Turbo on a 355
Old 07-28-2014 | 10:48 AM
Cody89RS's Avatar
Car: 1989 Camaro RS
Engine: 355 SBC
Transmission: th350
Axle/Gears: 31 Spline Moser Axles & 4.10 gears
Turbo on a 355
Got a question for everyone. I am taking a small block 355 and putting a t76 on it. I know the internals aren't stock. Nothing to write hone about but just wondering how much boost a stock 355 can hold safely...
Any help is appreciated
Old 07-28-2014 | 11:40 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Re: Turbo on a 355
Its not boost but power you need to look at, and that depends on heads cam and intake. 18 psi on stock head stock cam wont be near the power a afr 195/224 deg cammed car on 9 psi will make
Old 07-28-2014 | 11:28 PM
project89's Avatar
Re: Turbo on a 355
tune it good and u can push that turbo to the max before u have to work about the engine
one word of advice tq the main caps and extra 5ftlbs and tq the heads to 85ftlbs and use a standard rebuilders head gasket , the composite engine tech ones work great
Old 09-08-2014 | 08:17 PM
vortec350s10's Avatar
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
Re: Turbo on a 355
Trust me I've researched the heck out of what guys are running and it's all over the map as to what people consider safe on a relatively stock sbc. I have hardly ever seen anyone that has destroyed one from sheer hp stresses. It's almost always due to over revving or leaning out or something accidental like that. I'm scared to go over 10 psi with mine, even though I don't really have a reason to be. Search "the grenade" on theturboforums.com. Interesting and long read.
Old 09-09-2014 | 03:45 AM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Re: Turbo on a 355
Its all in the tune. Look at how many STOCK LS guys are running 20-25+psi with just gapped rings. Then you see even more guys blowing them up with 10psi. With all of the gas choices we have available now you don't need to worry about having a 7:1 dog *** motor to run a turbo/sc.
Jay
Old 09-10-2014 | 11:21 PM
project89's Avatar
Re: Turbo on a 355
Jay
yup even with those big *** dished pistons in my motor above my compression is just shy of 9.5-1 , still smacking it with 20+ psi of boost on pump gas
cheesehomer
12-31-2015 08:48 AM
Cam-aro
Camaros Wanted
11-12-2015 03:35 PM
darwinprice
17
10-11-2015 11:51 PM
bjpotter
10-04-2015 07:48 PM
anesthes
09-18-2015 12:34 PM
Quick Reply: Turbo on a 355
