Single Turbo Iroc update 4 - finally goes 7's on stock TPI 5.7
#51
Re: Single Turbo Iroc update 4 - finally goes 7's on stock TPI 5.7
Freaky - At 13 psi it goes from around 13 degrees @ 3100 to around 19 degrees @ 5200.. I'm not 100% sure where I left off at because it's been about a month ago since I went into the tune.
Draconic - The plan is to stay completely stock on the intake parts, although I did some minor porting to the plenum right behind the throttle body (removed the 'fingers' behind the TB). Heads are definitely going to get changed, it's mainly a question of iron vs aluminum at this point. Vortec heads are a possibility which of course includes an intake lower upgrade. Not a bad trade-off and I still retain a stock upper. Aluminum heads would be nice though to offset the weight I've added with the turbo component. Mainly I want heads that will improve exhaust flow a bit. My hope is to build an engine that makes 300 crank hp without the boost. Then it should be "easy" to make 500 with a turbo. All this with a goal to stay close to 20 mpg.
http://www.jegs.com/i/Edelbrock/350/60899/10002/-1
#52
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
True the cost approaches aluminum heads, but it's still considerably more. Those heads from Jegs are not centerbolt.. it costs about $300/pr more to get those specs in a centerbolt head. That's basically $1400 and I can get AFR 180 Eliminators for that. However you make a good point, as the cheapest brand new Vortec heads I can find are $600/pr assembled, then you add the intake and you're at $1000. The AFR makes a lot more sense in that light. Guess I need to add another $500+ to my budget
![Wink](https://www.thirdgen.org/forums/images/smilies/wink.gif)
#53
True the cost approaches aluminum heads, but it's still considerably more. Those heads from Jegs are not centerbolt.. it costs about $300/pr more to get those specs in a centerbolt head. That's basically $1400 and I can get AFR 180 Eliminators for that. However you make a good point, as the cheapest brand new Vortec heads I can find are $600/pr assembled, then you add the intake and you're at $1000. The AFR makes a lot more sense in that light. Guess I need to add another $500+ to my budget ![Wink](https://www.thirdgen.org/forums/images/smilies/wink.gif)
#54
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
something else to consider are the summit heads, they're reboxed Brodix IK series
http://www.summitracing.com/parts/SUM-162109/
#55
Car: 87 Iroc
I don't plan on running a very aggressive cam so that wouldn't be an issue. Those heads look good but those too are perimeter bolt like the other link. I don't see a centerbolt version of those.
Got the car running happy again - the problem did end up being what I suspected. Oil fouling on #7 sparkplug. It's been a problem on this car since I got it so nothing new. Can't wait to get inside this engine and see what is leaking where though. I use coolant as well as oil :-)
![](http://www.mentalsocket.com/iroc87/oilfouled.jpg)
#56
Car: 1987 IROC
Engine: 350 vortec
that's nasty stuff! that thing is going to be a new animal with 8 healthy holes
#57
Car: 87 Iroc
As bad as this looks, the other 7 aren't that bad. Only one other cylinder has been an oil fouler and a couple others make other deposits - coolant maybe. None as much as this one does, but probably bad enough to need changing. Anyway I ran 7.8's on this plug and have only driven about 60 miles since. It has between 1500 and 2000 miles on it total.
I'm sitting here reading that plug and it seems to be indicating "boost too low". Perhaps a 16 psi tune is in order for the evening?!![burnout](https://www.thirdgen.org/forums/images/smilies/burnout.gif)
#58
Car: 1987 IROC
Engine: 350 vortec
of course!!!!!!!!!
enough boost and the oil can't make it to the cylinder lmao
#59
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
http://www.summitracing.com/parts/SUM-162108/
same head but center bolt.
I really do not like 2.02 1.6 valves in a 170cc head though. But with turbo it may not matter that the port speed at the valve is low. Don't know how turbo would handle that my self, I would personally go with bigger runners or smaller valves.
EQ and RHS also have comparable offerings check them out too.
It's good to know that those summit heads are stamped and reboxed IK's. But to be honest if I have to look at a summit advertisement every time I pop my hood they are going to have to drop the price considerably.
#60
Car: 87 Iroc
Thanks Doom... those look quite tempting except for the advertisement on the end, but since I'm running full accessories and lots of plumbing most people wouldn't even notice they were aluminum. I wonder how the exhaust flow is on these. They have fairly large exhaust volume for 170cc intakes. That is a good thing in my case though.
Drove the car to dinner tonight, didn't miss a beat. I didn't put the boost up though... too much fun just driving it after not touching it for a couple of weeks.
#61
Car: 87 Iroc
SUM-162108 Cylinder Heads, Aluminum, Assembled, 62cc Chamber, 170cc Intake Runner, Chevy 1987-95, 5.7L, Pair $995.95
Complimentary Discount $149.39
Delivery and Handling Charge $12.95
Order Subtotal $859.51
Gotta love that early december discount.
