Procharger BOV... Standard or Race?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1985 pontiac trans am
Engine: Procharged 5.7l
Transmission: t-56
Axle/Gears: stock 9 bolt 3.71
So After a long long time of dealing with crappy BOV on my procharged 5.7l Ive decided to give the procharger one a go. The kit was assembled from pieces, due to the custom nature of my setup. The question is should i just use the Std surge valve, or should i spend the money and go full race version. Im currently running at a gauge reading of 13psi at the intake plenum. The boost runs through a series of 3" pipe and a large front mount intercooler. What is everyones take on this?
Re: Procharger BOV... Standard or Race?
If you're making anything over 550-600 RWHP, go with the Race Bypass Valve. Otherwise, the ProFlo valve would work just fine.
Transmission: t-56
Thats good to know. It was last Dyno at 460rwhp with the bad BOV. The race one is not cheep, and if i dont need it, id rather spend the money on other things i need.
Gunner242
12-25-2015 04:49 PM
