Back in Black, BBSDesigns is back!
#51
Car: GTA
Engine: Bone Stock 350ci HSR T-76 Turbo
Transmission: T56 6-speed
Axle/Gears: Stock
Re: Back in Black, BBSDesigns is back!
Sorry guys, Ive been dealing with all kind of things lately. Slowly but surely our website with product information, prices, pictures, etc.. will be up and running on August.
Thanks for all the support!!
Heads up: From our late designs we will be normally offering the following; V belt style single turbo header, serpentine belt style single turbo header, Street & Strip TO3 twin turbo headers and V6 single turbo header. The full race TO4 twin turbo headers and other custom projects (AU right handed 3rd gens, full race single turbo) will be offered only as special orders by request.
Ed
Ed
#53
Originally Posted by BBSDesigns
Slowly but surely our website with product information, prices, pictures, etc....
http://www.youtube.com/watch?v=0Wi8Fv0AJA4
#54
Car: 91 Firebird Formula
Engine: For me to know.....
Transmission: and you to find out....
Dan
#55
Car: GTA
Axle/Gears: Stock
lol I hate to call out Ed from BBS but whenever he says it will be done on this day..... always add on more time. Im sorry Ed but its true. Do a search on this board and you'll see for yourself. NOW... at the end of the day BBS has ALWAYS come through and never said "awwwww ****.. Im way too deep into this I'll just disappear.. nobody will ever find me."
Dan
Dan
I will open business again, the wait now means in-stock parts
#59
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
Transmission: T-56 fully built WOOHOO
#60
1 Post
Car: 92 Z28
Engine: Boosted LSX
Someone did just that. Chineese knocks offs are out there. They were all over ebay a few years back. Quality was sub part. OK enough for someone on a budget built. ( i bought each sbc turbo setup that was on ebay) the crossover wasnt the best. but the kit was a replica of BBSD single turbo setup.
Im sure the wait will be worth it. Ive had a real set of Eds single setup and the knock off.
#64
Car: GTA
Axle/Gears: Stock
We never really stopped making the turbo headers, but we did close the online shop. From time to time customers would chime in and requested something turbo related from us and we did make turbo headers and the occacional complete kit. Since the company moved on to and concentrated on other stuff we left the turbo related business as secondary business due to the blow we received after the knock off's a few years back, but there are always customers looking for the real McCoy, looking for a part well made and long lasting and there is where we come in.
#65
Car: 87 GTA
Axle/Gears: 3.42 posi
What is the difference in your th001 and th002 headers? On your website it says for v-belt and serp but the pics show both on serp setups. Thanks for any help.
#66
Car: GTA
Axle/Gears: Stock
The V belt style header will fit on engines equipped with serpentine belt style powered accesories, but the A/C compressor must be removed, no A/C.
The serpentine belt style header can be used on both the V belt and as the name implies, on serpentine belt equipped engines with the A/C compressor in place, although it does not make sence to use the serpentine style header on a V belt equipped engine due to the tight fit and limited turbo size.
I personally preffer to replace the serpentine belt setup for V belt if A/C is going to be used.
If you have anymore questions let me know.
Ed
#67
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, LT1
Transmission: TKX, 4L60E
Axle/Gears: 3.42, 3.23
Hi,
Ed
Ed
Are they same on the header for the other side?
-- Joe
#68
Car: GTA
Axle/Gears: Stock
The primaries are approximately 1 3/8"-1 7/16"ID and are port matched to the stock square exhaust port found on most SBC heads.
Since we are only offering only the turbo header on our online store, it's up to the builder if he or she want to use the stock manifold or a header on the drivers side to complete the hot side, hence we dont know the driver's side primary size.
All our headers are TIG welded and made of thick 1/8" wall steel pipe tube, guaranteed for life! To this date still not one single header we've made has cracked or broken on our customers rides... Not a single one
Any more questions, just let me know.
Ed
#69
Engine: LC9, LT1
Hello Joe,
Ed
Ed
-- Joe
#70
Engine: 5.7tpi 350,
Special Request Turbo Headers
BBSDesigns custom application turbo headers and kits, for special applications; Full race turbo headers, quad turbo headers, AU spec turbo headers, etc... BBSDesigns can build that special application setup for a particular need. For information and pricing please contact us.
#72
Engine: LC9, LT1
-- Joe
#73
Car: GTA
Axle/Gears: Stock
We normally preffer to fabricate our headers from the jigs we already have and do occacionally make custom builds and or special requests, but this do require hours of figuring out stuff and tend to be more expensive.
Ed
Ed
#75
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
I have one of the serpentine headers and was wondering if a PT88 or S480-T4 would fit on this header?
Do you have any pics of your headers with turbos larger than a T76?
Thanks!
Thanks!
#76
Car: GTA
Axle/Gears: Stock
We are currently offering the turbo headers only, passenger side for single setups and both sides for twin turbo. No crossover pipes or other exhaust pipes.
For more information checkout our store;
http://bermudezcustomdesign.ipage.com/store/page4.html
#77
Car: GTA
Axle/Gears: Stock
No we have not installed a bigger turbo than a T76 frame turbo on our headers, sorry. Serpentine headers are limited to a 60 A/R size on the compressor side, unless you make some kind of modification to the valve cover and others, is a tight fit.
#78
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Correction, I just looked and I have the v-belt header.
Do you have a turbo larger than a T-76 that you could mock up on your header to see if it fits? I have a GTA also with the stock hood. Just wondering.
#79
Car: GTA
Axle/Gears: Stock
Unfortunately no, we have not test fit with a bigger turbo than a T76.
The V-Belt style header includes a standard TO4 turbine inlet flange, T76's fit perfectly.
Ed
Ed