62cc combustion chambers would put me at 8.9:1 with my planned build. I was thinking about shooting for 8.5 to 9.0, so this would be on the higher side of that range. This works out good because I can run a thicker head gasket if I need to get it down.
Discount expires later this week, so I need to make a decision soon!
#62
Car: 87 Iroc
Uhgggg the nightmare of finding the right parts that will work together! So I'm down to this:
I have to use straight plug heads, or I'll have to build an exhaust manifold for the driver side. I'm also not sure yet if I can make angle plugs clear the crossover tube that drops down out of the passenger side manifold. I know they won't clear the driver side drop down. Since I have an 87, the middle bolts of the intake are 72 degrees. I can't remember if the 85/86 bases have standard and if they do I'm not sure if they are interchangeable with the 87 runners of not.
If not, theoretically this just added $400 for an aftermarket base or possibly more if I have to fab up new manifold(s).
I really want to make TPI work, but $1400 for heads and another $400 intake, another $2500 into the bottom end and I could have a LQ4/LQ9 and a new turbo, a lot more go and a ton of money left over. This is probably the reason most go that direction. At some point I have to cut my losses. Hopefully I can make a stock base work with the non-angle heads.
#64
Car: 87 Iroc
Yeah I have been researching tonight.. looks like the straight plugs will be on order tomorrow. I was going to 180's but might go for the 195's for future potential
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
#65
Just tossing this option out there... In case you had not known about these Patriot's
http://www.summitracing.com/parts/PAR-2169/
Honestly seems like a good deal.
#66
If you are considering 195's the best "deal" I know of are the Profiler's for a $1000 from one of our sponsors.
They could eat anything that TPI could feed and then some. Really awesome heads for the money.
#67
1 Post
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
It comes down to how much HP do you want. Just using a basic Gen 1 with a hand ported set of steel generic heads and small cam with make 300+ BHP. Add 15 PSI to it and you are up around 550HP or better.
If you want 800+ BHP numbers then I would use the LSx series and get it over with. You can put a crank wheel on it and run your MS-x ECM. I think the later ones are able to use the stock trigger wheels.
#68
Car: 87 Iroc
I looked at the profiler and it seems they only offer 210cc heads. The photos on their site only shows them with perimeter valve cover bolts as well. Also they are angle plug and that's another no-no with my setup for now.
The Patriot heads are perimeter bolt only and about 30 cfm down from the AFR's, but a good price indeed. I just checked all listed version at Summit and they don't list any with center bolt.
With the 15% discount at Summit right now the AFR's end up at $1244 and I get centerbolt, a better match on port size and straight plugs. Not to mention about 30 cfm per side more than the Patriots. Unfortunately my Duramax seems to have gotten severe fuel contamination today and it looks like it might get expensive. I'm running out of time to use the discount, but I'm hesitating on spending money for heads that will be sitting around collecting dust while I'm paying for fixing the truck. Oh well.
#69
These guys at Profiler would do so much business if they just got their information organized.
They do for sure have 195's and I see why you would think they don't searching on google. The first hit barely mentions the 195's. But the flow data for the 195's is right on the front page of their homepage.
Chad Speier has R&D this head to death and has solid info on his page; http://www.speierracingheads.com/profiler.htm
It makes no mention of the intake bolt patterns but says either center or perimeter covers. You are right on it does only mention angle plugs. I would call and clear that up because these heads are a steal at a grand even.
#70
#71
Car: 87 Iroc
No I haven't bought yet. Unfortunately my Duramax got a bad case of fuel contamination and I held off to see what that was going to cost me. When the estimate climbed over $2000 I talked to my insurance and they are covering it. Good thing I did, because $2000 didn't fix it and now we're at $7500. ![Frown](https://www.thirdgen.org/forums/images/smilies/frown.gif)
Knowing I'm only out the deductible, I finally decided to go ahead with the AFR head order this week. Well as my bad luck would have it, the discount code no longer works. So now there is no hurry on ordering the heads.
I've read about cleaning up the stock iron heads and such. Maybe for someone who's got plenty of time to burn up it's a good deal. For me, my back bothers me if I sit for hours doing something like porting. I'd rather just spend the extra on aftermarket heads and bolt them on.
#72
Car: 86' z28 (died 5/1/11) 76 k10 pickup
Transmission: th350
Axle/Gears: 3.73 open
I don know if you have bought heads already but look into the EQ 350E iron heads you can get them off of ebay for 99 a piece bare vortec chambers 12 bolt intake 1.94/1.50 valves center bolt 170cc runners 64cc chambers they are 906 based heads just some food for thought.
#73
Hate to bust into your thread with a queston, but I have been following it and figured you could help me with my megasquirt setup as thirdgen is not being very helpful for me ![Frown](https://www.thirdgen.org/forums/images/smilies/frown.gif)
https://www.thirdgen.org/forums/dfi-...side-c207.html
#75
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
Sanjay
08-12-2015 03:41 PM
mustangman65_79
08-11-2015 03:17 PM
