Its alive! 401 Twin Turbo version V2.72 :)
Car is idling alright now...still abit rich but working the tune. I got some things I need to do first before I can think about driving it tho.
Setup is same shortblock as before but with Speier Racing v2.72 heads (245cc heads, 330cfm 2.100" valve) and a big BRE custom hyd roller (Bauer racing - high 240's duration, .640" lift) ported vic E efi intake. I HAD AFR 195cc heads and a mild 233 deg hyd roller, .564" lift. SO huge change.
Exhaust isnt done but I hung some Dynomax ultraflo rounds, 3" inlet, 6" case in place of the bullets.. It was too loud with straight bullets which is odd, since with the smaller cam and heads it was quiet. I guess thats how much more air is moving thru this motor.
950-1000 rpm fast idle, I'll try to get it down to 850 or so but it doesnt make much vacuum ~10" Hg so I need to keep it fast.
http://www.youtube.com/watch?v=nwRHxh1smQU
Re: Its alive! 401 Twin Turbo version V2.72 :)
so is this the final version or just a beta lmfao
sounds good
sounds good
Car: 1991 Camaro RS
Engine: BBC 509 Merlin ii 9.6:1 pump gas
Transmission: ATI pro th350 sfi case. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Sweet...TT Camaro, nice.
Setup is same shortblock as before but with Speier Racing v2.72 heads (245cc heads, 330cfm 2.100" valve) and a big BRE custom hyd roller (Bauer racing - high 240's duration, .640" lift) ported vic E efi intake. I HAD AFR 195cc heads and a mild 233 deg hyd roller, .564" lift. SO huge change...
- Rob
Justin, did you go with another Bauer Camshaft, or is that the same one you ran with when you were running NA? By the way, how does the front look with the turbo's lowered and out of the way of the hood now...?
I got a new harwood 4" cowl to put on. I didnt want to go with a 4" but oh well, it was local and I picked it up to save on shipping. No chance to patch the holes in the other hood. It looks like a regular camaro with a big cowl hood now with the turbos hidden. I may have to paint the intercooler black to hide it to make it more "sleeper" lol but no hiding that exhaust note
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
time for a real rear end?
what kind of hp you expecting now ? you keeping the same turbo's ?
Figure on dyno jet the old setup was mid 700's. It was mid high 600's on a well known low reading mustang dyno here. New heads cam intake and hotside should be making bunch more power with an extra 1000 rpm. Should be interesting
hell yea , hope you got a suspension to put it to the grown . i can't keep the *** end of mine from going sideways with about 220 hp .lol
lmfao , thats got to be a great feeling . hell i'd love to have your ol setup ! i can't wait to turbo mine , i'm building a bottom end this winter .get vids from the track i'm guessing 8's ?
IF it can leave in boost and 60 foot hard, 8's shouldnt be a problem but I am not gonna have a trans brake in it for some time so this year it may just go 9's at 150+ just rolling off the line. We shall see.
it's hard to bitch about JUST 9's .lmfao
i wish i had those problems .
mines only about 220 hp an the *** comes around at will on dry pavement . tonight it rained an i drifted thru the neighborhood ! i can't imagine 400 more hp !
3rdgenparts
05-21-2016 11:50 PM
