Its turbo time!
Old 09-03-2012, 09:03 PM
34blazer's Avatar
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
Its turbo time!
finally out of training thats lasted a year and im on a favorable schedule.
along with Mark im in the market for a turbo. ive been looking at the fleabay gt35 special(lol). found mostly T3's with larger comp wheels like this one....
http://www.ebay.com/itm/PORTED-SHROU...sories&vxp=mtr
was looking for T4 frames but they have the small 57mm wheel. i like the 62mm wheel, seems perfect for my little 3.4. anybody have good links?
Old 09-03-2012, 09:17 PM
project89's Avatar
Re: Its turbo time!
its about time :P
engine mods?
stock heads cam = hybrid 50mm
stockheads / 252 or better cam = 50/57mm
ported heads/ 260+ cam = 57 to 67mm
depending on the turbo hotside will also dictate turbo sizing
for most built v6's a turbo on the 60-61mm range is plenty
cx racing offers the gt3582 with a t4 ptrim wheel in either .68 or an .84 housing if u really want the t4 turbine go with the .68
as fasteddi is doing the 57mm t3 hybrid turbo coupled with the t67 compressor will make one very killer turbo for a worked over v6
Old 09-03-2012, 09:25 PM
project89's Avatar
Re: Its turbo time!
its not 67mm its 66 mm
http://www.ebay.com/itm/GODSPEED-GSP...1ee534&vxp=mtr
that compressor put on the hotside of the 57mm hybrid will make a killer turbo and is what fasteddi is going with i belive
Old 09-03-2012, 10:00 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: Its turbo time!
For goodness sakes, why buy something for $300-400 thats going to break, if not right out of the box, shortly after, instead of spending $800 on something that will last forever ?
Old 09-03-2012, 10:02 PM
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
Re: Its turbo time!
yeah dude i been busy for the last year lol. i get 3 day weekends so ill have way more time than before.
the engine:
ARI 3.4
hyper pistons, rings were loosened up for boost, top ring is plasma-moly
arp hardware for the bottom end
heads are ported, gasket matched, bowls blended, valve guides slimmed down, still have the vane but much smaller
k-motion valve springs, iirc K-700's
crane chromoly retainers and locks, viton seals
trick flow 6.250" chromoly pushrods
crane solid cam, howards solid lifters
the cam is a 290/300 adv duration 493/512 lift(1.6 rockers) on a 112 LSA
42# injectors/walbro 255
also have a bbk rrfpr on the rail
going to use the 2.8/3.1 intake for now. on a budget lol
im liking that turbo you posted lol
Old 09-03-2012, 10:06 PM
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
Re: Its turbo time!
id love to buy the better part. problem is, budget. i dont care if it breaks, engine blows, etc. the engine and car have been sitting for the last 6 years, id rather break it than have it sit collecting dust. i want this piece on the road within the next year, tops.
Old 09-03-2012, 10:14 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Re: Its turbo time!
But seriously, if $400 is going to break the bank, you probably shouldnt be doing this...
Old 09-03-2012, 10:18 PM
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
Re: Its turbo time!
LOL, its not. trust me
Old 09-03-2012, 10:44 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Re: Its turbo time!
So then why fool with something that has a likely chance of just breaking for no apparent reason other than it was cheap poorly copied junk in the first place ?
Old 09-03-2012, 10:52 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Its turbo time!
Why keep harping on him about his choice of product to put on his vehicle? Especially in the light that MANY people use these same turbochargers with great reliability and success.
