Anybody use Reichard Racing Pulleys to reduce slipping?
Old 11-05-2009, 02:42 PM
TGO - 10 Year Member
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
I'm possibly getting some awesome belt slippage with my Procharger P1SC that I'm trying to remedy.
Using their 3.7" diameter pulley, I show ~7.5psi on my pillar gauge, but on the dyno recently they barely measured 3psi.
I've noticed some black film/dust on the head unit and bracket, indicating some slip I'm assuming.
The current belt tension seems tight and when pressing down perpendicularly, it has barely 1/4" flex. I don't recall if it was a Gates, or an off brand. I may try a Goodyear Gatorback next.
In addition to that, I was reading on the Reichard Racing ultra-grip pullies. Twice the price as a standard pulley and I've heard they can eat a belt if not aligned properly, but I wanted to know if they have any reviews in here.
Any other suggestions to look into are welcome as well.
Thanks!
Old 11-06-2009, 11:20 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Anybody use Reichard Racing Pulleys to reduce slipping?
- How did the dyno measure your boost pressure? Where did they tie into? Same place your gauge pillar is measuring?
- Have you verified your belt alignment with a straight edge or anything like that?
Old 11-06-2009, 11:48 AM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
Belt slip on throttle lift off is normal. If it doesn't slip you risk damaging the gears in the compressor.
Old 11-06-2009, 12:03 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Are you running the 8 rib setup? Possibly moving over to the 12 rib would get rid of the belt slippage.
Old 11-07-2009, 12:17 AM
Car: '89 GTA
Yes, they tied into the T where the boost gauge lines are. It's an electrical gauge btw. How is it the gauge would show 7+ and only measuring ~3 on the dyno?
I think the belt is aligned OK, but I do see a little white fray on one section, nothing major though. Mainly the black film makes me think it may be slipping at higher rpms. I am hoping a better belt and pulley helps, but not sure what else. I guess a boost leak is a possibility as well. How does 1 check for that, other than obvious connections in intercooling piping, etc.?
I'm using the 8-rib and it's not like I'm using a tiny pulley, I shouldn't have to swap to a 12-rib setup to see the correct psi.
Old 11-08-2009, 03:05 PM
Sonix's Avatar
Car: 1982 Trans-Am
Perhaps your electrical gauge isn't properly calibrated? If two gauges measured something different, I wouldn't assume leakage yet, i'd check for a bad gauge. See how you can calibrate the gauge.
How long have you been running that belt? If you've got some white fray and only have a few thousand km's on the belt i'd be concerned about it being out of alignment. I'm assuming the white fray is on a side and not the underside?
Old 11-09-2009, 08:35 AM
Car: '89 GTA
Less than a year on the belt and yes the small segment I noticed was on the side.
bigjay89gta
10-15-2015 08:04 AM
jaridjohn
10-05-2015 07:01 AM
gord327
10-03-2015 01:25 PM
anesthes
09-30-2015 07:48 AM
JSDaddy189
09-26-2015 03:50 PM
Quick Reply: Anybody use Reichard Racing Pulleys to reduce slipping?
