What can I do for more power? ZZ4/TPI/P600B
Old 08-24-2011, 02:17 PM
89IROCZZ4's Avatar
I have a P600B procharger on a ZZ4 motor with a TPI intake. The fuel pump is a 255 and has 42 lb/hr fuel injectors. I'm curious to hear from you all that are "in the know" as to what you feel my biggest horsepower limiting factors are. I am thinking it is the heads, but am not sure. Would love to hear thoughts as well as how much extra power I could see.
Old 08-24-2011, 03:04 PM
ZZ3Astro's Avatar
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
Re: What can I do for more power? ZZ4/TPI/P600B
Lots of possibilities... didn't you just put this together recently? Have you tracked it or been on a dyno yet? I'm curious to see what kind of power you are getting since my new engine is a modded ZZ3 with a stock TPI intake. The only flow mods are a different cam (224/224 .530/.537 and 114 lobe sep) and some pocket porting on the heads. Other than that just supporting mods such as forged pistons (24cc dish), head bolts etc. I was shooting for 8.4:1 compression but couldn't find any .051" cometics so I went with .040" for about 8.6:1.
As for the heads & intake, they are a really good match in terms of port flow on the intake side. The biggest benefit you would see from a head swap is.. well two benefits I suppose: lower compression and better exhaust flow. Of course the latter assumes you have a good exhaust system and headers to back it up.
I'm expecting to make 550 rwhp with mine (let me rephrase, a 3800 lb car that runs 6.99 or better in the 1/8) and I'm willing to run up to 20 psi to get there. So I hope you don't have to change the heads to get where you want to go LOL.. or I might be in trouble!
Old 08-24-2011, 03:11 PM
89IROCZZ4's Avatar
Ah, I didn't think at all about the compression drop from the heads - that would be nice! I don't have a clue what boost I'm seeing at all. Heck, I haven't even felt its power in about 8 years. That answers your question btw - it was put together many moons ago. I just bought the car back from the person I sold it to If different heads/intake means a boat load more power, I may consider it in the not-too-terribly-distant future.
Old 08-24-2011, 03:12 PM
TGO - 10 Year Member
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Heads/cam/intake will all be limiters at one point and then the blower becomes the limiter as its a P600 blower. Right now I would say stock TPI is the limiting factor. Bigger runners/base or stealth ram or similar will yeild great power gains but I say work on the tune first and then go from there.
Cant tell where you are going if you dont know where you are at now.
Old 08-24-2011, 03:16 PM
89IROCZZ4's Avatar
I absolutely agree - this was more of a wishlist question for the future, more than me actually being ready to buy something now. As it all sits right now, I just can't wait to get her running right as-is
Old 08-24-2011, 04:04 PM
ZZ3Astro's Avatar
Car: 87 Iroc
All I can say is with enough boost, the stock intake can do pretty well. My friend ran 115 mph in the 1/8 with a stock TPI intake on some world product heads above a 383. Somewhere in the low 20's psi. That car has been my motivation for my project. In fact I'm using his oil feed line on my turbo LOL
83 Crossfire TA
01-03-2016 01:26 PM
my86bird
10-23-2015 12:20 PM
Gunsbee
09-07-2015 07:10 PM
Slush92RS
09-02-2015 08:56 PM
z28guy134
09-01-2015 11:50 PM
Quick Reply: What can I do for more power? ZZ4/TPI/P600B
