hat for forced induction on tbi?
im planning on a single turbo on the silverado 2500 i just picked up , this truck has the tbi 350 in it .
the reason im putting a turbo on it is to get back the power i have lost being at 6500 ft above sealevel. it will take 4-5 psi just to restore the engines rated power at this altitude which the tbi will handle without issue.
i plan on 7-9 psi tops just for a lil added power and since the tbi injectors cant really handle much more then that
do u guys know anyone who makes a hat/bonnet to fit the tbi units. havent looked much but it dont look like i can even modify a carb hat to work on it
TGO Supporter/Moderator
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Re: hat for forced induction on tbi?
You will need to run a spacer, factory on L05 motors.
-- Joe
maybe i havent looked at it to well yet as normally with tbi i would have ripped it all off and went tpi or other means of port injection by now.
being the modest level of boost and power increase im going to leave the tbi on this one
i just ordered a ebay gt45 turbo yesterday so this weekend ill take a closer look at the tbi unit and see what i can come up with since once i saw the 2 studs for bolting the air cleaner down i didnt look at it much more thinking the reg carb hat wouldnt work
1 Post
Car: 1991 Firebird
Engine: n/a
Transmission: n/a
Axle/Gears: 3.27, I think
Take your air filter off and unscrew those 2 studs. Then get the single style stud and screw it in between the injector pods. Last, use a carb hat on it.
i figure at 7 psi i should be ok , since it would be running like 3 psi at sea level , should be about 30-40 hp more then stock rating
Keep in mind, when you raise intake manifold pressure you need to raise fuel pressure 1:1.
-- Joe
they flow 75#'s at 35 psi ? or are they 75# at stock presure
cause 2x 75# divided by 8 works out to roughly 19# per cyl
which if u had 8 port injectors at 19#'s each u would max around 220 hp with a turbo
or am i thinking about it wrong ? like i said ive never played with the tbi stuff im not looking to build a race truck here , this is actually my tow rig for towing my 18ft campping trailer and my twin turbo iroc out to the saltflats and drag strips.
im just looking to get back some of the power the engine has lost since it now lives its life at 6,500 ft above sealevel , + maybe an extra 20-40 hp
going to be doing flipped stock manifolds ebay gt45 turbo , intercooler + meth injection with a boost setting of 7-9psi , megasquirt controlling fuel and ignition
engine in the truck only has 25k or so on it 350tbi things still so damn clean u could eat off it
do any parts stores sell that single stud? or do i have to go picking threw the junkyard to find one
and since i just decided to seafoam the truck while i was at work this is what mine looks like
![Name: image_1_zps0db0f947.jpg
Size: 111.1 KB](https://www.thirdgen.org/forums/attachments/power-adders/350504d1501340369-hat-forced-induction-tbi-image_1_zps0db0f947.jpg)
1 Post
Car: 1991 Firebird
Engine: n/a
Transmission: n/a
Can't see the pic, but Advance Auto might have it. Spectre TBI Air Cleaner "S" Stud
Part No. 4215 $2.99
Here's Summit Racing:
http://www.summitracing.com/parts/sum-239007
Part No. 4215 $2.99
Come to think of it, my '89 c/k truck had a single stud too..
-- Joe
I would consider a set of the late 80s 454 injectors eventually. You don't need to worry about boost referencing your regulator, it's going to be under bonnet. I would get a TPI/Walbro pump and shove it in the tank, then crank the base FP to 30 PSI. After that she'll probably run more boost than you think. MS1/2 with an HEI setup? If so I bet she'll be a good runner. I always thought these were the standard carb bonnet size, at least that's what I heard. If I were going to do it I wouldn't put a ton of faith into that flimsy, offset stud honestly. I would probably make some sort of plate/clamp setup that fits on the TBI unit and holds it down that way.
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
if youre going to the yard, check the caddy 4.9 air hat, might work for you.
