Noboostnogo's turbo build v2.175
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
I'm redoing the headers and going with megasquirt II v3.0. Turbo will be my current one tc78 but I might upgrade exhaust cover to a 1.15 ar from my .96.
Headers are up and forward mild steel that I will get jet hot coated and getting my pops to tig weld them. More than likely turbo will be in front of water pump blowing into a water to air intercooler under the driver side battery tray. Depending on packaging issues i might go with dual 2.5" downpipes unless I can fit a single 3.5".
Trans is a built th350 with brake and PTC converter
Power goals are to put down about 700 at the back wheels
Re: Noboostnogo's turbo build v2.175
if u want to save a few bucks i have an ms2 cpu for sale, i downgraded to ms1
I already built mine and got the cable for it and the relay box everything is built i just have to upload images
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: 92 Z28
Engine: Boosted LSX
can't wait to see the new build.
How do you guys like the MS stuff? Either of you ever use $59 code?
Thanks what Im running/ was running with the novi 2000. Im looking to either swap to the LSx pcm or something...
i would have tried 59$ on my current iroc but the po took bolt cutters and cut the harnes sin half by the fender when they put the carb on it, and the price ppl want for engine harnesses for these cars is insane, so it was cheaper for me to go megasquirt
not to mention i had already bought low-z injectors which wouldnt work with the stock ecm anywys
damn lol i would have sold u mine for like 65 bucks shipped and saved u like 45 bucks on the kit
btw be sure to use the latest msn extra 2 code the previous version 3.2.1 had some bugs in it
1 Post
Car: 92 Z28
Engine: Boosted LSX
Sorry for the hijack.. Last question..
would I need to repin my harness for a ms setup? (7730 tpi harness)
I guess I should goto the ms site and read up. Its been awhile since Ive been into tuning. Im deff. going to have to dive back into it with the new combo.
it says for the 165 ecm
http://www.diyautotune.com/catalog/m...pcb-p-363.html
but if u contact them they can prolly tell u if it will or if u can make it work for the 7730 harnes
so I built the passenger side manifold yesterday and was gonna start on the passenger side but didn't have enough u bends to finish it so I quit for the day
Man that's pretty cheap I bought a brand new ms2 kit from a local ttf member and assnled it myself I was quite simple and interesting.
so i finally had some time to get ont he computer and upload some pictures
this is just a random bad pic of the ms2, relay board, ms cable, iat, cts, and edelbrock fuel rails
![Name: IMG_0646.jpg
Size: 111.2 KB](https://www.thirdgen.org/forums/attachments/power-adders/359159d1501357889-noboostnogos-turbo-build-v2-img_0646.jpg)
this is my first attempt at making the headers, i will be redoing number 8 cylinder runner for some reason i dont like the way it turned out
![Name: 2012-11-0295182555.jpg
Size: 37.7 KB](https://www.thirdgen.org/forums/attachments/power-adders/359160d1501357889-noboostnogos-turbo-build-v2-2012-11-0295182555.jpg)
just mocking it on a spare motor
![Name: 2012-11-0295181636.jpg
Size: 45.4 KB](https://www.thirdgen.org/forums/attachments/power-adders/359161d1501357889-noboostnogos-turbo-build-v2-2012-11-0295181636.jpg)
and this is the little band saw i bought at harbor freight tool, it seems to do a great job so far
![Name: 2012-11-0295181756.jpg
Size: 67.3 KB](https://www.thirdgen.org/forums/attachments/power-adders/359162d1501357889-noboostnogos-turbo-build-v2-2012-11-0295181756.jpg)
front view
![Name: 2012-11-0295181737.jpg
Size: 57.4 KB](https://www.thirdgen.org/forums/attachments/power-adders/359150d1501357889-noboostnogos-turbo-build-v2-2012-11-0295181737.jpg)
![Name: 2012-11-0295181720.jpg
Size: 45.4 KB](https://www.thirdgen.org/forums/attachments/power-adders/359151d1501357889-noboostnogos-turbo-build-v2-2012-11-0295181720.jpg)
![Name: 2012-11-0295181941.jpg
Size: 43.5 KB](https://www.thirdgen.org/forums/attachments/power-adders/359152d1501357889-noboostnogos-turbo-build-v2-2012-11-0295181941.jpg)
some pics of the otehr stuff
new elbow and tb
![Name: 2012-11-0295181959.jpg
Size: 44.3 KB](https://www.thirdgen.org/forums/attachments/power-adders/359147d1501357889-noboostnogos-turbo-build-v2-2012-11-0295181959.jpg)
mockin the radiator
![Name: 2012-11-0295182044.jpg
Size: 44.9 KB](https://www.thirdgen.org/forums/attachments/power-adders/359148d1501357889-noboostnogos-turbo-build-v2-2012-11-0295182044.jpg)
new elbow and tb
mockin the radiator
![Name: 2012-11-0295182009.jpg
Size: 57.2 KB](https://www.thirdgen.org/forums/attachments/power-adders/359149d1501357889-noboostnogos-turbo-build-v2-2012-11-0295182009.jpg)
I have the TBI adapter board, grab the manuals swap the pins around for what you need and yank the rest out. This is the way to go in a lot of ways, I really like it instead of having to deal with a DB37 connector. The only thing I will say is I'd probably do a "harness stub" if I had no intentions of ever going to a stock box again. By keeping the connectors it keeps my options way open.
