couple questions on remote bov's
Old 10-06-2009, 07:58 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
My paxton is only pushing 6psi but I want a bov to elongate its life.. My first question is what psi bov(spring) do I need to operate properly with 6psi of boost? Second are there any drawbacks to running a remote bov? Finally due you recommend and brands thatll cost $150 or less... thanks guys any info is appreciated
Old 10-07-2009, 09:40 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Re: couple questions on remote bov's
A bov spring is sized on engine vacuum, not boost psi. You want the bov to open just below idle vacuum, so if your engine idles at 15"Hg, you'd want it to open at 16 or 17"Hg. Most bov's can be adjusted by adding washers to increase opening pressure, or replace/cut down the spring to lower opening pressure. Bov springs are usually rated for psi, and 1 psi = 2"Hg, so for the above example you would want a 8psi spring.
There aren't any drawbacks by adding a bov, just the benefits of reducing surge, keeping boost up during shifts, and the cool psshhh sound.
For my turbo, I bought a cheap eBay bov and it's been working fine for 2 years. You might want to browse youtube and listen to sound clips of different models if sound is a factor for you.
Old 10-08-2009, 01:28 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
thanks for the info. It didnt have mounting directions on the link, is yours remotely mounted or directly on the intake piping?
Old 10-08-2009, 01:51 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Yes, the bov mounts to the intake tubing. What do mean by remote mount?
Old 10-08-2009, 07:37 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
my friend saw an article in a mustang mag where there was no room for the bov on the intake piping of this guys build so a hose was used to connect the bov to the intake piping and the bov was mounted down in the engine compartment.
Old 10-09-2009, 10:58 AM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
I have those rotors with EBC Greenstuf pads on my 2000 T/A, ***** all over the way the stock rotor/pad combo stopped the car
Old 10-09-2009, 01:22 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Oopps I posted the pics in the wrong section, they were supposed to be in the reginal post.
Old 10-10-2009, 10:53 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
lol....just got back and "edit" your post and delete the pics and text...
Frozer!!!
01-19-2024 04:55 PM
chazman
08-28-2018 03:25 PM
Cleotiz
01-06-2018 08:56 PM
ezobens
08-19-2015 10:29 PM
redmaroz
08-16-2015 11:40 PM
Quick Reply: couple questions on remote bov's
