Single turbo 352 iroc 1000hp or bust the grand finale
Old 07-22-2016, 01:06 PM
  #1251
TGO - 10 Year Member
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Re: Single turbo 352 iroc 1000hp or bust the grand finale
You need a clean room proper paint booth
Old 07-22-2016, 01:08 PM
  #1252
TGO Supporter/Moderator
anesthes's Avatar
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, LT1
Transmission: TKX, 4L60E
Axle/Gears: 3.42, 3.23
Yup. Maybe when I build the new shop. Been thinking about knocking the barn down and doing a 60x40.
-- Joe
Old 07-22-2016, 01:09 PM
  #1253
project89's Avatar
Originally Posted by anesthes
I don't know how you get such good paint jobs with all that dust out there. I blew my shop out with a leaf blower, tarped the walls and everything, and STILL got dirt in my paint.
-- Joe
the shop is presurized with filtered air , so open up a window or door on the side of the shop, and all the dirt/dust overspray goes away form the car and out of the shop , and no dust or dirt can be blown by wind into the shop
since the shop is also were my bitcoin farm is i have over 16kcfm of air being brought into the shop by the intake fans
Old 07-22-2016, 01:14 PM
  #1254
project89's Avatar
m having trouble picking a new color , i dont want the same color i have now .
im thinking about
emerald metalic green
chamelon
candy apple blue
candy apple red
or gunmetal
copper pearl which is close to the gm sunburnt orange is also one final choice
Old 07-22-2016, 01:28 PM
  #1255
anesthes's Avatar
Engine: LC9, LT1
im thinking about
chamelon
candy apple blue
candy apple red
or gunmetal
What is the defect with the existing paint?
-- Joe
Old 07-22-2016, 02:31 PM
  #1256
Street Lethal's Avatar
The two of you painting in a barn/shop, sigh lol. Come on now.
Don't you guys believe in clear coating/wet sanding after painting in a dust/hay storm lol?
Old 07-22-2016, 02:54 PM
  #1257
project89's Avatar
-- Joe
the clear is getting soft in the heat and allowing dirt to get embeded in it when it cools down at night the clear gets hard again
Old 07-22-2016, 02:58 PM
  #1258
anesthes's Avatar
Engine: LC9, LT1
Clear coating and wet sanding won't do much for stuff falling into the paint.
I do cheesecloth it between color coats, but usually crap falls in the first layer of clear.
At least I don't use a paint roller and rustoleum like most forum members.
-- Joe
Old 07-22-2016, 03:34 PM
  #1259
lol im not crazy enough to repaint it if the current paint was good
I thought you didn't clear it? So you did then, good. Make sure you clear it again next time around. What are you out for, a show car? I raced my GTA on the highway so much last year, the front bumper has so many scratches in the paint that I am not going to bother doing any show paint anymore because its not worth the effort with a driver, just Black, clear and polish. My cousin did give me an idea though with the paint to have some fun with, should be one hell of a good time on the highway if I decide to go through with it lol. Just need to drop another eight hundred on the 91-92 aero wing, can't find any used, so a new one from Hawks it is...
Old 07-22-2016, 04:00 PM
  #1260
project89's Avatar
yeah the paint i used was bc/cc something wrong with the clear though
ill prolly keep it simple and go with a simple metalic this time around instead of a color changing pearl
Old 07-22-2016, 04:14 PM
  #1261
I might actually go B4C, but with a GTA lol...
Old 07-22-2016, 08:30 PM
  #1262
project89's Avatar
since i have to do this again im going to make sure the damn thing stands out
Old 07-23-2016, 10:18 AM
  #1263
Drac0nic's Avatar
The relay method to me is just extra stuff to fail. But 99.9% of people find that page in the documentation and do it that way.
What did you use for hardware? A microsquirt ?
-- Joe
Done both, and both work. The 7747 ECU actually has a purple wire that goes to the starter wire from the ECU that's usable if you're retrofitting a stock harness. Pretty sure that's what the TBI adapter board I have does.
For the Megashift it was a GPIO board. I don't think it was the assembly as much as the design of the circuit. There was some sort of parasitic harmonic that was being amplified. Lance seems to say there are "no issues" with it although I certainly got banned for asking about it.
