What supercharger would fit?
Old 05-18-2010 | 01:47 PM
CrackerJack87's Avatar
Car: 87 z28
Engine: 355/Edelbrock Heads/Pro-Flo Inj
Transmission: Monster 700r4(500hp)9.5" 2800 stall
Axle/Gears: 10 Bolt with 3.23 posi
Does any of the centrifugal superchargers make a carb blowthrough style setup for thirdgens?what I want is a paxon serpentine with the metal carb cap.10 pounds boost MAX
355 - 9.1 comp, Edelbrock Pro-Flo Injection(1000cfm)Performer RPM heads(70cc) Xtreme Marine 278 cam, FlowTech ceramic headers into the ol 80's series flowmaster 3" system.
Old 05-18-2010 | 01:57 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Re: What supercharger would fit?
As far as I know the only super charger that comes in a kit which is a direct fit for our cars is the ATI Prochargers. Their kits are designed for 1988-1992 TPI engines. You can use any supercharger you want but some fabrication of custom hardware may/probably will be required.
Old 05-19-2010 | 03:41 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
There are a couple people on here running the universal SBC bracket on there third gens, I think it requires an adapter. You could get the SBC kit from procharger that is designed for carb setups and go from there. It won't be a directly bolt on affair though.
Old 05-19-2010 | 04:44 PM
Street Lethal's Avatar
Doesn't the universal Vortech setup fit with a cowl....?
http://www.vortechsuperchargers.com/product.php?p=138
Old 05-19-2010 | 04:49 PM
Twin_Turbo's Avatar
Procharger doesn't make a supercharger bracket for an 87, it's only available for the 88+ serpentine system, not the 87 serpentine alternator/v belt everything else combo.
That doesn't mean however you can't modify it all to work. I did. I also swapped all the pulleys but it could be made to work with the stock serpentine/v groove combo pulleys.
Just buy a carb hat/igloo if you want to go that route or get a pressure referenced carb and a hat.
New2Chevy
09-28-2015 01:35 AM
xXIROC ZXx
Wheels and Tires
09-16-2015 12:18 AM
1Aauto
Sponsored Vendors
09-08-2015 12:14 PM
BOOT77
09-05-2015 04:55 PM
Formula_88AE
09-03-2015 02:47 PM
