Turbo 1991 z28 with A/C - Turbonetics tc76
Old 08-12-2012, 09:18 PM
  #351
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: Turbo 1991 z28 with A/C - Turbonetics tc76
on mine the cage is not attached to the thermistor at all. My only concern would be the drag on the sensor in the air stream, So I may add some epoxy to support it just in case
Old 08-12-2012, 09:37 PM
  #352
project89's Avatar
thats what i meant the cage helps support it in the airflow stream so it cant flop around and possibly break off and be ingested by the engine
Old 08-14-2012, 11:31 PM
  #353
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Well I reattached the collector that was missing all 3 bolts, new plug wire, welded up some new exhaust hangers so it's rattle free, and welded up a few pin holes also. Started the car, still had an exhaust leak.... back 3 bolts on passenger header were loose, tightned them up, no more leak - the car sounds freaking great (quiet!). BTW copper RTV is some badass stuff, I use it for header to head gaskets (and all other gaskets) and it sealed right back up once I tightened the bolts back up, I thought it would have burned off.
I also moved the fuel line hanger so my torque arm doesn't hit it anymore, and replaced the crappy vinyl BOV and WG reference hose with thick wall fuel line.
All I can say is WOW what a difference it all made, the WG is not fluttering and boost sees pretty constant, the BOV now open in one big badass PSHHHH-WOOOOSH every time the throttle closes (even at idle when I rev it), and the it seems like the car is rattle free. I'm in a great mood with the positive progress that I can feel rather than see on the data log only, no I have the itch to turn up the boost some more this week!
Old 08-15-2012, 04:31 AM
  #354
TGO - 10 Year Member
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: BBC 509 Merlin ii 9.6:1 pump gas
Transmission: ATI pro th350 sfi case. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Awsome man. Turn up thee boost!!
Old 08-16-2012, 10:36 PM
  #355
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Ok so I burned a new tune and my computer was on low battery, it didnt work right and ran like crap. reburned teh same new tune plugged into the wall and it's way better. Here is a plot of the data from the run, yeah only 4k rpm my tach is way off I though I was at 5600.
I changed the WGDC from 45 to 65 and boost is MUCH more steady, but it feels like my brakes are on at WOT, or the engien can't breath enough... I'm not sure if thats the solid bosot or something changed in the tune that I'm unware of... I'll try more RPM and boost
BTW thre was zero knock on the pull in the plot
Old 08-17-2012, 01:05 AM
  #356
project89's Avatar
is that 32* total timming i see under boost?
thats ummm brave
Old 08-17-2012, 04:33 AM
  #357
fasteddi's Avatar
Car: 1991 Camaro RS
Zero knock with 32* of timing, Im curious if you have offsets that make it so there really isnt that much timing being produced. I.E there is a intake temp Vs timing area in $59. I noticed on mine that it was set at -3.5* for the whole table. I changed that so that there was only a timing offset at 150+ temps insted of the whole table.
Old 08-17-2012, 04:56 AM
  #358
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
That's normal timing for these heads and boost... and it's true timing, verified multiple ways
Old 08-17-2012, 06:18 AM
  #359
project89's Avatar
that just seems so high to me , its a zz4 crate motor right
Old 08-17-2012, 11:34 AM
  #360
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
I ran close to 41* na with no issue, 32 is quite a step down
Old 08-17-2012, 11:43 AM
  #361
TGO Supporter/Moderator
anesthes's Avatar
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, LT1
Transmission: TKX, 4L60E
Axle/Gears: 3.42, 3.23
With electronic advance? That's almost retarded on the previous cylinder!
-- Joe
Old 08-17-2012, 12:26 PM
  #362
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
113 heads take alot of timing. Low 40's for cruise and 38 at wot for one car i did.
How much boost are you at now? I have 28 deg so far at 6 psi and 12.5 air fuel no problems but i am bringing that air fuel down to 11.8-12.0 here soon. I may try 30 deg timing as well
Old 08-17-2012, 01:00 PM
  #363
anesthes's Avatar
Engine: LC9, LT1
42 or so degrees is about the max you can do before you risk striking the previous cylinder though..
-- Joe
Old 08-17-2012, 02:53 PM
  #364
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Yeah most bins seem to have a cap at 41.8 or so but still those heads want all they can get at cruise and even wot takes more than you'd expect
Old 08-17-2012, 04:06 PM
  #365
anesthes's Avatar
Engine: LC9, LT1
Right, but you can't with an electronic dizzy. When the rotor is in the dead center of two terminals, which one will the arc hit?