Old 09-03-2012, 11:00 PM
project89's Avatar
Re: Its turbo time!
that cam is going to want a serious top end turbo
the turbo i posted is not a good choice by itself the hotside has a .48 housing, though realistically in the picture it apears to be a .63
but the turbine wheel itself is tiny and a mismatch
for fasteddi he already has the 57mm unit with the much better hotside so if he gets that turbo and swaps the coldside onto his 57mm unit it makes a very kickass turbo
the way they offer that turbo (66mm) its aimed more at the 4cyl ppl to get that massive compressor spinning with not much lag
for an out of the box turbo for u i recomend the 57mm unit or the gt3583
the gt3582 would be my first choice
if u can pick up a t3 50 trim out of the junkyard with a 5 bolt turbine and a .63 or 8x housing for cheap i would get that then buy the 66 and swap the wheels
other then that buy the gt3582
Old 09-03-2012, 11:07 PM
project89's Avatar
Re: Its turbo time!
actually i take that back knowing the actualy size of the v band flange i was able to calculate the actual size of the turbine wheel from the picture, and it apears its the same size as the 57mm turbos turbine so if it is infact a .48 housing u could swap on the .63 from any standard t3
edit never mine its the smaller stage 1 t3 turbine wheel its about 3mm smaller on the inducer and 2.5mm smalle ron the exducer then a standard stage 3 wheel but it uses a standard shaft size so the compressor can be swaped onto any t3 turbo
u could try it as is though im not sure if it would choke flow on the top end, its slightly smaller then what the rest of use run and i have no problems going to 8,000 rpms with the very slightly larger turbine wheel
Old 09-03-2012, 11:14 PM
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
Re: Its turbo time!
i do have a factory T3 off my hot-air buick. cartridge is in good shape too. .63 housing, not sure of the turbine size tho. id have to ask some buick guys.....
Rob? lol
Old 09-03-2012, 11:15 PM
project89's Avatar
Re: Its turbo time!
go to the turboforums and tell that to the guys running ebay turbos that run 8's and 9's the same thing, these turbos have been proven to be reliable
Old 09-03-2012, 11:16 PM
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
Re: Its turbo time!
i do not need to explain anything to you. offer up something useful or be gone
Old 09-03-2012, 11:18 PM
project89's Avatar
Re: Its turbo time!
Rob? lol
i belive the hotair turbo has the smaller turbine i used to have a hotair turbo.
i know my old ebay turbo we could swap the housings on and off from the intercooled gn turbos since they had the same size turbine. but i couldnt swap the turbine housing off the hotair turbo cause it had a smaler wheel
take the ex housing off and measure the turbine wheel im pretty damn sure its the same size as the turbine wheel on the 66mm turbo, if it is then u already have a nice .63 housing to use and i know u can buy .8x housings for the those turbos , i believe they came on the 301 carbed turbo setups and they are always for sale on ebay
Old 09-03-2012, 11:22 PM
project89's Avatar
Re: Its turbo time!
this is my old hotair turbo , does urs look like this ?
well except for the modified turbine housing anyway i drilled the internal wastegate hole then taped it to npt thread and screwed in a plug them machined it flat.
i also machined the turbine inlet so it was flat for easy of making a flange for it to bolt to. mine had the .82 housing on the turbine, i ended up building a diy turbine engine out of it
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
Re: Its turbo time!
well i just looked at it with the housing on, the exducer is roughly 2 1/16th" i can take off the housing tomorrow, but i dont have and verniers. just a tape measure.
Old 09-03-2012, 11:29 PM
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
Re: Its turbo time!
no thats the carby draw thru, i have the one from the 84-85's
just took a couple of pics here ya go
Old 09-03-2012, 11:31 PM
project89's Avatar
Re: Its turbo time!
pics arent showing
Old 09-03-2012, 11:35 PM
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
Re: Its turbo time!
uploader sux, trying to attach directly to page lol
https://www.facebook.com/media/set/?...3&l=535eb33f71
Old 09-03-2012, 11:41 PM
project89's Avatar
Re: Its turbo time!
that housing should swap right onto that 66mm its hard to tell though as im comming up with a 2 inch exducer on the 66mm turbo.
only way to know for sure is going to be to try
Old 09-03-2012, 11:44 PM
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
Re: Its turbo time!
id hate to drop any ching without being sure that i can swap it. at first i was thinking of swapping other housings/wheels on this one i have with new seals and a bearing but i looks more expensive
Old 09-03-2012, 11:46 PM
project89's Avatar
Re: Its turbo time!
