Fuel system for super charger
Car: 89 Camaro IROC
Engine: 383 Stroker
Transmission: turbo 400
Hey guys. I'm going to be super charging my 383 stroker here in a couple weeks and was wondering what you guys run for fuel systems. I'm thinking about running an in line fuel pump system but was wondering if you guys just use the stock fuel pick up or if everyone is putting a sump pickup in?
Thanks for the help
steve
Thanks for the help
steve
Re: Fuel system for super charger
i did duel intank pumps in mine
twin aremotive stealth 340lph pumps
be aware once u hit a certian hp level no matter what u use for a pump or pumps u will be upgrading the fuel lines to a larger size in the car
Car: 89 Camaro IROC
Engine: 383 Stroker
I definitely plan on upgrading all of the fuel line to full braided ones. Will it work to have an inline pump with my set up
are u doing fuel injection or carb?
and if u mean adding an inline booster pump they are only as good as a single walboro 255
imho an inline pump shouldnt be used just get one of the new intank 340lph pumps and be done with it
Car: 89 Camaro IROC
Engine: 383 Stroker
Im running a carb setup and was thinking about using this fuel pump and line kit.
http://www.summitracing.com/parts/SUM-PUMPKIT7A/
What do you think??
What do you think??
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
Not totally finished, but Im using an Aeromotive Eliminator pump, with a sumped tank, 2X -10AN lines and an Aeromotive 13212 regulator
9192camaro
16
02-03-2019 12:21 AM