Originally Posted by junkcltr
I think the hardware work arounds are what make the docs so difficult. For instance, the try do the resistor pack hack (bad turn on/off times) or PWM for peak and hold injectors. Confuses everyone.
You have to be attentive to detail to read the Megasquirt documentation and build it out right. The Megashift documentation was just flat out wrong at spots, where I was having to change things so that it would work.
They try to add in jumper wires for different trigger source for crank and cams. Confuses everyone.
The hardware grounding scheme was suspect from the get go and caused a lot of problems. I think this is one of the biggest problems people have even today. I don't think it was thought out well enough for large coils with high dI/dT rates. Puts noise on all the inputs and "random" trigger errors, input errors, resets.
The VR ckt is always been flaky. Simple MAX9924-27 part would fix all that but I think they don't do it due to sourcing the part.
Yeah, I could see the jumpers causing issues but IMO they are at some level a necessary evil. A basic table with everything summarized would make things a lot easier IMO. Just go through and do "choose your own ignition" based on the table entries and perhaps a pictoral diagram of the jumpers for each board/type that's standard.
Noise is always a spectre in electronics, and has to be carefully managed. I could see the fact that some of the jumpers above
http://www.theturboforums.com/thread...uild-for-4L80E
www.theturboforums.com/threads/371628-Question-for-the-electrical-sorts?highlight=megashift
Quite frankly if I didn't have an early 4L80E which uses the different PWM frequency I would have been very inclined to sell the mess and go to an 0411 with HP Tuners.
Old 07-24-2016, 05:48 AM
  #1264
Up in the air w/that color, but it's definitely unique.
Old 07-24-2016, 07:31 AM
  #1265
anesthes's Avatar
Engine: LC9, LT1
Looks like the 2008+ synergy green they painted the camaro's with.
-- Joe
Old 07-24-2016, 08:43 AM
  #1266
It does, but I meant unique for a third gen. That color started becoming popular when Tokyo Drift came out in 2006 w/the incredible hulk themed Touran...
Old 07-24-2016, 12:06 PM
  #1267
DIGGLER's Avatar
lol
Old 07-24-2016, 01:03 PM
  #1268
I smell a sponsor lol...
Originally Posted by DIGGLER
lol
Old 07-24-2016, 01:59 PM
  #1269
project89's Avatar
lmao as much as i drink those things that would be awesome
Old 07-27-2016, 02:22 PM
  #1270
project89's Avatar
so i was browsing ksl and came across this
01 gsx-r
seriously considering going to pick it up , though my friends are seriously trying to talk me out of it
Old 07-27-2016, 02:32 PM
  #1271
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Dont bother with the GSX-R. You'll get it and immediately feel like your car will never be as much fun or as fast and its accurate. Riding my turbo'd 90 GSX 600 before crashing it makes most cars feel slow.
Old 07-27-2016, 02:36 PM
  #1272
project89's Avatar
i was kind of thinking that myself , but damn i miss having a street bike , i live in the perfect area for having a nice streetbike, i dont think i would enjoy a cruiser enough to justify buying one though
Old 07-27-2016, 02:41 PM
  #1273
Car: 87 TA clone
They are crazy fun, very easy to screw up and unforgiving when you do lol. I'm more of a street bike guy vs cruiser, long distances can be tough on a street bike. I still have my bike but the wife wont let me ride it, unfortunately my area is very urban so most people dont know how to drive, dont have valid licenses or dont have insurance which sucks.
Old 07-27-2016, 02:44 PM
  #1274
project89's Avatar
unfortunatly i know this all to well , just last year i went down broke my collar bone in half + sepearated it from my shoulder + broke my foot and a couple fingers all at the same time.
over the years theres been a honda cbr 600 rr , ninja 1000, ninja 600 and a katana 600 , most didnt last long due to were i lived at the time with to many idiots on the road
Old 07-27-2016, 02:48 PM
  #1275
Car: 87 TA clone
Nice! I was lucky, just alittle rash and a nice chunk of my hip missing which healed up with no stitches... not bad for flipping at 75+Mph on the highway lol.
Hmm CDR600 and ninja! My GSX 600 turbo is actually a katana 600. Very comfortable cruising street bike.