just get the 3582 then as they spec out as true gt3582's
if u had a turbo with the stage3 turbine i.e a gn intercooled turbo id say go for the 66 and swap the wheel like fast is going to do
Old 09-04-2012, 12:00 AM
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
Re: Its turbo time!
im liking these...
http://www.ebay.com/itm/GT35-400-500...sories&vxp=mtr
http://www.ebay.com/itm/GODSPEED-T3-...sories&vxp=mtr
http://www.ebay.com/itm/GT35-TURBO-G...sories&vxp=mtr
Old 09-04-2012, 12:16 AM
project89's Avatar
Re: Its turbo time!
this one ships from china so dont buy it
the other 2 would be fine when u get one just verify the compressor wheel measures 61mm inducer 82mm exducer
Old 09-04-2012, 12:19 AM
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
Re: Its turbo time!
kewl man. im prolly gonna jump on it then, ill get in touch with the seller tomorrow after i wake up lol
*just emailed them now, couldnt wait*
Old 09-04-2012, 01:07 AM
project89's Avatar
Re: Its turbo time!
lmao
Old 09-04-2012, 04:34 AM
TGO - 10 Year Member
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: BBC 509 Merlin ii 9.6:1 pump gas
Transmission: ATI pro th350 sfi case. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: Its turbo time!
Awome joe. Cant wait to see the build. Yes im going to use the 67mm unit, and if I need to use the ex housing off the 57mm unit i already have.
Old 09-04-2012, 04:43 AM
project89's Avatar
Re: Its turbo time!
fast more then likley u will have to take the compressor cover backing plate and wheel off the 67 and bolt it to the 57 not just swap the housing
Old 09-04-2012, 01:30 PM
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
Re: Its turbo time!
just ordered this....
http://www.ebay.com/itm/271046032590...84.m1423.l2649
Old 09-04-2012, 02:36 PM
Street Lethal's Avatar
Re: Its turbo time!
Rob? lol
Wow, it's been a long time since I even looked at a stock Hot Air turbo charger from the 84/85 models. I have the measurements somewhere, I just have to find them. I can definitely tell you that they only flowed ~390 cfm at 15psi, which is horrific. Nice choice on the GT3582R by the way, now I can't wait to see this thing get done...
Old 09-04-2012, 02:59 PM
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
Re: Its turbo time!
yeah it didnt do much past 3K rpms and turning the boost up didnt do much lol. it had good bottom end torque tho. i have 3 day weekends from now on so i should be able to work on it once a week hopefully. just need to find a decent gas sipper beater, mustang doesnt like 550 miles a week lol
Old 09-04-2012, 05:23 PM
project89's Avatar
Re: Its turbo time!
when it arrives just be sure to pull the compressor cover and measure the wheel ebay turbos dont always turn out to be what there listed as.
Old 09-04-2012, 05:41 PM
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
Re: Its turbo time!
ill be sure to do that, thanks!
Old 09-04-2012, 06:45 PM
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
Re: Its turbo time!
im going to start shopping for related parts as well.
since all of my experience is with internal wastegate turbos, im not sure what size wastegate to get. i have an srt4 intercooler, but thats probably way too small, so im going to sell that one and find something better.
needed parts list...
1. intercooler
2. wastegate
3. exhaust piping, which i have some that i can use. so i wont need much. also going to flip the headers and see how easy it will be to modify.
4. 3" ex downpipe
5. oil feed/drain lines
6. need to configure wiring for $59
7. wideband
8. flange for turbo, v bands
9. flange for wastegate and piping
10. charge piping
11. alky
Old 09-04-2012, 06:56 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Its turbo time!
$59?? Sweet. I got some killer start up bins if you would want any to play with when the time comes. Just let me know.
Wideband? See if 14point7.com still has any slc-diy2 kits. Thats what I got and love the thing. http://14point7.com/SLC-DIY-2.php
Alky? Awsome, thats something I wish I would of used from the start.
You need to come back over to Ohio....
