Just another blow thru MP-T70 build thread ***NEW PICS ON PAGE 4***
#51
Car: 1985 Z28
Axle/Gears: fourth gen 3.42
Re: Just another blow thru MP-T70 build thread
looking good man. how bout these snow storms huh? were going on 12" right now and its supposed to snow straight through tomorrow night. put my project on hold for a while...
#52
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
man i feel ya, im tired of all this snow already. luckily we're further south so its not as much but 5-8" is still more than i want haha
#53
just picked up some new parts today, 50/50 rear shocks, 90/10 front struts, new oil dipstick, mallory fuel pressure regulator. Thats it for now, stay tuned
#54
Ok so the snow has melted. Saturday i was off work and it was 60* outside so decided to work some on the car. I dropped the rear end and the tank. Today i removed the fuel lines and couldnt do anything else since now its raining . But i was able to make it to the store and pick up some parts i bought 23' of -8an SS braided line and an inline fuel filter that the guy recommended. here are some pictures
out with the old,
old fuel lines
i hope 23' will be enough for both feed and return.
i think i might have to pick up a 4th gen fuel tank since i read somewhere that the 3rd gen tanks arent big enought for dual walbros im gonna have to research this
out with the old,
old fuel lines
#55
Car: 1981 Buick Century Wagon
Engine: 87 GN engine
Transmission: 2004R
Looking good man, take a few pics while your modding your sender for dual pumps. This is a mod I plan on doing myself in the near future (3 months)lol
Making some good progress. Here in PA I still have a foot of snow on my property, covering up all my cars.
#56
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Also duak walbros fit ask me why I know :P, They are really tight and took me about 3 tries (rotating the second pump different ways to make it fit)
Hardest part is getting the socks in.
Jay
#57
Jay- Question for you, how did you replace the fuel feed line that comes out of the sending unit? did you use one of these tubing adapters? http://www.holley.com/165008ERL.asp i wonder how much that short tube would restrict flow to the -8an line
I forgot to take pictures but i received my 3" mild steel super builder kit and v-band assemblies to make my downpipe. I got them from Columbia River Mandrel Bending. Great company and great customer service. I recommend it if anyone needs mandrel bends, great prices also.
I also received the other set of my IC pipes of 3 inches.
At work we were having some great accomodation on dynamat so i went ahead and ordered 2 bulk packs for the firewall.
#58
mmhmm this dual walbro intank mod in a third gen tank isnt lookin too promising
i think what i will do is get rid of the line that used to go to the canister. drill a 3/8 hole and clamp the pumps together and use the stock line for one of the pump and a new line from the pump to the new fitting/hole then T it off outside the tank
Idk how i will do the -8an return yet
#59
Transmission: 2004R
you could always run the return to the filler neck.
#60
I was playing around with the pumps and i think i might have found the placement for them.
I also started building some plates to get rid of the old battery mount.Im still working on it.
I need to finish my fuel system so i can drop the car back down and pull the engine/transmission out so i can shave the engine bay and modify the turbo headers
#61
I forgot to post this picture, i still have some cutting left to do but i like its looking alot better than the stock piece.
#62
picked up a couple of fittings and got to work
stay tuned for the finished product
#63
ok done with the dual walbro setup. it wasnt too bad after all
drilled a small hole for the second pump's wires
..............IT GOT STUCK....... i couldnt get it to go in or out
but after playing with it for a bit it just went in.
Im done, now its just time to put the tank back on
I routed the lines so that the fuel Y-block would be where the old tank lines connected to the old body fuel lines.
#64
Congrats, fantastic build! I wish I would have tried to make my own dual pump setup...it would have saved me alot of money I think but oh well. Glad to see you got it to work in the thirdgen tank. It does fit as you can see but is not as easy as the 4th gen tanks. Theyhave a much bigger hole.
Cant wait to see the results. I havent looked into this thread until now, i'm surprised I havent because I've seen the thread title before. Glad i stopped in. Good stuff.
#65
Im hoping to put the tank back on tomorrow as well as the rear end, drop the car and pull the engine out sometime this week, thats the plan lol
#66
1 Post
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
What are you going to do about sealing the red and black wires? As pictured, it is going to leak gas pretty bad just using a rubber grommet. Is that regular EFI fuel line or submersible? Regular EFI won't last long in a tank and will deteriorate........and go lean.
#67
I used a sealer called GOOP which is a fuel sealant i just forgot to take pictures, as far as teh fuel lines go i did use gates submersible fuel lines.
#68
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
looks very good. im digging the car and the fuel setup. i think im gonna go the 4th gen tank route for mine. im planning on dual boschs though, and perhaps a 3rd bosch inline. not sure yet.
my build is also a blow thru but going with the slightly larger mpt78.
also where did u get the fittings snd line for your power steering lines. they came out very nice,
#69
You should start a build thread i like seeing peoples builds.
#70
Car: 02 SS
thanks i will go back thru the thread.and find part no.
i will be starting mine once i get all the parts and am ready to go. still collecting main parts.
#71
not a big update but its something. Ive been working mid-shifts at work so it doesnt give me time to do much.