Old 07-27-2016, 04:17 PM
  #1276
Used to blast back and forth from Queens to Jersey when I lived in New York City with my old Hurricane 1000, would do 100+ over the Verrazano Bridge before all the work that is now being done to it, not to mention zip past everyone on the Belt Parkway. Looking and thinking back I honestly can't believe that I am still alive. You guys must suffer from the same nightmares that I did/do; blasting down the street on your bike with someone suddenly pulling out in front of you, bike hits the car and you go flying in the air for about a block. I usually wake up while still soaring and feeling like I am floating lol...
Old 07-27-2016, 06:24 PM
  #1277
anesthes's Avatar
Engine: LC9, LT1
I don't mind a few off topic posts, but please try to keep the thread on topic or at least relating to the car build.
Unless you are putting a turbo on the bike, in which case I'll be happy to split those posts off into a new thread.
Thanks guys!
-- Joe
Old 08-11-2016, 11:52 PM
  #1278
project89's Avatar
i took the car out again today lets just say i turned the boost up past what my map sensor can read , roughly 24 psi on vp114 still , and i swear i didnt stop smiling for hours, though i do belive its lifting the heads that high as i got some coolant sprayed out of the overflow.
but it was really friggen hot again
im happy as hell as ive been wanting to stress test the engine for a while now and im pretty sure 24 psi stressed the hell out of it
im actually really excited about my car once again so as soon as i can manage to pick up that ms from joe im taking the car to the track for sure
Old 08-12-2016, 08:37 AM
  #1279
Car: 87 TA clone
Very nice! das alot of boost. I dont remember what are you running for head fastners? If your running ARP studs your prob not gona get more clamping unless you upgrade the block/head for more head bolt holes. Maybe take timing down a few degrees.
Old 08-12-2016, 10:20 AM
  #1280
project89's Avatar
yeah ive got arp head studs , but only running a composite gasket, so i could try switching to an mls if it is lifting the heads, but then again i dont plan on running it that high ( much), have to wait till we get past theese 95-105* days and see if it does it when its cooler out
im going to back it down slightly and see if i cant get some videos today when i get home from work
Old 08-14-2016, 10:13 PM
  #1281
project89's Avatar
yup im pushing water , the head studs are tq'ed on the low end , thinking about mls or other gaskets ,....
suggestions
Old 08-14-2016, 11:52 PM
  #1282
Car: 87 TA clone
That's about all you can do plus prob a few coats of copper coat. Nothing more you can do without more clamping force which means more bolts around the cylinders. I've heard the water/meth can help lower the cylinder pressure and then you wouldn't have to drop timing.
Old 08-15-2016, 07:06 AM
  #1283
anesthes's Avatar
Engine: LC9, LT1
suggestions
Did you deck the block?
A felpro 1010 or 1003 gasket holds tons of cylinder pressure, as long as the deck is good and flat. If the block wasn't decked, who knows.
Either way, an external water leak shouldn't be caused by boost.
-- Joe
Old 08-15-2016, 07:39 AM
  #1284
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Proper deck finish and mls will seal best but leave little room for error if tune is bad. Mls usually torches heads when they fail or lift.
Copper gasket oring setup is alittle more forgiving but also requires several retorques from what i read
I've never retorqued mls
Old 08-15-2016, 07:50 AM
  #1285
anesthes's Avatar
Engine: LC9, LT1
Years ago guys used to use those steel o-ring gaskets and have the heads machined for them, but I haven't seen that in a while.
-- Joe
Old 08-15-2016, 08:06 AM
  #1286
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Big hp guys love the copper with steel oring in block and receiver groove in head. Was debating on this for my new setup but am leaning towards mls since its simple and has been proven to work to my planned power. Just gotta watch the tune
Old 08-15-2016, 08:13 AM
  #1287
anesthes's Avatar
Engine: LC9, LT1
I've always had good luck with the felpro permatorque.
I tried a cosmetic or cometic or whatever the hell they were called MLS back in 2008 or so, and it leaked coolant. When I called they told me I didn't spray both sides enough. wtf.
