Paxton is in
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
Paxton is in
Put the Vortech Plenum on the Stealh-Ram today with all the fuel rails and injectors, put the Paxton in place and will make fuel lines this week, not a bad day.
Re: Paxton is in
Yes I do, this engine is not even close to stock, I sent the unit out over the winter last year and had it rebuilt with upgraded parts, they are saying up to 8psi I plan to do 5-6 with the new impeller should be fine (per the rebuilder) so we shall see
I have gotten a few PM 's on this so let me list what I have in the motor
4 bolt main 350 .30 over (355) Probe forged dish top pistons (keep comp around 9.5)
Doug Herbert Cam - 500/500 intake-284 / exh-292 / lobe seperation 112 / 108 centerline / 1200-6000 powerband
Pro-comp Vortech aluminum heads 190/62/70 1.6 aluminum Roller rockers
Double roller chain
Howard lifters
Holley Stealth- Ram (Vortech) adj fuel pressure reg / Bosch 42 lb inj (Green Giant stage III)
Walboro 255 pump
Paxton Novi 6 or 8 lbs boost
4th gen rear with 3:42
Double roller chain
Howard lifters
Walboro 255 pump
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Re: Paxton is in
If it flows more than a stock engine it will make less boost.
That's a good plan. Probably make 350-400hp.
Waay too much injector IMO.
-- Joe
Double roller chain
Howard lifters
Walboro 255 pump
Double roller chain
Howard lifters
Walboro 255 pump
-- Joe
Re: Paxton is in
As for the 42 # injectors, probably on the high side but my new set up has them as well in anticipation of a VR4 upgrade to the supercharger. I don't anticipate any driveability issues, they just won't be working hard vs. the 30 #'s that were in mine when I bought it that were beyond maxed out.
Re: Paxton is in
I think 350-400hp is a little low unless you're talking at the wheels...mine with the combo in my sig but with 200cc Pro Topline heads (still 9.7.1) and about 6psi ran 12.20's...that's about 450hp at the crank and comparable to his setup.
-- Joe
Re: Paxton is in
Those injectors were put in based off what the guy dyno tunning the car sugested, he did not want to run out of injector when he sets the car up. We will see how she does, I think it will make 350 + HP with out the Paxton.
Re: Paxton is in
MPH was around 115, race weight was whatever a fully loaded Iroc with A/C weighs. Granted there are other considerations too like my 3.73's, suspension mods, 2800 stall at the time, etc that contribute to what my car ran but that's neither here nor there. My point is that his engine combo should be in the 350-400hp range without the sc. Not trying to hijackthis thread though, nice build!
Re: Paxton is in
I am also running a B&M Tranny
Re: Paxton is in
Had touble with my Alt. was sitting crooked, brand new from the dealer but it looked crooked. Spent half the day trying figure out why it was not plumb, took it apart 4 times and with it at the bottom it takes a bit. Finnaly went up to the dealer and found that the casing was not drilled true so it did sit crooked, 45 min after getting my new one it was installed and I was done for the day. Hope to start this up by next weekend.
Car: 64 Studebaker Avanti,67 ElCaminoTBI
Engine: GM 350 10.5:1 Supercharged
Axle/Gears: 3.54 posi
Re: Paxton is in
91droptop
I added a took my Paxton apart and added a hole at the bottom and one at the top, installed a pump and filter with a trans cooler. now I service it every 8000 miles otherwise do it every 2000 miles. It really really gets hot without the cooler.
My engine has 10.5:1 compression and wow, sent the paxton back and had it boosted as high as they could. Be sure not to over spin a paxton.
I added a injection system that would add part distilled water and methanol injection system to keep down the detonation. I also turned the maximum retard way up.
My next step is to setup and burn various chips, mileage, power, race.
The throttle was crazy touchy, chirped the tires every time I would touch it. So I changed it to a progressive rate, first 1/2 gas pedal moved the throttle 1/4. next 1/2 does the balance.
Dave
Dave
Re: Paxton is in
Do you have any pictures of the set up including the routing? I had planned to change it at every oil change, pretty simple to just suck it out. I have a meth set up all ready to go on mine, just need to install it, I have 4 hours of dyno time planned to get the car set up once it does hit the road, I do not plan to run the SC (no belt) until it goes on the dyno.
Benefits of Water Methanol Injection:
- Lower air temperatures by 50-200+ degrees
- Reduces cylinder temperatures by 200+ degrees
- Increase your 87-93 pump gas by 15-20+ points
- Increase horsepower safely by 10-15%
- Allows you to safely run more boost and timing
- Cools and protects the tops of your pistons
- Longer more stable combustion expansion and progression
- Removes carbon build up from combustion chambers, pistons and valves
- Reduces & helps eliminate damaging engine detonation & pre-ignition
- No need for expensive racing fuel or additives
Re: Paxton is in
When I first added the pump, small trans cooled, filter system, it was attached to the dipstick. (Notice the two rubber plugges on the dipstick, it has an in and out)
When i took the pump off and took it apart I went to the lowest spot that would clear the belts, the return is pointed with a screw driver touching the return hose.
I have A/C, P/S, Air Pump, Water Pump, SuperCharger, and Alt. (mounted backwards).
I also added wire tie system in the main inlet to the TPI throttle plate, 4 machine screws with holes in the bolt head to the large PAXTON Curve pipe. It was added do to an oversight.
I never half to floor it when I'm driving anywhere. But one day I really didn't expect this 08 vette to get the jump on me as I'm getting on the freeway. Well my Wife was with me and I floored it. I came around the vette and got on the freeway first, a few moments later at about 5800 rpm I heard a pop. My wife asked me " what was that" and I said, oh, about $600.00 dollars. The Paxton pipe blew off the intake and hit the alternator, the alt. Fan blade went into the radiator, so back home I went,
Re: Paxton is in
-Jim
Re: Paxton is in
I posted a bunch of pics/info in a post a while ago. Not a lot of people have vortec HSRs, maybe I'll get mine running again soon but my house has been taking precedence lately.
Re: Paxton is in
Ordered my kit today, I figure $300 is decent insurance for cooler temps and higher octane
The AEM Water Injection Kits are cost effective and user-friendly alternatives to very expensive water injection kits. The AEM Water Injection kits are a perfect way to reduce air inlet temps and increase charge density in boosted vehicles. These AEM kits allow the user to safely run higher boost pressures and suppress detonation allowing the utilization of more timing and boost. AEM's progressively controlled high-pressure pump draws water (or up to a 50% alcohol mixture) from the supplied tank (with integral fluid level sensor) to provide boost-dependant variable flow. Your water is fed into the intake system via interchangable nozzles for additional flow control.
An integrated system status light, which can be mounted on your dash, keeps you informed with easily identifiable error codes such as short circuit warnings, battery voltage problems, and low fluid alarms.
AEM also incorporated a failsafe that provides output to either decrease timing, or reduce boost if the system runs out of fluid or detects any error. Complete kits include:
One (1) OR five (5) gallon tank
Integrated fluid level sensor
Progressive control 150 PSI pump
Three different size jets
Dash mountable warning light
All hardware & hoses for insallation
Select 1 gallon or 5 gallon kit
toronto formula
11-10-2015 06:17 AM
