Single turbo 352 iroc 1000hp or bust the grand finale
#1057
Re: Single turbo 352 iroc 1000hp or bust the grand finale
any transmission guys here ?
out right now playing with the car decided to do some testing and my transbrake is engaging and holding but as i come up on the converter it suddenly starts to slip and car rolls forward
what should i be looking at
#1058
the transbrake did work on first try , and all i have to say holee ***
#1059
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, LT1
Transmission: TKX, 4L60E
Axle/Gears: 3.42, 3.23
Probably shimmed too loose, as I'm assuming you used alto red clutches...
-- Joe
#1060
ill post up some stuff tonight but im having a ****ing blast with the car right now on a low boost pump gas tune , cant wait to crank her up and race gas and see what she does then , but that wont be tonight
#1062
Engine: LC9, LT1
The downside to using a transbrake is you need to have a machine shop where you can turn the drum and the steels to be just the right size. A loose reverse or first gear is not noticed on a street car, until you try to use it to hold against your forward 2nd/3rd.
You probably wouldn't have this problem on a 400hp car either, but when you're making over 500hp at 3000rpm, tolerances matter.
Glad you are having fun with the car. I have not touched mine in a few weeks. Went out a few times in the speed boat, but mainly have been working on the house.
-- Joe
#1063
thank you , looking over some data logs from passes now , ive either got a fuel system issue or im making more power then i think
my 85# injectors are showing
52% duty cycle at 5/6 psi @ 4900 with an afr of 12.5-12.7-1
air temps at intake are a cool 123* with 96* ambient temps
#1064
It simply wasn't shimmed properly.
-- Joe
-- Joe
#1065
Engine: LC9, LT1
I've been on and off exploring using both MAF and MAP, but rather than be RPM based like the OEM stuff, instead use MAF under 100kpa and then switch to MAP. I think I can tune out some of the goofy stuff that happens with speed density, including not having to use soo much AE.
I'm really pick about the way stuff runs. Even my 2012 GMC 6.0 has a little 'bump' once and a while that makes me cranky. (and no, it's not the a/c compressor cycling)
I do hope you end up keeping the car. I suspect you are about my age, and I honestly regret selling a number of projects I had. Some cars got sold complete, others parted out and used to supply other projects. But I really do regret getting rid of them. Now I just keep everything. I've got enough land that I can always build more garages.
-- Joe
#1066
Are you doing both fuel and ignition with the ECU ?
-- Joe
-- Joe
tuning this thing for cruising is a lil rough as with the cam and intake it doesnt make much vacum at all so not a whole big tunning window , i may be better off with maf for crusing and speed density for boost , i need to switch to manual brakes or something
#1070
#1073
Engine: LC9, LT1
When you run a 2 bar map sensor your resolution is pooched, and 3 bar is even worse. MAF at idle, part throttle, etc conditions is far superior. But blow through MAF is useless, so having both is a great solution.
In theory.
Orr - You are running the 411 PCM, and that's hybrid MAF/MAP out of the box isn't it ? Or are you running modified code that is MAP only?
-- Joe
#1076
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
That's a pretty easy setup if you can hack the PCM. You can actually have it on a table look up how you want it to pull based off load or anything else and do a slow blend from MAF to SD. I've seen it done before. Actually, I've run the code on my own car, just never implemented the SD to care.
I'd consider doing this on $8d eventually with my car if I ever saw a dip in cruising "performance."
#1077
Engine: LC9, LT1
I know it's also factory in the LSx PCM's, but I don't have any experience tuning those.
-- Joe
#1078
#1079
Engine: LC9, LT1
To a degree on a turbo setup I'd agree with you.
On a n/a, or supercharged motor it's a huge benefit. That's why GM and many other OEM's do it that way.
But again, on a turbo you're probably in boost a lot more often, so the lack of range under 100kpa is irrelevant.
-- Joe
-- Joe
#1082
Engine: LC9, LT1
Boost also attempts to push the valve open, so you really need to make sure your springs have enough pressure to keep the valve seated.
-- Joe
#1083
-- Joe
-- Joe
#1084
Engine: LC9, LT1
So for example, the representation of 20kpa - 100kpa is .25 to 1.5 volts on the 3 bar map sensor, with only 6 data points.
On 1 bar, the same range is .5 volts to 5 volts with 21 data points to interpolate through.
Does it work? Sure.
