? twin turbo with a single turbo intercooler?
I have twin t3/t4 turbos on my 355 blow through. I aslo have a single turbo intercooler, can I wield a pipe for both turbos to feed into the intercooler?............Kind of like a Y pipe before the intercooler. or do i have to run a pipe from each turbo to the intercooler? Im only going to run 10 psi total
Re: ? twin turbo with a single turbo intercooler?
You can Y-pipe the turbos together before going into the intercooler and then just do single out to the carb hat. That works just fine.
What size are the compressor outlets? 2"? y them together into a single 3" into the intercooler if possible.
i have the same setup this is how i did mine
LT1Formula
10-08-2015 08:34 PM
355, build, carb, hat, intercoller, intercooler, intercoolet, pipe, single, size, sizing, t3t4, thirdgen, turbo, twin
