Brakes for boosted applications
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
What are all you boosted guys doing about brakes? Hydrobooste or what?
I know cobras and stuff have hydrobooste. But then I also know guys running F1s on big blocks that just run normal brakes, with MAYBE a resivoir. Seems like this would only let you have one or two really good pumps if you are making booste.
Am I right?
Am I right?
Re: Brakes for boosted applications
True, but it's unlikely you're deep enough in the throttle to be making boost AND be pumping on the brake pedal at the same time. As soon as you let off the throttle the manifold goes back into vacuum and refills the reservoir nearly instantaneously.
I am sadly still on stock brakes up front and i have the C5 kit just sitting here. No problems on boost. Only time I am on the brakes and have boost is during the burnout, but i hit the brakes before i start the boost, so no problems
Engine: LS3
All great info. Thanks guys. I will stick with my standard C5 brakes and see how they go. Dump more $ into the SC!
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Not that its the same but my WRX has a standard brake booster and it works great.
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Im running a stock master/vaccum booster with LS1 front brakes and 91+/LT1 rear brakes
Works great! HUGE improvement over the stock 10.25 rotors, those were scary with my lumpy N/A setup!
Jay
Jay
Engine: LS3
Great to hear. Stock style setup it is!
Thanks.
Thanks.
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Drove my buddy's 92 with an F1A just last weekend, it has stock booster/master and stock front calipers with LS1 rears. The brakes worked fine, plenty of power assist.
IROCZDAVE (88-L98)
11-19-2015 07:03 AM
dbrochard
09-19-2015 08:13 PM
