd 305 tpi or lesser 305 (aka TBI).
#65
Engine: LC9 , LT1
Could you post the eqn used to get 800HP with 55#/hr injectors and turbo? I come up with only 680 flywheel hp.
800hp, .90 duty cycle, and .50 bsfc I come up with 55.8 lb /hr.
I don't think he's going to have enough intercooler to pull off a .50 BSFC..
-- Joe
#66
Car: check
Engine: check
Transmission: check
-- Joe
-- Joe
That was more of an example then anything else, just to put the injector sizing into perspective. At 10 - 12 psi on a stock 350 it isn't going to be anywhere near 800 HP. The '87 L98 is rated at 225 HP at 4400 RPM (from this site). Even if pushed to 15 psi and the HP doubles to 450 HP:
450 HP @ .55 BSFC @ 85% DC:
450 * .55 / .85 = 291.2 #/hr fuel requirement
291 / 8 injectors = 36.4 #/hr
These flow at 34 #/hr @ 39.15 psi fuel pressure, more at 43.5 psi:
M-9593-LU34K 34 lbs./hr. 11-18 ohms L Jetronic/Minitimer Black
M-9593-LU34A 34 lbs./hr. 11-18 ohms L USCAR M-14464-A8 Black
Same injector different connectors, have compensation data for them.
RBob.
Last edited by RBob; 12-02-2015 at 03:42 PM. Reason: Corrected inj calc for a 350, not a 305
#67
Engine: LC9 , LT1
With the car being an '87 MAF setup it is easiest to go with the EBL Flash ECM and a 2-bar MAP sensor. With the optional 4-Injector Upgrade it is capable of running 8 low impedance port injectors. We don't offer this on the EBL P4 system as the '7749 ECMs are hard to come by (two inj drivers). The ECM we use only has a single injector driver.
35.83 lb/hr right?
-- Joe
#69
Car: check
Engine: check
Transmission: check
cheesehomer, more info on the injectors I listed above (from their web site):
M-9593-LU34A: 34 lb/hr, 4-hole, high-impedance fuel injector
Original equipment on 2011-2014 5.0L Mustang and 2012-2013 Boss 302
Good possibility you can pick up a used set for a good price.
RBob.
RBob.
#70
Car: 1987 Iroc Vert
Transmission: 5 spd
Hello RBob
I want to thank you and everyone else for the great information.
I did pick up a used Dynamic EBL with port mods "multi ports", it also came with a TT1 control box and 02 sensor
#71
Engine: LC9 , LT1
Looks like you are rocking and rolling!
I think Street Lethal mentioned in the spring that RBob added wastegate control to the EBL Flash, so if you pick up a WG solenoid you can dial in a boost curve.
-- Joe
#72
Car: 1987 Iroc Vert
Transmission: 5 spd
I don't know about Rock'in or rolling, still need Turbo, intercooler with piping , injectors and fuel pump. I try to check the local classifieds daily, but looks like I will have to bite the bullet and purchase new from the USA at .30 cents on the dollar....... !!!! lol,,
#73
Car: 240sx
Engine: whatever works
Transmission: 4l80e this year
Axle/Gears: 3.512
Hey guys, just a theory question,
What would an OEM TPI 92' engine produce with 25psi of boost? If the OEM camshaft was used, (with a good enough spring), and pretending the oem headgasket was up to the challenge, and that the pistons would last at least one run to get a dyno from it.
My guess is something like
15psi 450rwhp (480bhp)
20psi 490rwhp (520bhp)
25psi 530rwhp (560bhp)
mainly due to cam/head limiting of course. thoughts?
#74
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
I think the TPI intake restriction is going to make the majority of the boost and the combustion chamber is going to net much less benefit. Peak power is at a low rpm around 3800-4000 and especially with stock compression is very timing sensitive thus prone to detonation. I'd guess you'd be 300-330 rwhp at 15 psi based on my experience. That's wheel hp so probably high 300s at the crank. Torque will be impressive though. I was putting down 378 rwtq at 10 psi but only 272 rwhp.