Ive been working on the roll bars and im almost done i just need to tack weld the two front bars and then weld away. I just want to make sure they will clear my armrests.
this is the first pic i took
I also just got in my new extreme velocity carb hat.
#73
#74
Car: 02 SS
looking good. are u shooting for low 9's or hi 8's full trim?
#75
#79
1 Post
Engine: 3xx ci tubo
I have always run regular SBC, but the price of a used LSx engine is so low now it is hard not to want to change.
Street car or race car.........an LSx makes more power out of the box and adding boost just makes more power. A straight up comparison will end up with a stock LSx making more than a stock SBC. I also believe in using what you already have if it is good. If the SBC went into a bunch of pieces then I would look at an LSx for a replacement.
#80
#81
havent really done anything to my car latetly since ive been helping my brother out with his car.
#83
finally finished the roll bars and they clear my door armrests
Painted.
I will pull the engine out today and start working on the turbo headers as well as shave the engine bay this week and spray it blue.
Painted.
#84
Car: 1987 Z28
looking good man, you should paint the floor and t-top area while your at it!
Jay
Jay
#85
thanks, quick question for you. When you built your headers how did you weld runners 3,5,4,6?? did you weld them on the inside? tig welded them or mig? i'm about to start on mine and was just trying to get an idea of how to do those since they are so close together
#86
Originally Posted by noboostnogo
no no no im hoping for high 11s with this setup. next year or when this one goes i will be building my bottom end and get some afr heads and shoot t for mid 10s and thats it....
#87
There is a couple of ways to go about doing mid 10's. You can do it with power or launch. 10.5 at 125 is abit harder to get since you need to come off the line much harder than say a 10.5 at 140. If you make power to trap 125, a single pump would work, but if you make power to go 140, I think 2 are needed.
Comfortable mid 10's is about 128-130mph which is near 550whp. Capable on single pump with hot wire kit but 2 is good for insurance.
#89
dont get me wrong, we all know how this game works and once we achieve our goal we want more and more until boom so 10.5 is my goal right now but i want to be ready for more in case/ when i decide to go faster lol
#90
#91
Thats what I figured. Soon mid tens will feel slow to you, especially when your spanked by a nine second street car. Just remember though, when it comes to blowthru, the way we calculate the fuel pressure requirement is....;
P = (base fuel pressure) + (boost pressure) + (line losses) + (10-15 psi if running a dead head regulator)
.... you need less fuel pressure when running a return style regulator as opposed to a dead head.
#92
Yeah, i made a low boost pass at 10.5 psi and ran 10.55 at 132 and it was the most boring ride... it was smooth and uneventful. Its sad to think that 10's are boring. There is no limit to speed I guess. You always want more.
#93
#94
Small update:
I pulled out the engine, put the carpet and rear interior pieces on, dynamated the transmission tunnel with 2 layers of dynamat. and finally got started on turbo manifolds.
Lets just say that buying those chinese headers was a waste of time and money it would take alot of modifying to get them to clear my valve cover, #8 spark plug (even with shorties it was wayyyyyy to close to even put a spark plug wire on ) it was also hitting the oil dipstick and the cross over pipe was nowhere close to lining up. Soooo i decided to build my own. The turbo will go with the AC compressor originally went with the serpentine setup. Im building a bracket to keep the turbo up and work my way back with 2.5" to the crosspipe
thats where it will go
I need to make as much progress as i can for the next month. Starting May 24th i will start classes again and i will have little to no time to work on it unfortunately. I took summer classes in 09 just so i could take a semester off thinking i would be able to finish it but then i started doing other things and barely worked on it. My goal now is to have it at least running by August which i think is doable. Being a college student and working full time SUCKSSS... wish me luck
#95
Car: 1987 Z28
Awesome to see some progress!
Im completely backtracted lol, just tore my new 6.0L down to nothing awaiting parts, then start over on the hotside haha
Jay
Jay
#97
#99
Car: 1987 Z28
Gonna try to make 6.0L manifolds fit (been proven over 1000hp) and turbo mounting in the same spot probably. Im just awaiting my mount adapters so i can get the block set up and start mocking!
If not then i will build some headers simaller but a bit lower down to make more room for a larger DP
Jay
Jay
#100
havent really done much these past couple of days. My dad just bought a cnc milling machine so we've been workin on getting this bad boy settled in.
in the near future i see me buying a cheap set of aluminum heads and have my dad cnc port them LOL
small update on the manifold. I cut up the ssautochrome one i bought and just reused the header flange which is a nice 3/8" stainless steel with square 1 5/8" holes as well as the t4 flange. i have not yet messed with the small 35mm wg flange i will most likely buy a new one or if i have time machine one. They are coming along pretty good #2 and 8 cylinders are done just have to tack weld them and get started on #4 and 6 as well as modify the crossover pipe to fit the new manifold. I am done with the support bracket and let me tell you, this turbo is not going anywhere. It will aslo give me room for enlargement if i get rid of the tensioner and relocate the alternator and ps pump. The way its setup right now i have enough clearance for a 4" to maybe a 4.5" downpipe as well so well see haha
almost forgot i also started dynamatting a bit with 2 layers of dynamat extreme
