Just another blow thru MP-T70 build thread ***NEW PICS ON PAGE 4***
#201
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
Re: Just another blow thru MP-T70 build thread ***NEW PICS ON PAGE 4***
I figured that you did something like that with the hood, I was wondering what you did to keep the nose from flapping around since that is usually lined up with the brace mounted to the front of the core support and the flat panel over that, which you don't have...
I'm a bit surprised that you're convinced that you're running out of turbo so soon, people have gone a lot faster with even old school 76mm turbos. I'm considering trying a holset HX52 that has a 68mm inducer that I hope to run faster than that...
#202
Originally Posted by noboostnogo
I am hoping to hit ~700whp with no more than 15psi but i dont know if i will need some meth/water to get there....
#204
Car is finally all one color again
The new engine is pretty much ready to be put in the car. I think i will slap some headers on it for a few miles to brake it in a bit... we'll see lol
#205
Car: trans am
Engine: 5.3 l59 flex
Transmission: 4l60e
you have inspired me to go ahead with my turbo build up in my 85 trans am
#206
1 Post
Car: currently 91 camaro
Engine: soon to be 350 turbo
Transmission: soon to be 4l80e
Axle/Gears: 99 ss rear end with richmond 4:11's
I'm gathering my parts now to do a blow through turbo build and i just read every single post in this thread... wow great stuff i learned a ton and your ride is awesome, nice job. for someone in there early 20's you seem to have a lot of knowledge. I'm 34 and admittedly not very mechanically inclined(but I'm getting there) and my hats off to ya lol very very nice work . cant wait to see some more.
#207
#208
I found a twin setup hotside cheap, I'm thinking about modifying it for a single. It seems much more sensible, what made you go with a single?
#209
i dont know where i left off but the engine is done and has been for months. I installed the water meth kit, havent gotten to use it.i am building a th350 for it with manual valve body and 4000 stall converter. and spohn xmember with mounted tq arm, also went ahead and installed a new thermostat housing with a rad cap since the thermostat is the highest point of the cooling system and i was never able to put enough liquid in it therefore causing some overwarming issues. lol i also installed the lower radiator bottom piece so it should never go past 200 degrees lets hope. other than that its been sitting at my parents, i need to fix the fuel sender unit cuz its not letting me know how much gas i have left in the tank. Havent done a whole lot since ive been helping my brother out with his '73 formula with a 427 bbc
#210
1 Post
curious why you went from a trans with overdrive to a tans without? is this just a track car or street?
#211
It's just street car but the th350 is better for racing than a 700r4 and my tranny was acting up I'm getting the 700r4 rebuilt by the same guys if you are interested in it they claim it could handle up to 750 up and that it was my fault i burnt the clutches by not having the tv cable properly adjusted
#212
It's been cold and the track is still closed do I decided to relocate the transmission oil cooler and put a fan on it on a temPerature switch I also went ahead and got some tubular a-arms and I'm also doing ls1 brake upgrade and my friend bought new wheels for his 4th gen trans am ws6 so I traded him my adjustable tq arm since I replaced it with a dmember mounted one for the th350 and 100 bucks I thinking was a decent wheels they are 17x9?? I'm keeping the 15" with drag radial for the track and the 17" are for the streets
#213
Stupid iPhone won't let me upload pictures...
#214
and the last one is when i was machining theh ubs for the new brakes
#215
im gonna go with 275 40 17s all around i bet i wont be able to get on it ever on the streets lol
#217
I ended up just getting some basic tires for those rims I will just take it slow on the streets and at the track I'll just slap the 15s on
#218
#219
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
Lookin good! What brakes did you put on there?
#221
1 Post
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
what color blue is that ?? very interested.. i also gave up on my lt1 swap and now im going with a 6.0l lq4 with l92 heads and ls3 intake with hopefully a 76mm turbo.. i have everything but the turbo stuff and the intake
#222
I've been driving it around a lot and it runs great. It never goes past 180 degrees anymore so I'm happy now!!! the tranny works great ive been just blowing thru the converter like crazy it's no fun. I'm sending it back to TCI and they're restalling it for 150 so that's not bad I just have to take the tranny back out... Oh well
Ghettobird52
07-05-2024 11:18 PM
xbmx89
South Central Region
10-31-2015 10:59 AM
Linson
08-21-2015 02:12 PM
