supercharger
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
supercharger
well heres the deal i have the v6 camaro. and i want a supercharger. however when i search for it it always leads to a v8 supercharger. i dont like turbos and a v8 build is for a later date, for a different camaro. so my question is any one now where i can find a v6 supercharger? under 500 would be a dream but any price under 1500 is good. umm doesnt really have to be direct bolt on kinda speak but it would be nice.
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
Re: supercharger
A turbo would be the cheapest route in this case. If you're dead-set on a supercharger, the next best option would be to use an oem Eaton Supercharger from the salvage yard. They do not have to be mounted directly on the intake but you would have to fab up brackets, an air box to bolt the s/c on top of and figure out the belts/pulleys.
http://www.thehighspeedlab.com/catalogsc004.html
In the case of a turbo, it would just be a matter of making a Y pipe off the manifolds and a downpipe back to the original exhaust.. oh and an oil feed/return.
By the way, it wouldn't be a bad idea to grab the injectors from the car you get the S/C from. I'd be tempted to get the ECM too, since it is set up for boost.
Engine: 305 tbi
Re: supercharger
hey thanks, i dont like the turbo sound or the lag thats why i want a supercharger. and its a carb so no injectors or ecm...and its a 5spd to boot. in fact i dont think i even have a comp!
Car: 87 Iroc
Re: supercharger
Ah that carb makes it easier in some ways. I wonder if those eatons can handle a carb in front of the rotors?
Car: 91 Trans Am
Engine: LSA
Transmission: T56 AWD
Axle/Gears: 8.8 4.10
Re: supercharger
Any non centrifugal SC will have rotors to compress the air inside the unit
The rotors will survive being wet with fuel
Newer units have a teflon coating on the roters to improve seal and efficiency. The are sometimes not-ok with having gas thru them but they are NEVER happy with methanol on them
Engine: 305 tbi
Re: supercharger
ya good point lol, but you now what i mean. im not taking it to the drag strip or circut races. this is gona be my daily driver that also beats... umm non muslce cars (?)
toronto formula
11-10-2015 06:17 AM
305, 84, centrifugal, eaton, firebird, injection, lm7, metanol, pt6766, salvage, supercharged, supercharger, tbi, v8, yard