Performance will be decent - 13 psi on my stock 87 got me almost 7.89 @ 87.72 in the 1/8 (12.2x 1/4). Even though the theory is running another 10psi should make a significant difference, I think the restrictive nature of the tpi intake makes a significant impact on that improvement.
#75
Car: 240sx
Axle/Gears: 3.512
#76
Car: 1987 Iroc Vert
Transmission: 5 spd
RBob.
RBob.
Wow, these 34lb injectors are discontinued and where very difficult to find, but I was able to find a person in Calgary, Canada who had a set new never used.
#77
Car: 1987 Iroc Vert
Transmission: 5 spd
Then I was able to find a On3 T70mm in a local classified and picked it up today. The only problem was the ar on the exhaust side is .68 instead of what I wanted a .96 , I figure if It spools to quick I can change the housing.
Boy, it's a lot smaller than I though it would be for a V8 engine.
What ya think..??? Will it spool to quick...????
#78
Car: 89 Iroc-z
Transmission: TH400
My 3400-ish lb 91 z went 110 mph on 9-10 psi. 305 tpi all stock. Thats likely 280 whp give or take. My 3650 lb ls1 ta went 107-108 on 320-330 whp.
#79
Car: 89 Iroc-z
Transmission: TH400
That cover looks different than my on3 t70. It will def spool very fast lol my remote setup spools well and you are doing a front mount
#81
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:42
Fast as in it will be a snappy boost building car.Ill tell you right now with the on3 before you actually start the motor.Take the inlet housing off and reseal it with red permatex or equivalent.They are known for the original seals to leak and mine certainly did out of the box brand new and I found out the hard way.Glad to see you finally got a turbo picked up.Hope the car is put together before spring and maybe we can line up for some street/strip runs and if your down for some oldschool armdrop races there is a event 3 times a year in Picton where easily 2-300 cars run what a brung at a old airfield.Makes for a great weekend.
#83
Car: check
Engine: check
Transmission: check
We have working wastegate control code in the EBL SFI-6 system. It has been successfully tested on a number of turbo cars.
There are no plans to use this code in the EBL Flash ECM.
RBob.
RBob.
#84
Car: 1987 Iroc Vert
Transmission: 5 spd
That suck's big time....Gotta ask though...how hard would it be to add that code or program to my Flash...???
Would be a great feature with the 5spd to control boost by gear
#85
Engine: LC9 , LT1
I suppose he could create a target boost @ rpm vs mph.
Don't think much demand exists for that. Most people just want a flat boost curve and some overboost protection.
Most aftermarket is solenoid dutycycle @ tps vs rpm.
The boost solenoid is a frequency driven vac valve.
If you are dead set on electronic boost control, you should talk to Orr. He's running an LSx truck PCM with custom software which is supposedly pretty fantastic. Or you can just spring the wastegate appropriately and keep what you've already paid for
-- Joe
-- Joe
#87
Engine: LC9 , LT1
#89
Engine: LC9 , LT1
#90
Originally Posted by cheesehomer
Street or RBob can you give me more information on that or a link to some information.
Thanks George
Thanks George
#91
Engine: LC9 , LT1
George, it wasn't boost control that I mentioned awhile back w/the EBL-P4 , it was alky control. Controlling boost though is essentially very easy, with a number of different ways to accomplish it. I myself invested in a standalone EBC not too long ago, but controlling it through your ECM should not pose a problem. When it was mentioned that it isn't being planned to add boost control, I believe that is more in terms of the XDF itself, meaning there won't be a designated area specifically for that command, but that doesn't mean you cannot control it through a different avenue with Tuner Pro...
I think George should just spring his WG for now. It's his first build.
-- Joe
#92
Originally Posted by anesthes
The GM WG solenoid is frequency based, right? What pin on the EBL would you use to control it?
-- Joe
-- Joe
Sanjay
08-12-2015 03:41 PM
