oil return turbo
Old 12-23-2014 | 07:04 PM
sideways87's Avatar
oil return turbo
Is it possible to run the oil return to the fuel pump block off plate?
Thought I saw someone do it but couldn't find any answer searching.
Old 12-23-2014 | 07:24 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Re: oil return turbo
Yes but its not as good as the pan
Old 12-23-2014 | 09:50 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula, '95 Formula
Engine: LC9 , LT1
Transmission: TKX , 4L60E
Axle/Gears: 3.50 9" , 3.23 10bolt
Why not? Isn't that basically where the lifter valley drains in the front of the block?
-- Joe
Old 12-23-2014 | 11:41 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Theres two smaller holes in the block off port the oil has to return thru. It can back up slightly as its not as much gravity feed as the pan, depending on where and how high turbo is mounted. It can work fine dont get me wrong. I just prefer pan. Alot of oil gets trapped up in the top end on a wot pull. I want to get as much of that back to pan as quickly as possible
Old 12-24-2014 | 05:25 AM
anesthes's Avatar
Engine: LC9 , LT1
Good points.
When I used to run vortech blowers we returned to the pan on the driver side. I tried a few different methods, tapping the pan and rtv, bulkhead connections. Always leaked. I never tried welding a fitting to the pan cuz I was afraid the pan would warp too much and leak at the rail.
Do you do the oiling mods to your blocks when you machine them?
-- Joe
Old 12-24-2014 | 06:42 AM
sideways87's Avatar
Cool Thanks guys,
ill probably just do it that way for now and get it running, and when I take the engine out ill move it to the pan.
Old 12-24-2014 | 07:19 AM
project89's Avatar
Originally Posted by sideways87
Cool Thanks guys,
i run twin turbos to the fuel pump area , if the block is apart and u look in there u will see the lower drain hole u can enlarge the hole with a drill bit and it helps alot.
if the engine is already assembled i wouldnt suggest trying to drill it out
Old 12-24-2014 | 07:41 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
i ran mine to the fuel pump plate, very shallow drop from the turbo, no issues at all
Old 12-25-2014 | 08:55 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Just a heads up that not all blocks have the fuel pump holes drilled. Be sure to check this first.
RBob.
GeneralIesrussi
Carburetors
06-20-2024 07:21 PM
Hotrodboba400
12-10-2019 07:07 PM
dmtz956
LSX and LTX Parts
09-06-2015 04:45 PM
tgp1990
09-04-2015 06:24 AM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: oil return turbo