-- Joe
Old 08-15-2016, 09:28 AM
  #1288
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Most mls dont need any coatings. The copper stuff is up in the air. Some guys swear by spraying it, some dont
Old 08-15-2016, 09:40 AM
  #1289
anesthes's Avatar
Engine: LC9, LT1
I don't know. We used to spray the steel shim gaskets when I was growing up in the dealership, cuz GM told the techs that's what to do.
Cometic told me to spray the crap outta it. It still leaked. $200+ gasket.
I've never had a problem with the permatorque, but I've seen plenty of pictures of the fire ring distorted.
For anything high performance I always have the block decked. Cheap insurance.
The other thing to consider is the finish on his heads. I know a lot of the early pro-comp heads needed to be kissed flat, perhaps that is part of the problem.
Still, I stick by my opinion that if boost caused this issue he has one or more dead cylinders now. I do NOT think the head was lifting, not with 17 bolts. But who knows.
-- Joe
Old 08-15-2016, 09:58 AM
  #1290
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Yup anytime you push water you may have hurt the gasket
Old 08-15-2016, 11:54 AM
  #1291
I run Cometics too, gave them a generous amount of copper spray before torquing them down. Re-torqued them after bringing engine to operating temperature and after waiting for slight cool down, never leaked once, so far...
I do NOT think the head was lifting...
This is why I maintained my coolant reservoir, you will know immediately if so...
Old 08-15-2016, 01:32 PM
  #1292
Car: 87 TA clone
Ive run the permatorque and never had issues but that wasn't with boost. Stock 150k 5.3 on OEM 99 graphite gaskets with original tq to yeild bolts and at 10psi no issues yet. I'm planning to get refreshed heads since I can't get good graphite gaskets for my knotched heads and going to get non knotched heads which use MLS gaskets. GM stopped making graphite and MLS is now the stock replacement for all LS motors... so I'm forced to run them as a quality gasket. Same thing goes for the LS1 lifters which now are all discontinued... all forced to get LS7 lifters as stock replacement. MLS can't be that bad as all the LS guys run them with lots of boost. Heads lift the gasket isn't at fault, can't upgrade the fastners over ARP studs so then all you can do is get 6 bolt vs 5bolt heads or dial down boost/timing or figure out how to alleviate cylinder pressure
I bet the cheap heads have something to do with it.
Old 08-15-2016, 01:40 PM
  #1293
project89's Avatar
im going to take a look , im only running a composite with silicone bead gasket , i also didnt tq the head studs to the max tq i could have
theese heads have a damn thick deck on them id be really really surprised if it was the heads , but being they arent brand name heads u never know
its actualy fine until i really crank up the boost so maybe i just need to tq down the head studs a lil more
Old 08-15-2016, 01:47 PM
  #1294
Car: 87 TA clone
I was only referring to the head brand... quality might not be the same as other 5/8" deck thickness say from edelbrock or brodix etc.
I would def swap the gaskets out and crank them down TIGHT! Man those pistons are close to each other. Barely any gasket between eachother (assuming its bored out)
Old 08-17-2016, 09:32 AM
  #1295
Drac0nic's Avatar
It could be the block deck flexing too. Did you use plugs when building it?
Old 08-18-2016, 09:24 PM
  #1296
project89's Avatar
2 dead cyls , but just plugs again the autolight racing plugs r friggen garbage this is set number 3 ive had plugs die on me so im switching to ngk's
ive got some lowering springs comming 2.25inch drop, hope i can still get it in and out of my driveway after lol
  #1297
project89's Avatar
its only .020 over
Old 08-18-2016, 09:54 PM
  #1298
Car: 87 TA clone
Hmmm interesting. I've been running the NGK TR6 which is only 1 step colder but love them. Going to get another 8 as spares. I only run NGKs in my last 2 motors. Gapped at .035 right out the box.
Old 08-18-2016, 10:03 PM
  #1299
anesthes's Avatar
Engine: LC9, LT1
Autolite 3923 here.
Project89: What is your injector firing strategy? 2 per cycle?
-- Joe
Old 08-18-2016, 10:10 PM
  #1300
project89's Avatar
Autolite 3923 here.
-- Joe
2 squirts alternating i.e 1 squirt bank 1 -- 1 squirt bank 2 per 720*
Quick Reply: Single turbo 352 iroc 1000hp or bust the grand finale