You'd have to put a whole lot of initial advance into it first, but then you risk having cranking problems, or hitting the next cylinder.
-- Joe
Old 08-17-2012, 04:27 PM
  #366
project89's Avatar
-- Joe
hmm that might be why im having such issues with my tt iroc at idle.
due to my est bypass configuration i have to run the timming very retarded or i have very bad cranking issues, once the motor hits 450 rpm it advances to 30* and i get this miss i just cant figure out
ill have to setup the coil on a relay and toggle so i can bump more initial in it and not have the starting issues im having
Old 08-17-2012, 05:25 PM
  #367
fasteddi's Avatar
Car: 1991 Camaro RS
Boost is a different story then a N/A engine.
But what ever the thing likes..give it to her. If she like that timing and you dont have KR and egt's out of wack then let her rip!
Old 08-17-2012, 07:02 PM
  #368
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Aftermarket ignition box with start retard function helps alot
Old 08-17-2012, 08:26 PM
  #369
project89's Avatar
actually i can prolly do that with my megasquirt im thinnking if i set the est bypass settings to 100 rpm i can just add a row in my ignition map around 300 rpm and retard the timing that way, once the motor fires and gets over 550 rpm i can bring the timming back were i need it for idle
that should allow me to set the initial more advanced and get rid of my missfire if that indeed is my issue, which i think it is caus eif i retard the timing at idle my miss goes away but idle quality deteriorates
Old 08-24-2012, 11:36 AM
  #370
RBob's Avatar
Car: check
Engine: check
Transmission: check
The min/max timing values in the BIN confuses a lot of folks. What it really is, is the limit that can be programmed into the distributor or DIS. On a distributor it prevents cross firing as Joe mentioned.
However, the initial (base) timing needs to be taken into account when looking at the at-crankshaft timing. The more initial timing there is the more at-crank timing can be had. With the stock TPI initial of 6* BTDC, and the 42* that can be programmed into the distributor, up to 48* of at-crank timing can be had.
RBob.
Old 08-24-2012, 11:42 AM
  #371
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
For some reason i was thinking that was the limit the ecu would send to dizzy and the motor would end up only seeing that amount but what you say makes sense.
Old 09-09-2012, 06:49 PM
  #372
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
well I kinda have an update...
I got cut off (I was doing 25MPH) and had to crash up a steep driveway to a stripcenter to not wreck my car scraped some paint off my front lip, down to the plastic which REALLY pisses me off, but thats the only damage so it's not the end of the world. I'm debating a full color change on the car and new wheels but thats down the road, I need to get the tune right first.
On a positive note I have a list of things I'm going to check when I get a chance.
1. cold side boost leaks - I have a suspicious coolant leak by #1 at the head/intake interface.
2. true timing - I'm gonna put 5psi to the MAP sensor with compressed air and check with the timing light to see what it's really doing at 5psi and wot and make sure my "5psi" form the map is true, would rather do it on a dyno but I'm gonna give neutral a shot as it shouldn't really make a difference
3. fuel pressure check
4. check the valve train mechanicals
5. e-brake cables were moved when I did the new exhaust, I'm wondering if they are getting pulled by the suspension when I go WOT and the rear end moves...
if it's not that.... hell I don't know what I could be. Anything else I should check fellas?
Old 09-16-2012, 09:50 PM
  #373
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Made some real progress today:
Checked cold side boost leaks - First I found a connector totally disconnected so I though that was my problem, but it didn't make much difference when fixed. I then put 15psi to the throttle body, and found some more leaks. My charcoal can was directly connected to manifold vacuum, which now sees boost so that was a big leak. Also had a small leak on a vacuum hose to the brake booster. Fixed both of those. The shaft the throttle blades are on leaks form both sides but barely, and thats just a leak you have to deal with I assume... Finally I could hear air making it's way SOMEWHERE in the motor but I don't know if that was through blown intake gaskets or into a cylinder with both valves partially open and flowing into the exhaust. So I pulled the valve cover to make sure nothing was broken, it wasn't. Then I said screw it and pulled the dizzy and intake. I don't see any leak areas except between 3 and 5 the gasket was off to the side of the small dividing area.
the dizzy has lots of corrosion in it so thats not good:
I'm going to pull the other valve cover to make sure everything is ok, then new 2106 intake gaskets, and button it back up. I'm convinced the intake gaskets were leaking since I am getting huge crank case pressure at only 5 psi considering compression in the two cylinders I checked was 135 and I'm making less power than NA with out blow by issues. I have no vacuum lines hooked to the crank case, only 5psi, decent compression...
