Nitrous plugs ?
Car: 1989 iroc z28
Engine: L98 350 carb
Transmission: built 700r4
Nitrous plugs ?
any one know what plugs to run for a 1989 iroc 350 5.7 with a 125 shot of nos i want to go 2 steps colder then stock but dont know the part # any one by chance know?
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Re: Nitrous plugs ?
Factory plug is an R45ts, go to an R43ts that is two steps colder. I only know the AC Delco numbers off hand.
If you get another brand run standard copper plugs, DO NOT RUN PLATINUMS
Re: Nitrous plugs ?
Nitrous Oxide Injection1. Try to avoid platinum (particularly double platinum) plugs. There are suggestions that a chemical reaction may occur and some unusual deposits will form on the electrodes - these may impede ignition performance. Double platinum plugs (where a platinum 'chip' is welded into the ground electrode) may be at risk from the platinum chip becoming detached in extreme temperatures, the surrounding electrode material will doubtless have a lower melting point. A platinum chip dropping into the combustion chamber could be disastrous.
This is a pretty good link for info about spark plug choice when running nitrous.
http://www.spark-plugs.co.uk/pages/t...park-plugs.htm
wigmobile
09-17-2015 03:38 PM
89 formula TPI
09-07-2015 11:06 AM
