nitrous questions
Car: 85 camaro
Engine: 5.7
Transmission: th400
Axle/Gears: 4.10
nitrous questions
I've got a nitrous kit I picked up for cheap.
It's a NOS SNIPER system.
I recently rebuild a 350.
It's basically stock crank, reconditioned rods and hypereutectic pistons.
I've been told by some mechanics that hypers dont go well
With nitrous no.matter what. Others have been telling me it'll
Be fine if I tune it rite on and not to big of a shot.
That's one of.my concerns. I've never messed with nitrous
So its kind of confusing.
The other item I've never messed with is a stall converter for it.
I got a 304 isky mega cam and I'm looking for a 3500-4000 stall.
But since I want nitrous I need anti balloon plate.
My concern is if a torque converter with anti balloon plates is as reliable as
One without anti balloon plates.And do I really need an anti.balloon plates if I don't plan on
Bigger then a 100 shot
Car: 85 camaro
Engine: 5.7
Transmission: th400
Axle/Gears: 4.10
Re: nitrous questions
It's got h.o 305 heads and a weiand intake.
It was.something my.machinist.put together for alil weekend warrior
Car: 85 camaro
Engine: 5.7
Transmission: th400
Axle/Gears: 4.10
Ima go to.the.junkyard and pick some up.
It's 906 and 901 on the casting.number isn't it?
Car: 85 camaro
Engine: 5.7
Transmission: th400
Axle/Gears: 4.10
Well the yard I go to has a 30 day return policy and my machinist said
He will pressure test them as.soon as I get.em to make sure.there ok
Car: 85 camaro
Engine: 5.7
Transmission: th400
Axle/Gears: 4.10
Perfect. I think I'm probably wring but isn't one of.those heads good for street and other
Is what circle track guys like to use?
Car: 1984 camaro z28
Engine: sbc 383
Transmission: Th400
Axle/Gears: Moser 9", 4.11 gear
No they dont. There is no difference between the two heads except for their appearence on the outside. There's been a couple threads on this previously.
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
Not true, the xxx(cant remember which one out of the two think the 906, or whichever one does not have the saw tooth pattern on the outside of the head) have the hardened exhaust seats that apparently hurt low lift flow.....I have the ones with the hardened seats and my brother previously had the ones without. Without testing cfm, I would argue that it would probably be a difference of 10cfm in stock form. The hardened seats had a bit more shrouding around the valve......pocket porting fixed that.
Engine: sbc 383
Transmission: Th400
Again, there was a thread on this about how a magazine posted misinformation. I cannot find it right now. Maybe someone else will chime in and help me out here.
Engine: sbc 383
Transmission: Th400
Here is another article cant find the other...
http://www.onedirt.com/tech-stories/...k-chevy-heads/
"The L31 Vortec comes in two different casting numbers, 10239906 (#906) or 12558062 (#062). Originally, the stock #906 casting head was available in two versions. One version had an Inconel exhaust seat with single angle valve grind and was available on 1 ton trucks. The other version was the traditional three angle valve grind. Other than that, the #906 is the same as the #062 head"
CarGuyDennis
137
12-06-2016 11:02 PM
