What size wastegate?
Car: 1992 camaro
Engine: 5.7L single turbo GT45
Hey I'm currently mid build on a single turbo (GT45) build and am ready to buy a wastegate. i am running the xs power manifolds that come with a wastegate port set up for a 38mm. The location of the gate is what i am concerned about due to it coming off the number on primary on the turbo side. i plan on running 7PSI for now and want to make sure i get a big enough wastegate. So will 38mm do the trick and has anybody had any luck with ebay wastegates?
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Re: What size wastegate?
Kyle86 on here has a thread on in the lsx swap section GT45 and a single emusa 38mm ebay gate. Seems to hold 7psi fine for him on the 4.8L and 5.3L. I personally would go minimum 44mm especially if you think flow is an issue.
In the past I have always had good luck with X02, I had two 44mm for my current twin scroll GT45 setup but they were too bulky and I snatched up some Tial MVS 38's on Black Friday for $200 a piece.
Jay
Jay
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
If in a good location to extract flow then a 38 could work but i agree, you should go 44-50 for ultimate low boost control on a single turbo
Car: 1992 camaro
Good stuff guys i will get the 50mm not a huge price difference just means i get to install some awesome v band flanges! any suggestions on intercooler piping sizes just finished the hot side and will be in the market for intercool kits.
Car: 89 Iroc-z
Transmission: TH400
2.5" is fine for 500 hp. 3" for more. Big power singles use 4"
Pac J
05-17-2020 10:44 AM
LiquidBlue
Wheels and Tires
32
12-10-2019 04:06 PM
