Supercharging a 305
Supercharging a 305
Im thinking about supercharging my 84 camaro within the next few months. It has a 305 HO. Is there a certain cam i will need? My brothers got one I can get from him, I don't know if it will work or not. Here's a link: http://www.jegs.com/i/Comp-Cams/249/...oductId=746624 . It also has a quadrajet on it, just rebuilt a couple months ago. Will I be able to use it or will i need to upgrade to something else? Also is there anything else i will need to know when adding a supercharger? And does anybody have a kit they recommend or is it better to pick and build?
Car: 1992 camaro rs
Engine: 305ci v8
Axle/Gears: stock
Re: Supercharging a 305
Somewhere on here it says that our lO3s aren't good for supercharging, something with being wet or dry or something like that, I didn't pay much attention cuz I like turbos better. I also heard one thing supercharged cars need to consider is hood clearance. Sorry I'm not much help!
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
he has an L69 not an L03
what kind do you plan on putting on? a centrifugal*sp? or a roots style?
and i'll need someone else to chime in, i'm not sure if an L69 makes enough power for a supercharger?
190 hp though with a cam, exhaust, ~220?
I was thinking about a centrifugal one. And after you saying i may not make enough power i started thinking about putting a turbo on it instead. My friend has a turbo off a volvo truck. Its a 71 trim. That i can get pretty cheap. If i do a rear mount kit would it be to big? Or does anybody have any suggestions
There should be NO problem supercharging a 305. You will have to use a smaller lower/bigger upper than a 350 but at the same time the super for a stock to stockish 350 should be good for your 305 as well. There is actually a B&M install on a 305 with a roots type supercharger in the technical articles section of the main page. A good cam will help you out immensely I would recommend something like a 214/224@.050 grind if this is a budget vehicle, a nitrous grind or something along those lines. This will help evacuate the exhaust. Besides this I would ditch the stock exhaust system end up with something like 1 3/4 or even 1 7/8 headers, and a full dual 2.5 inch exhaust system to get rid of the exhaust.
Ok. I read the article that was in the technical articles. If i was to get a kit like that would i need to get different heads to lower my compression? Right now mine is 9.5:1.
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Why supercharged? Why not turbocharged?
Turbos offer far more adjustability for day to day driving. They can be somewhat harder to install because of some fab work, but the reward, to me, is much greater than with a SC.
Car: 85 trans am
Theres no such thing as lag in a remote mount turbo. Im lookin forward to get the setup from sts, before i start saving for my lsx swap.
Car: 83Z28 HO
Transmission: G Force 5 speed
Welcome to the Turbo board!
I think Drac0nic already answered your cam question best. Not sure, but I think most of the "XE" cams have an LSA of 110 or less. You need something a bit wider in the 112 to 114 range with about a 10 degree or more longer exhaust duration (like a nitrous or small blower cam).
EDIT: Also read the article Damon has....it's helpful, esp. if you're contemplating a Weiand 144.
Axle/Gears: 3.23:1
In my SRT-4 I can go from stockish 10-13lbs of boost to 20lbs with a turn of a ****... The difference is insane! Aside from some supporting mods to handle the extra boost and deliver adequate fuel, making a turbo adjustable is fairly cheap. AFAIK, An S/C setup can only change when you change the pully(s).
Originally Posted by Dante93GTZ
AFAIK, An S/C setup can only change when you change the pully(s)....
some people have different tastes
1988, 305, 95, install, needed, putting, sbc, stand, stock, supercharge, supercharger, supercharging, transam, turbocharger, turbocharging, twin