Thats a nice turbo though, anti surge caseing always helps, hopefully you dont ever need it though. You set that up nice and that blazer will probly smoke my Camaro...
Old 09-04-2012, 06:59 PM
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
Re: Its turbo time!
sweet man, ill def hit you up for some starter bins. also going to get the DIY2 from 14.7, i have the PP2 and love it.
Old 09-04-2012, 07:12 PM
project89's Avatar
Re: Its turbo time!
35/38mm wastegate will be fine
for the feeds and drians use pushlock hose and fittings, nexto the turbo this is prolly the most expspensive thing on the list
for the intercooler if buying ebay intercoolers dont buy one of the 24x6x2.3 cores they are to small
realisticly u want one of the large cores though being in ablazer i dont know how much room u have
i would use the 32x12x3 if u can fit it
the only bov i recomend is the rfl style bov
also let me know if u need a hand putting it all together , ive been looking for an excuse to load up the gf and the car hit up vegas
if u need help on any of the parts let me know and ill get u links
Old 09-04-2012, 07:31 PM
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
Re: Its turbo time!
i was thinking steel lines for feed and drains, gives it more of an OEM look.
well i going to start tearing it down on the weekend of the 21st, id have to look into escorting you on base, shouldnt be hard tho.
im going to look up intercoolers now....
Old 09-04-2012, 07:34 PM
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
Re: Its turbo time!
http://motors.shop.ebay.com/i.html?_...506.m270.l1313
Old 09-04-2012, 07:35 PM
  #42
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Its turbo time!
Just get the largest possible, mine was way too small for my app.
http://www.ebay.com/itm/Universal-In...ae65f6&vxp=mtr
There ya go,your links got plenty of them..lol
Are you going to put a ally kit together or buy one per made??
Old 09-04-2012, 07:40 PM
  #43
project89's Avatar
Re: Its turbo time!
try to get a bar and plate
this one is cheap and apears to be bar and plate if the picture is accurate
http://www.ebay.com/itm/FRONT-MOUNT-...sories&vxp=mtr
100 bucks reread the description it is bar and plate
this one is 95 bucks and apears to be bar and plate
http://www.ebay.com/itm/Universal-JD...sories&vxp=mtr
Old 09-04-2012, 07:41 PM
  #44
project89's Avatar
Re: Its turbo time!
hjere is a v mount that may be easier to mount in the nose of the blazer
http://www.ebay.com/itm/Universal-In...e586b1&vxp=mtr
Old 09-04-2012, 07:48 PM
  #45
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
Re: Its turbo time!
thats what i was thinking, i have no A/C condenser so it should fit neatly there, i can drill holes in the bottom too
Old 09-04-2012, 07:51 PM
  #46
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Its turbo time!
That's what I did, I know mines smaller but there is a ton do room left on my 27 inch wide IC
Old 09-04-2012, 07:52 PM
  #47
project89's Avatar
Re: Its turbo time!
from what i remeber form looking at my friends 2.8 blazer the v mount was a really good fit and made the routing of the charge pipe easier
Old 09-04-2012, 08:00 PM
  #48
project89's Avatar
Re: Its turbo time!
wastegate
http://www.ebay.com/itm/38MM-VR-STYL...4c891b&vxp=mtr
u can use brake lines for the oil feed, any parts store should carry inverted flare to npt pipe adapters , screw and adapter into the block, one into the turbo and connect with inverted flare tubing
for the drian use the pushlock stuff atleast -10
Old 09-04-2012, 08:03 PM
  #49
project89's Avatar
Re: Its turbo time!
http://www.ebay.com/itm/30-4100-AEM-...049f9e&vxp=mtr cheaper then the 14.7 unit and simple to install has extra outputs both simulated narrow band and 0-5 volt outputs for ecm
its what i use in my iroc
Old 09-04-2012, 08:17 PM
  #50
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
Re: Its turbo time!
going up for sale tonight...
https://www.facebook.com/media/set/?...1&l=f9b0fc6edf
Quick Reply: Its turbo time!
