What dizzy and plugs to run with my F1???
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I have a pro billet dizzy with a Digital 6 Plus box and a BTM box attached to that. My motor is a 390 blow thru setup.
I assume I am all set with my timing pieces, but just wanted to double check.
Doesn't seem like I will be needing a vac adv. dizzy or anything like that seeing as how I am boosted.
Also what plugs would you guys run, or how do you think I should decide?
I will be making around 650 WHP I would think. Maybe a little less. The car is a daily driver that I will be taking to work. Sort of just a weekend toy that I want to be able to drive to work. Car will NEVER EVER see the track, maybe years later when I have rebounded from the cost of the motor.
People seem to like autolites that are cheap and swap them out every year......opinions welcome.
Thanks guys.
Thanks guys.
Re: What dizzy and plugs to run with my F1???
i use autolites no problems just start out with a cold heat range till you get an idea where that motor wants to run then you can move up 1 heat range at a time this way if something happened it would be with a cold plug would just foul it out rather then burn a piston with to much heat range
Engine: LS3
Great. I think I have a place to start at least.
Thanks.
Thanks.
Engine: LS3
Interesting. I too would like the plug to die off before anything else in the motor went, but I think I will stick with conventional autolites.
You are not supposed to run platinum correct. Gets hotter than a standard plug and promotes detonation correct?
Car: 1990 formula
Engine: 433 sbf + turbos
Transmission: powerglide
Axle/Gears: fab9, 3.50
Can you turn an F1 down low enough to make 650 on a 390" engine?
Engine: LS3
I am talking about wheel HP. Not motor. If I make more power I don't think I will be complaining.
This is definetly a better problem to have than my past of not having enough power.
eightsixseven
08-14-2015 03:09 PM
