lt1 powerdyne on tpi
Car: '88 Formula, '95 Formula
Engine: LC9 , LT1
Transmission: TKX , 4L60E
Axle/Gears: 3.50 9" , 3.23 10bolt
Re: lt1 powerdyne on tpi
I ran a BD11A for a couple years on a C4 (corvette). You can upgrade the impeller for more boost too.
-- Joe
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Well I picked up the kit for pretty cheap 800 with everything and some pod and gauges. would I be able to use the head unit though on SBC at least? Or do they rotate different like Lsx engines.
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
I already have ac delete so it would be perfect if I could do that ima check how much it costs to get me a bracket done see if its worth it if not ill just sell itQUOTE=anesthes;5839254]Probably need new brackets. Making a blower bracket is pretty darn easy though. I'd remove the a/c compressor and make a bracket to hold the head unit on that side, off the main belt.
-- Joe[/QUOTE]
-- Joe[/QUOTE]
Sanjay
08-12-2015 03:41 PM
