tbi with a turbo ?
Old 11-29-2010 | 05:31 PM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
tbi with a turbo ?
can it be done ? does it need anything special done to it ? how much boost can you push thru it ?
Old 11-30-2010 | 10:06 AM
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
Re: tbi with a turbo ?
have you tried the search button? this has been covered before. If you cant find all the info you need on this website, there is a great search engine called google.
Heres a link
http://lmgtfy.com/?q=turbo+tbi
Old 11-30-2010 | 02:07 PM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
[quote=noboostnogo;4748848]have you tried the search button? this has been covered before. If you cant find all the info you need on this website, there is a great search engine called google.
Heres a link
http://lmgtfy.com/?q=turbo+tbi[/quote
if i could of found the info i'm looking for i wouldn't have made a thread .
theres no need to such a ****ing smartass ! ***** !
Old 11-30-2010 | 03:19 PM
83 Crossfire TA's Avatar
Otherwise, if you have a specific question...
Old 11-30-2010 | 04:22 PM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
i believe i ask a couple questions in the begining ...
Old 11-30-2010 | 05:27 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Yes. No. A lot. Next?
Old 11-30-2010 | 05:55 PM
Ronny's Avatar
you need to swap out ECU and MAP sensor and increase fueling and obtain a WB02 with controller and learn how to tune bigtime. other than that it is quite simple.
Old 12-01-2010 | 02:42 PM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
i got a wideband i'm gonna use mega squirt to tune with . this ain't my first turbo project jus not sure about using the tbi . i know to use a carb you have to have a blow thru carb i was wondering if the you need anything special done to the tbi aside from the abvious fuel system upgrades ( regulater with the 1-1 an an bigger injecters } i guess my main question is can the tbi stand the forced air without leaking ?
Old 12-01-2010 | 04:09 PM
Ronny's Avatar
Procharger has marketed TBI blowers for years. Turbo should be no different. May see some leakage at the shaft bushings. no big deal.
Check out Aeromotive for the reg # 13301? 1-20 lbs fp spring and another spring 20-60 lbs. vac/boost referenced.
Old 12-01-2010 | 05:54 PM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
cool , thanks for the info .
Old 12-01-2010 | 07:33 PM
Thank you, or he could have just looked in the other thread from the same day or day before or searched...
92firebirdguy
09-01-2016 08:53 AM
New2Chevy
09-28-2015 01:35 AM
Glowsock
09-12-2015 12:09 AM
92rsvortec350
09-10-2015 11:54 AM
Wylecoyote08
09-08-2015 09:26 AM
