Turbo headers
Old 08-30-2011 | 09:02 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Turbo headers
I know this question has been asked many many times but can anyone point me in a good direction or can make a nice set of turbo headers? My plan was to modify or make my own but with working 12 hr shifts I havnt found time to plan or make them. So please if anyone can help it would be great. Thanks
Old 08-30-2011 | 11:31 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Re: Turbo headers
i saw some cast iron sbc turbo manifolds on ebay for 600 per pair.......do a search ..most of the time you will be building your own since there isnt much of a market for turbo headers for 3rd gens
Old 08-31-2011 | 08:03 AM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: Turbo headers
The idea was to build my own but with working so much I hardly have time to think. Hopefully ill get some time so I can search but thanks for the input and if anyone else has some suggestions feel free
Old 08-31-2011 | 08:28 AM
ZZ3Astro's Avatar
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
Re: Turbo headers
Being an 87, single turbo makes it easy to keep your AC. I've got a lot of info on my single setup at http://mentalsocket.com/Iroc87/turbo1.html. Might give you some ideas for a layout.
Old 08-31-2011 | 09:41 AM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: Turbo headers
Ac is gone have most of the stuff ready for a twin setup but appreciate the info none the less
Old 08-31-2011 | 10:49 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Re: Turbo headers
theturboforums.com
Theres a guy there with name 10secgoal. He makes headers for about 600 bucks. really nice setups that should fit these cars and make a good base for a TT setup Hangs them over the front of the valve covers or pipe to whereever you want.
http://www.theturboforums.com/smf/in...topic=127269.0
Stainless works also makes a similar set
http://www.stainlessworks.net/produc...o-headers.html
Old 08-31-2011 | 11:24 AM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: Turbo headers
Thanks Orr knew it would be a matter of time before you chimed in. I'll take a look and see where that gets me. Just wish I had the time iv done most of everything else , makes ya happier knowing that you did it.
Old 08-31-2011 | 12:31 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: Turbo headers
Email was sent hopefully he will get back to me soon
Old 08-31-2011 | 02:07 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: Turbo headers
Yeah the DIY turbo stuff is awesome, I get a kick out of it when ppl ask me where I got my turbo stuff from, and I just say I fabbed everything.
But buying stuff is ok too, makes things soo much easier and faster sometimes. If i knew about those headers from turboforums, I likely would have bought them. I just didnt know about them til way after my build was done and even then, I still asked about pricing. I plan on redoing my setup to hide the turbos and those headers would be a nice start.
Stainless works are nice since they are stainless steel. Last forever and shouldnt crack if you dont hang a heavy turbo off them. 10secgoals stuff is similar design but cheaper due to mild steel. It should last too, as mine have been fine for the last 2 years. I willl be inspecting mine again this fall/winter when I tear it all down again.
Those header designs require you to pipe the downpipes under the headers which can be tricky with a long run of pipe. Snaking it through there is possible but getting it all to fit and install/disassemble without taking off the header itself could be a challenge. May need to segment the downpipe with a couple of flanges. My manifolds are nice in that you can go between rear 2 cylinders on each side. They just sit the turbos up way too high and forced me to cut the hood. I can modify my design easily to hang them like those headers above however. Thats my goal way down the road
Old 08-31-2011 | 03:16 PM
The_Punisher454's Avatar
Car: '74 Firebird, '84 vette
Engine: 454 twin turbo, 350 HSR
Transmission: 4L80E, 700R4
Axle/Gears: 9", Dana36
Re: Turbo headers
I like the way the turbo's stick half way out of the hood on your car, looks mean!
Old 08-31-2011 | 03:46 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: Turbo headers
Its great for heat management too. cant get a better heat extractor while idling and maybe even at speed. I've had alot of people tell me it looks mean and I think it does, but the look needs cleaned up some. I need to custom cut the hood abit cleaner to either follow the turbo shape or make it more uniform.
Old 08-31-2011 | 03:58 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Re: Turbo headers
If you want simple and fast then just modify stock manifolds. I posted a pdf file in another thread with a picture of some. If you want high HP then go with stainless header design.......hardest, expensive, slow to build.
Old 08-31-2011 | 04:00 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Re: Turbo headers
Your headers are 16ga or 18ga mild steel right?
I don't understand why people always are saying SSAC / ebay headers are thin walled junk and will crack. Lots of people at TTF and here have thin walled mild steel headers.
Old 08-31-2011 | 04:06 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: Turbo headers
I love the way yours stick outta the hood looks menacing . And the DIY stuff is great. Even if its not the fastest thing on the road you have a lot of people beat bc you can and did do it by yourself. I have yet to see pics of the headers but I think I understand how the downpipe will be ran but I was already planning on making part of the pipe in a segment for easier access
Old 08-31-2011 | 04:29 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: Turbo headers
16 gauge mild steel pipe. Now its not uniform thickness. At some points in the bend sections its thinner/thicker than other areas. But its a beefy rugged design and can support a crapload of weight on it since its part log/part header and the weight is distributed across 3 of the 4 primaries well. Theres alotof weld between the 2 middle runners that go into the main feed pipe so that adds alot of strength/ support.
