Best place for 60lb injectors
Been reading and found a few places for Siemens injectors...
http://fuelinjectorconnection.com/sh...&productId=233
and
http://cgi.ebay.com/ebaymotors/Sieme...item415bcf15c4
and
http://cgi.ebay.com/ebaymotors/Sieme...item35a3de7da1
Just wondering if anyone has used the 2nd or 3rd as I know some people use the FIC injectors already....
and
and
Re: Best place for 60lb injectors
We also carry 60lb and 80lb Siemen fuel injectors. Receive 10% off for tgo members.
If we can help in any way please contact us!
Ok, sorry bout that. For some reason the "performance injectors" category did not include the promo code. Will need to correct it. In the meantime I was able to update the 60lb Siemen listing. Give it a couple of minutes, then try it again. You should be fine. Sorry for the inconvenience!
no, why are you having a problem also? We have to list all products that are eligdable for a discount, for some reason the performance injectors were not included but I was able to correct the 60lb injectors right away. We are working on the others as we speak. Should be completed by tomorrow. Sorry for the inconvenience
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
HOLY SH-T !!!!!!! Thank you for the heads up....yes there is definitely something wrong. We are on it! Will let you know when it's fixed.
Ok, website is up and running again. Company that hosts it for us said there was a glitch in the software. Once again,, thanks for the heads up!
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
I am ready to order these, but had trouble with the website
SKU: d2-30
30lb Bosch corvette, mustang, dodge, camaro LT1 ...Special Offer!
High Performance!
I also did noy see a place for any promo code, thanks for the help
SKU: d2-30
High Performance!
the area for the promo code comes up during check out. Why don't you give us a call and so we can take care of everything.
516-492-6504
516-492-6504
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
do you have the correct web address? I just opened it without a problem
www.southbayfuelinjectors.com
Thanks to Julie, I will have my injectors by next week, you guys (gals) rock, thanks
MikkoV
09-09-2015 04:25 PM
