Any interest in meth/intercooler harness?
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
Built a cleaner methanol/IC pump harness and can build plenty more
Top going clockwise
12v battery with inline fuse and holder
Hobbs switch ring terminals
Alcohol pump/solenoid inline connectors (pump and sol for reference)
Intercooler pump connector
GRD, doubled for safety
12v IGN splice with inline connector
Meth and IC pump relays
In a nut shell, the IC pump runs continuously with the IGN on. The alcohol pump only fires when the hobbs switch engages. Solenoid prevents engine idle vacuum from sucking the tank dry when its not needed. Inline connectors are used to prevent hard connections. The IC pump circuit can be deleted for those only running meth i.e. turbos with ATA IC
Anyone want one?
Top going clockwise
Anyone want one?
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Re: Any interest in meth/intercooler harness?
So if i wanted to run a meth kit, the only things i would need to get after using your harness is:
-meth pump
-meth lines
-meth tank
-meth nozzles
Right? What if i don't want to use the IC pump and only use the harness for meth use?
-meth pump
-meth lines
-meth tank
-meth nozzles
Car: 92 Firebird
Thats right, the IC pump circuit can be deleted
Everyone seems to hate electrical, so this is the "hard" part made easy
