Inlet tubing for Procharger
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
Im finishing off the tubing from the intercooler to the carb on my car, and have a couple of questions:
Firstly theres quite a bit of silicone pipe rather than hard aluminum pipe, will this affect anything? Most of the cars I've seen use only small sections at bends.
Also, looking at the picture, the pipe steps up from 80mm to 90mm for maybe nearly a metre. Will the bigger diameter cause a noticable drop in pressure, and therefore cause a problem?
On the picture, the pipework is only roughly in place with no clamps
Re: Inlet tubing for Procharger
Larger diameter just means your blower won't have to work as hard to make boost.
That IS a lot of silicone. It will work, but over time, it may cause a ballooning effect and cause the hoses to come apart.
gixxer92
05-18-2017 11:20 AM
no green
01-09-2016 09:22 PM
