XFI292 in a boosted 355?
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
about to put a motor in my firebird and Im having second thoughts about using the XFI268. I kinda want a bigger cam, and have been looking at the 292 what do you think.
Motor
8.5:1
Patriot vortec 185 heads
Edelbrock Super Victor manifold w/elbow
LSx 90mm TB
P600b(for now)
xfi292 specs
Dur. 292/302
Lift .584/.579
LSA 113*
Motor
8.5:1
LSx 90mm TB
P600b(for now)
xfi292 specs
Dur. 292/302
Lift .584/.579
LSA 113*
Re: XFI292 in a boosted 355?
I personally feel its way too big. That setup would be better with a a 210cc runner if you wanted 292xfi. That cam will go to 7000rpm + in a 355. I see no reason to spin that high especially with just a 600 blower. D1sc may get more use out of it but still thats awfully high to rev.
How much power are you looking to make? I think there are better cams for blowers than the XFI series.
Engine: 383/LGX
I plan to add a turbo, just using the 600 because I have it. I'm using Comps camquest(which may be the problem) and that cam keeps poping up. What kind of cam specs should I look for? As for power not looking for to much anything over 500 I'll be happy with and that's when it's turbocharged.
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
Call them.. they will do custom grinds for the same price as the ones they have listed. I talked with Steve there and he recommended the following custom grind for my L98 head 350/turbo combo:
224/224 @ .050
.537"/.530" on 1.5 rockers
114 separation
This is around $297
224/224 @ .050
114 separation
This is around $297
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
the big problem with comp cam quest is if you dont have the exact flow numbers of your heads its just gonna spit something crazy out at you
IF your looking at 500-ish whp, you definately dont need that cam. That cam with the right heads could get you near 450whp all motor, let alone boost but its gonna spin up very high. Good combo for a miniram motor
The 268 would work well with a turbo and ok with a blower. Blowers typically use more duration on the exhaust side, 8-10 deg splits. turbos usually need closer to single pattern cams due to exhaust backpressure driving the turbine
Engine: 383/LGX
So it sounds like I should just stay with the 268 I have. I may email comp just to see what they recommend.
@scamaro355 I did put in the flow numbers, it recommends both the 280 and 292 xfi cams.
You will make ALOT more average power with the 268 and even the 280, as the 280 is the bigget cam i'd go with. THe more average power the faster the car will be. The 292 doesnt come alive until 4500 rpm and wont stop til over 7000. Thats spinning pretty high
codeysabatini
11-10-2015 04:07 PM
darwinprice
17
10-11-2015 11:51 PM
Dragonsys
09-25-2015 03:51 PM