On a n/a, or supercharged setup using a hybrid MAF/MAP combo you now have a dedicated sensor reporting 0-5 volts for operation under 100kpa. The MAF sensor (assuming a GM LSx) has 1,026 data points. The resolution is quite a bit better.
On a turbo app, you will probably spend more time in boost during part throttle and wouldn't have a benefit of more resolution while not in boost.
In fact, most turbo vehicles (OEM too) that I've been in were more of an on-off switch. Idle or boost, no real in between.
-- Joe
#1085
Hydraulic is a PITA. You are always fighting spring vs lifter collapse. The setup I have right now, the cam requires more spring pressure than the lifter mfg (howards) recommends using. You absolutely HAVE to do a running valve adjustment, or when your lifters pump up the valves will be too tight.
-- Joe
-- Joe
Love to see how anyone does a running preload adjustment on shaft rockers lol
#1086
Engine: LC9, LT1
If you had dual MAP sensors, a 1bar and a 2bar and used table switching it would be a little better.
This is the stuff that keeps me interested in the hobby. Any idiot can slap mail order parts together, but advanced controls, algorithms, etc keep me engaged.
-- Joe
#1087
All you are doing is tricking yourself. Sure you can have a 24x32 fuel table which looks great on screen, but you still have a lack of resolution in the sensor itself. It's not like a variable resistor (i.e, a TPS). It has set voltages it produces in 'steps' (I refer to them as data points).
-- Joe
-- Joe
#1091
Engine: LC9, LT1
I tighten the 5/8 nut until the tick goes away, go a 1/4 turn and hold the wrench while I tighten the allen.
-- Joe
#1092
as seen here
versus ur std stud mount type rocker
#1093
just checked the stock ms map reads in 1 kpa increments, my car idles at roughly 62-67 kpa
#1095
My rear mount 305 was same way once i deleted cat. It simply was laggy enough that par throttle rarely saw boost. I never felt a difference running 3 bar vs 1 bar on those setups. Plenty of resolution to keep fueling stable and happy
#1097
Engine: LC9, LT1
-- Joe
#1098
Engine: LC9, LT1
When I was in school, we were taught about Tesla vs Edison in respect to engineering. Edison would spend countless hours and days trying to understand something through trials that Tesla would simply use an equation to solve on a chalk board. No doubt Edison was passionate, but he lacked the traditional engineering background to fully understand what he was doing. This also led to the saying "Correlation does not mean causation".
-- Joe
#1099
Oh my goodness, is it really reaching the Edison vs Tesla debate now lol? Hey, let's also throw in Einstein vs Poincare, that is one of my favorite's, being Einstein was a plagiarist disguised as a patent clerk...
Joe you're accusing Justin of arguing everything you say, but the truth is you love all of this bickering more than most of us combined lol. I don't agree with either one of you, but in this case hey Justin is the only one that ran the numbers that would require that much data in terms of this argument, so what he is saying is clearly backed up and tangible...
#1100
Why is this? Precision versus accuracy. It's a lot like any other measuring tool we have, say a bathroom scale. If you get on it and weigh yourself at 200.5 lbs and it shows a tenth of a pound increment, that means that you're anywhere from 200.45 to 200.55lbs. At the point you're less or more, the scale will indicate the lower or higher quantity. This is called quantization error.
Lets look at the transfer function of the sensor as per its data sheet (URL at bottom)
V out = VS x (0.00369 x P + 0.04)
Notice how it doesn't say anything about steps in it.
In our example if we have ~253,000 and divide it by 512 (9 bit binary) we get roughly .5 KPA. Checking the data sheet of the MC9S12 CPU in the MS2 we find it has a 10 bit ADC. This means that the code base its self is the bottleneck in terms of resolution as you're seeing less resolution than the actual hardware is capable of. Chances are they didn't care and found half a KPA to be more than accurate enough, or it's plausible they just didn't have the CPU horsepower to do the precision calcs.
Overall I'm inclined to agree with Orr89RocZ. We don't typically worry about emissions in many cases with our cars and are willing to make mild to moderate sacrifices in driveability. We are also using a fully custom tune which means we don't worry about tolerances in the system nearly as much because we're compensating for them and until recently (maybe even recently) we tend to use better feedback instrumentation like wide band O2s.
http://www.nxp.com/files/sensors/doc...et/MPX4250.pdf