EDIT: also the intake bolts were really loose, required very little TQ to break them free, maybe the gaskets weren't compressed very well
Old 09-17-2012, 08:50 AM
  #374
vwdave's Avatar
How the hell did that thing run?
Good to hear you found all these....issues and resolved them.
Old 09-17-2012, 11:58 AM
  #375
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
I'll tell you how it ran, it ran like ****!!!
yeah me too, hopefully this resolves my pressurized crank case issue. If it doesn't the motor is coming out, I'm not doing head gaskets on this POS i'll just start over with a new motor since this ones not ideal for boost anyways
Old 09-17-2012, 04:59 PM
  #376
DIGGLER's Avatar
did you mean between 5 and 7? 3 and 5 arent next to each other...
if it is 5 and 7, i think you may have found your oil on the #7 plug culprit.
Old 09-17-2012, 05:09 PM
  #377
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
EDIT: Im a retard, yes I meant between 5 and 7. I assume the fast it could be letting oil into the cylinder could also mean it was letting boost into the crank case?
Old 09-18-2012, 12:51 PM
  #378
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
well the intake gaskets in my motor are felpro 1206's, and the stock HSR and Al L98 heads both call for 1205's, so maybe that had an effect on it. I'll be replacing them with 1205's.
Old 09-18-2012, 01:44 PM
  #379
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
well i feel pretty stupid right now, here is how my plugs were on the dizzy, 2&4 were switched and 5 and 7 were switched... I dont know how it even ran like that!
Attached Thumbnails Turbo 1991 z28 with A/C - Turbonetics tc76-aaaaa-dizzy-wronge-order.jpg
Old 09-18-2012, 03:27 PM
  #380
The_Punisher454's Avatar
Car: '74 Firebird, '84 vette
Engine: 454 twin turbo, 350 HSR
Transmission: 4L80E, 700R4
Axle/Gears: 9", Dana36
The most useful number I ever memorized early in life was the chevy (pontiac too) firing order. Countless times when I have heard something running wrong or not at all, one of the first things I check is the plug wiring.
Old 09-23-2012, 11:52 PM
  #381
Homer23's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: T-56 w/hurst short throw
Axle/Gears: unknown
At least you found out what the problem was. After reading your whole thread I think I need to start planning a twin-turbo build for my Camaro (and making me look bad about being lazy about a lousy trans fluid change). I just bought a turbo build book for some much needed info off ebay.
Old 09-24-2012, 06:10 AM
  #382
project89's Avatar
lmao its a sbc it will run even if u leave parts out of it, usually a crossed plug wire is easy to hear when the motor is running.
but ive seen a sbc that ran with the timing 180* out , figure that one out
Old 09-24-2012, 07:42 AM
  #383
vwdave's Avatar
Ive seen a TDI beetle run with the injection timing 180* out once. Still dont know how.
Old 09-24-2012, 04:33 PM
  #384
DIGGLER's Avatar
i got a 5.0 mustang to run with the ignition 180 out and THEN the wrong firing order. lol
Old 09-25-2012, 02:12 PM
  #385
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
yeah I though it sounded funny, but going from not hearing it run in 1.5 years to hearing it through the turbo with a new tune that was really bad to start with, made it hard to tell it was a mechanical issue not the tune
once I got the tune close I knew something was wrong, so I started looking at stuff, I'm just glad the intake gaskets are bad too so it's not wasted effort.
I wont get a chnce to work on it until the 5th or 6th, I hope to have it back together by that sunday but we'll see...
I too have seen my share of crazy ignition wiring jobs run, bought a v6 mercury two stroke outboard that was running on 3 cylinders but I couldn't tell untill it was loaded. two wires from the switch boxes were backwards and one coil dropped out once it loaded up. Neutral it would rev to the moon and idle like nothing was wrong...
Old 10-01-2012, 06:37 PM
  #386
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
Hey Alex, quick question for ya! Going back to the IAT sensors from page 7...Where do you have your sensor mounted? Right now mine is in the port in the bottom of the plenum on the HSR. I was thinking about moving it out to the charge piping to help avoid heat soak from the intake/plenum, but maybe that doesn't matter. I also think I have one of the metal fully enclosed IAT sensors right now and I am thinking I will get one of the open "caged" sensors you showed a picture of to help keep air temp readings more "instantaneous" if you will...Just curious on how your setup is done. Thanks!
