Single turbo 352 iroc 1000hp or bust the grand finale
#551
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, LT1
Transmission: TKX, 4L60E
Axle/Gears: 3.42, 3.23
Re: Single turbo 352 iroc 1000hp or bust the grand finale
-- Joe
#555
Engine: LC9, LT1
I've never had a problem with mine - it's a surface mount unit built my the manufacturer. Not a through hole high school project.
There is probably a thousand times the number of MS units in operation than EBL.
But beyond that, certain features are a must for me. I'm not going backwards.
-- Joe
#556
If Dave's car still maintains the factory TPI harness (correct if I am wrong Dave, as I remember your car coming with a carburetor but was originally Tuned Port Injection), if he didn't butcher it, then I would say go EBL Flash for sure. Megasquirt has a lot of users out there, but only a handful on this website that were successful with it. I think the ratio of EBL users here is much higher in comparison. Lot of ways to go though, I mean there are even classic FAST systems out there for extremely cheap that work hand in hand with the GM distributor. To be honest, at the rate he is going, he should just go blow-thru carb and call it a day, this way he can at least enjoy whatever is left of the season...
#557
Engine: LC9, LT1
I've recommend EBL to a number of people over the years because I know even if they had an IQ under 60, RBob would work with them and get them up and running.
-- Joe
#558
i dont have a stock harness on my car , when i got the car somone took bolt cutters and cut the harness in half by the heater box when they did the carb swap , i put the tpi back on it but went right to ms
the ms isnt a bad system , i bought a used unit that wasnt assembled properly , when i tried to fix it i missed a few things myself and thats were my issues came from
i was just going to buy a new diyautotune assembled unit , but if im going to spend 4-500 bucks i may as well justs pend a lilmore and try one of the other systems i havent tried before
heres a picture from the other day so u guys know im not slacking
#560
Engine: TPI 327 SBC Turbo MS2
Transmission: 200-4R CKP Stage 2
Geesh, you know how to get the MS going, but you're considering a change before you even get the motor broke in? No one can say you aren't scared to tackle something new.
Grab an assembled MS and get it running.! I want to see what this thing will do.
Good luck and KEEP IT GOING
#561
anyone know were to buy the coil cord for a transbrake button , summit sells it but only with abutton attached to it and the cheapest is like 50$'s , hell i already have a button , i just need the wire
#562
summit just delivered my arp rear wheel studs , comp cams breakin oil , and some other misc parts i needed to put the engine back int he car , now i just need the new mosfets for my megasquirt to arrive so i can repair the injector drivers
#563
my new turbo is here lol
lol i think id need 7 more of those
any ways i got the oil leak fixed motor back in , im just waiting on diyautotune to ship out my replacement parts for my ecm , and then i can finally get some vids of this thing up and running
#564
uncalled for and reported , like i said before u dont like the thread dont click on it
#566
god i hate to even say it since the last planned outing was halted due to my ecm issue sometimes i think this car is cursed lol
my next planned outing is nov 14th i have my fingers crossed we will make it i have other projects im working on along with the car so my time is split up between then
the good news is there is racing here year round except for the month of december so if i dont make the next one the next race would be in january
that being said i am focusing most of my time on the car right now , and as it sits im just waiting on replacement injector drivers for my ecm from diyautotune which shipped out today with 2 day delivery , other then that i need to yank the rear apart and install my longer arp wheel studs and then shes ready to go
#567
buttoning up the electrical and fuel system tonight, ecm parts are sitting in my po box to late to pick them up tonight , so ill grab them in the morning and get my ecm fixed .
only hurdle left to get over is a trailer to tow the car to the track with , was going to use a friends but they are going racing too , that leaves the 5th wheel flatbed farm trailer but i dont think i can get my car on that trailer unless u build like 10ft long ramps
#569
yeah fixing some odds and ends today , picked up some gates radiator hose exspensive stuff at 22$ a foot to replace the stock hoses i cut up to make connectors for the steel rad hoses , need to mount the wideband gauge and a few misc items in the car , and finally tonght im going to solder in the new injector drivers in the ecm. so glad this will finally be done so i can get started on my turbo bike/motard conversion on my xr250r
if anyone wants to follow along on that here it is
https://www.thirdgen.org/forums/fabr...-dirtbike.html
#573
well wont be the first startup but close enough , if all goes well this weekend were off to the track next weekend
#577
Originally Posted by project89
well wont be the first startup but close enough , if all goes well this weekend were off to the track next weekend...
Did you get any closer?
#579
video uploading
this new motor and turbo setup sounds good
#580
more vids later just home to eat and go back to working on it
#582
not sure what im going to do witht he steering wheel right now its got a grant with a hub on it now i may just buy another grant wheel
#583
#585
#589
its not to rich on cold start , actually not as bad as the actual first start that i did were it just smoked black , but hard to tell as i had the ideband out of it till all the oil and grease had burnt out of all the new tubing
i think the echo in the shop makes it sound a lil worse then it really is as well
cam is installed +4 so its going to be a lil rougher then normal as well
#590
Yeah it's rich, but shouldn't surprise you Dave. Did you tune it, or just running a base code? No O2 correction in Open Loop, open downpipe right where the camera is filming, and an enclosed garage. That's going to effect the sound. It's sounds very crisp to me though, but I can see how it would be mistaken for running rough. How much vacuum are you pulling in idle?
#591
dont know how much vacum none of the gauges inside the car are plumbed yet , and i wasnt paying attention to tuner studio as i wanted to make sure we had no leaks or obvious problems at first, i did find a small fual leak that i need to take care of at one of the fittings
and yes front exit downpipes FTW
#595
u know what ur right im confusing myself , cam was ground with +4 and i installed it -4
for some reason i was thinking the opposite ground with -4 installed at +4
my timming set offered 0-2-4-6* retard and 0-2-4* advance
#597
right now im just giving the stocker a once over since the pinion seal was leaking
but more then likley i will start on the dana 60 after my bike project
#599
#600
Originally Posted by project90
its one of those very easy things to confuse when thinking about cam advance and retard...