I'm gonna try to keep this thread updated with alot of pictures I am just waiting on more pipes and clamps to come in now and a day or two off work to get stuff done
quick update
![Name: IMG_2713.jpg
Size: 117.4 KB](https://www.thirdgen.org/forums/attachments/power-adders/358368d1501356373-noboostnogos-turbo-build-v2-img_2713.jpg)
dropping everything off at the shop to get tig welded
![Name: IMG_0681.jpg
Size: 92.4 KB](https://www.thirdgen.org/forums/attachments/power-adders/358369d1501356373-noboostnogos-turbo-build-v2-img_0681.jpg)
i will get some pictures of the engine bay as it sits, i got the new edelbrock victor-mounted with the elbow, tb, rails and injectors and the turbo merge
oh and the radiator is already relocated
slowly but steady and hope to have it at least idling by january
Went and picked up all the tubes from the shop and they look nicely tig welded I tacked them on the flanges tacked the bullets on and im taking them back on mondayto have them finish them with the collectors and vbands on. I've started on the turbo merge and once I have the headers finished I will finish the crossover hopefully by next weekend
Quick update!
Crossover is tig'd. All I have left to do is mount the waste gate and fab the 3.5" dp and the hot side is done. After Xmas I will mount the a2w cooler and finish the cold side
i dont know if anyone is following this or not but heres a quick update!
![Name: IMG_7741.jpg
Size: 63.9 KB](https://www.thirdgen.org/forums/attachments/power-adders/356400d1501352448-noboostnogos-turbo-build-v2-img_7741.jpg)
![Name: IMG_0311.jpg
Size: 65.0 KB](https://www.thirdgen.org/forums/attachments/power-adders/356401d1501352448-noboostnogos-turbo-build-v2-img_0311.jpg)
![Name: IMG_4394.jpg
Size: 71.5 KB](https://www.thirdgen.org/forums/attachments/power-adders/356402d1501352448-noboostnogos-turbo-build-v2-img_4394.jpg)
![Name: IMG_3834.jpg
Size: 65.8 KB](https://www.thirdgen.org/forums/attachments/power-adders/356403d1501352448-noboostnogos-turbo-build-v2-img_3834.jpg)
I need to build a new bumper and some supports for the intercooler.
I am hoping to have this thing idling by this weekend since i ordered the fuel pressure regulator which was the last thing i needed for the efi conversion.
--I still have a bunch of stuff to do like build a ice tank which i will try to fit in the opposite side of the spare wheel compartment
--get hotside coated (any advice here?)
--wire in transbrake
--finish downpipe (waiting on parts to arrive)
--put everything back together like headlights and wiring, dashboard center console
--build new bumper support
-- and i need to brace my turbo not sure how im gonna do that yet
so what do you guys think? any feedback?
must be nice to be close to firing up your project.Im getting close to the 8th year mark with my turbo project and still have 3-4 months to go. Post up video when you fire it up. I do like how your exhaust headers are setup makes it easy to access the sparkplugs.
Yeah when I built the headers I had spark plug accessibility in mind and these make it easy to get to but only from the bottom
New2Chevy
09-28-2015 12:35 AM