-Paul
Old 10-01-2012, 06:49 PM
  #387
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
My IAT is in the bottom of the plenum, I think it would be a good idea to move it to right before the throttle body, even with the open one it get heat soaked bad. I plan to cut the metal cage off of mine and use an epoxy to reinforce it from the bottom, and move it to the charge pipe eventually. There is a plastic "caged" one out there thats the best but i found this local and bought it. I would DEFINITELY get an "open" IAT sensor - cost the same and are 100000x better when comparing response time
Old 10-01-2012, 07:06 PM
  #388
quadgoat's Avatar
Car: 1992 Firebird
Good deal, that confirms my thoughts on the matter! Just gotta figure out how to mount it in the charge piping and I'll be in good shape :-P
-Paul
Old 10-08-2012, 10:03 AM
  #389
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
I would leave it in the plenum as long as it's the sensor with the plastic cage.
You'll get the most accurate reading of the incoming air temp. Previously, I welded a bung in the charge pipe to relocate the sensor right before the TB. I didn't really notice a difference so when I switched to the First intake, the IAT sensor was left in the plenum.
Old 10-08-2012, 11:04 AM
  #390
Six_Shooter's Avatar
Transmission: 5-speed/T-5
I have mine in the plenum, and while it does read hotter while cruising the temp drops almost immediately when I open the throttle, so that indicates that it is reading the air temp, not being heat soaked, as one might first conclude. I'm using the open element sensor as well. I would rather the ECM see actual air temp, not what looks good to me.
Old 10-25-2012, 08:35 AM
  #391
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
thats a very good point.
so i have the NKG-FR4 plugs now, I assume I should go a step colder with a 0.035" gap based on what the interwebs say, but which plug? I'd like to stay with an easy to get locally plug
Well this weekend will be telling, gonna throw the intake back on, make sure I don't have any bad plug wires, new plugs, put a new rotor/cap on, fix all the boost leaks, and see what It does. time permitting I may build a catch can setup or something, we'll see. I have all of this coming:
Old 10-25-2012, 03:44 PM
  #392
Homer23's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: unknown
Is a catch can supposed to catch oil?
Old 10-25-2012, 03:52 PM
  #393
fasteddi's Avatar
Car: 1991 Camaro RS
Yes. Its basically a accumulator. Seperating the oil and letting that stay in the tank. insted of either being blow out or dumped straight back into your intake via pvc valve system.
Old 10-27-2012, 09:38 PM
  #394
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
made some progress today
cleaned up the surfaces:
gaskets in place Name:  IMG_20121027_164817.jpg
I used copper just RTV instead of the rear valley gasket, and coated both sides of the front valley gasket with RTV
lower intake an dizzy back on.
I have the upper intake and valve cover on now too but no pics, just have to put in new plugs and hook up the hoses/wires
Old 10-27-2012, 10:01 PM
  #395
fasteddi's Avatar
Car: 1991 Camaro RS
Nice!
Old 10-28-2012, 12:19 AM
  #396
whitedevilTA's Avatar
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Hope you get the issues figured out. Really curious to finally see what this things gonna do! I managed to get mine running, tuned, and blown up before you got yours figured out lmao. Hope you have better luck, but my luck has never been known to be very great.
Old 10-28-2012, 01:29 AM
  #397
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
if this does not fix my crank case pressure issues i'm gonna have to say bad rings are to blame since EVERYTHING ELSE has been gone through. So I MAY have beaten you to blowing it up LMAO!
Tomorrow will be interesting and I have my fingers crossed, but I'm not holding my breath
Old 10-28-2012, 01:41 AM
  #398
Car: 1986 Trans am
Engine: 5.3 LM7
It was pretty noticeable when I lost the ringlands on my pistons. I have an open breather on my oil cap and after the car started hesitating a bit, I popped the hood and my breather filter was oil coated, and you could literally see the compression "chugging" out of it in the form of steam. What are the symptoms yours is giving you? Are you getting compression out of the breathers? If so, I would almost 100% say it's a piston/ring related issue (but hope thats not the case!)
Old 10-28-2012, 01:53 AM
  #399
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
breathers pushing oil out when in boost, not too terribly much but it's not right... does not do it at idle only when I really get on it. I don't have blow by at idle, and not much free revving with no load/boost just a tiny amount. i had a dual PVC to manifold setup before so Im not sure if its new, from boost, or i have always had some blow by.My intake was COATED with oil inside when I took it apart I my just need a catch can, or I may have bigger issues.
and I had 4 plug wires wrong, huge plug gaps, and a bad cap/rotor SO that wasnt helping LOL
Old 10-28-2012, 10:16 AM
  #400
vwdave's Avatar
Why did you use Copper RTV for the china walls?
Quick Reply: Turbo 1991 z28 with A/C - Turbonetics tc76