I thought stainless steel had different heat expansion rates and could be prone to cracking. I havent seen many crack tho, atleast posted on any of the forums i visit. I dont know anyone really using that SSAC/Ebay stuff either.
The weld quality is likely the difference maker. If its not welded together well, then it may be prone to cracking more often. I've seen n/a headers crack due to poor welds.
Old 08-31-2011 | 04:53 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: Turbo headers
Id be interested in at least reading/seeing how you did the stock manifold. The idea crossed my mind but wanted to go the header way. Still it should be a good read
Old 08-31-2011 | 04:59 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Re: Turbo headers
Tools:
3" cut-off tool
60 to 90% ARC nickel rod
90amp capable ARC welder
drill
old grill or outside fire pit
Material:
1/4" or 3/16" plate for box
1/2" or 3/8" plate for turbo inlet
Steps:
Cut off original outlets and weld
Cut out plate to make box and weld
Pre-heat to 300+ degrees
Post-cool buried in speedy dry overnight
See the PDF I posted last week or the week before for pics of manifolds. Some people have simply used a MIG welder instead of the correct ARC process and filler rod.
Old 08-31-2011 | 05:58 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: Turbo headers
What is the rough cost of building your own headers? And where would you normally get all the stuff. Just pricing tho I have very little time
Old 08-31-2011 | 06:58 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: Turbo headers
I started with hooker flanges with stubouts already welded on. Thats the expensive way to start. 175 for the pair. I got maybe 275 in materials, which mainly was just buying a bunch of J bends in 1 3/4". needed 2 small pieces of J bend 2.5" pipe for main feed section. Then reducer cones for the transition for the rear primaries. T4 flanges, wastegate 38mm flanges. I"m not 100% sure how much I had in it. It may be abit less than 200 in materials but that sounds reasonable.
I figure 8 j bends for each primary tube, at 15 a pop. T4 flanges 60 a pair. 38mm wastegate flanges, 20 a pair. 2.5" j bend, 18 bucks. 4 transition cones from columbia river mandrel bend, expensive at 13 a piece, 52 bucks total. 1.75" to 2 then 2 to 2.5 to attach rear primary to main feed tube. Thats about 270 right there but i may have used less than 8 j bends.
My buddy then finished TIG/MIG mix the setup for 120. I just tacked and patched up any leaks I found after the finished welding. About 570 in a pair of these...not bad I guess. Now you can see where the turbo forums headers around 600 bucks would be a good deal but you still need flanges for turbo and such. If your better at welding than I, then save 120 or so.
IF you start with a bare flange, you likely can save even more money. A good thick flange only for the head should be less than 40 bucks i would think for each one
Old 08-31-2011 | 07:58 PM
project89's Avatar
Re: Turbo headers
check out my build thread if ur willing to run a v belt setup without ac i can build u a set of twin turbo headers pretty cheap, and i gaurentee they will outlast about 3 cars. they are built out of weld els and heavy wall tubbing
Old 08-31-2011 | 08:01 PM
project89's Avatar
Re: Turbo headers
Size:  66.4 KB Name:  IMG_20110808_203711.jpg
Size:  59.6 KB here ya go heres 2 pics
Old 08-31-2011 | 08:35 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: Turbo headers
Very nice , I am running what seen to be the same setup as you lol I'd b interested in you making some let me kno an idea of how much
Old 08-31-2011 | 08:50 PM
project89's Avatar
Re: Turbo headers
let me price up a set of sbc header flanges and the inlet flanges again and ill give ya a price
quick guess will be around 450 shipped for a pair of headers
Old 09-01-2011 | 09:25 AM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: Turbo headers
Alright, guy I work with has a set of cheap ebay headers he said he will give to me and modify to fit for nothing but I will eventually need a good set being I'm sure they will crack or what have you
Old 09-01-2011 | 12:23 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Re: Turbo headers
I wish I worked with people like that. If you end up not using them or take them off later on you can ship them my way.
Old 09-02-2011 | 08:19 AM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: Turbo headers
Ya its nice I worked with him my last job for 2yrs I left for college he went to a new place, ended up running into him. The headers come towards the front of the car a bit long, hopefully we can cut them back a bit figure out a way to 90 them and make room for a wastegate ill keep ya posted on how well it works and of course when the replaced ill be sure to keep ya in mind
Hotrodboba400
12-10-2019 08:07 PM
bamaboy0323
09-12-2015 08:14 PM
hdis2002
09-08-2015 03:52 PM
dmtz956
LSX and LTX Parts
09-07-2015 11:16 PM
Hotrodboba400
09-02-2015 08:28 PM
Quick Reply: Turbo headers
